Old 06-27-2018, 02:14 PM   #57
CSG Mike
CSG Mike's Avatar
Those results only make me more excited to finish my own testing!
Old 06-27-2018, 02:56 PM   #58
RayRay88
Drives: 2017 86 860 Special Edition
144whp sounds pretty low to me for a stock kouki motor. Most i've seen are at around 170. Might be heart break dyno. 60 over 170 puts it at around 230whp before any head work or cams. That's very impressive.
Also that torque number is totally believable, a healthy bump is well within the benefits of a ITB's. I do wonder why power and torque start to taper at ~6800. What's restricting it? Cams? Head flow? Runner length?
RayRay88 is offline   Reply With Quote
Old 06-27-2018, 03:47 PM   #59
CSG Mike
CSG Mike's Avatar
Generally speaking, smaller trumpets = more low end gains, at the cost of high end gains. Likewise, larger trumpets = more high end gains, at the cost of low end gains.
These trumpets are on the smaller end for our displacement, so I would expect to see a healthy midrange boost, that chokes up top.
Icecreamtruk (06-27-2018), Williampreza (06-27-2018)
Old 06-27-2018, 04:29 PM   #60
fika84
fika84's Avatar
FINISH IT! My pockets are burning.. I've been waiting for some real results and this makes me really excited!
fika84 is offline   Reply With Quote
Old 06-27-2018, 04:42 PM   #61
max20s14
Drives: 14' Raven M/T - 02' is300
Perhaps SARD will release an N/A version of this kit down the road without the surge tank?
max20s14 is offline   Reply With Quote
Old 06-27-2018, 08:27 PM   #62
RayRay88
Are you sure you don’t have the two reversed?
I know to calculate second and third harmonic pulses you need to account for runner length which is bell mouth to the valve seat. I’m not completely sure about the fa20/boxer motors but Honda and Toyota runners in the head portion were pretty short so to boost mid/low range power you had to run decently long stacks.
Old 06-27-2018, 11:32 PM   #63
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Kinda like how BPB lengthen the intake to shift power lower.
JimmyMac is offline   Reply With Quote
Old 06-28-2018, 12:32 AM   #64
CSG Mike
CSG Mike's Avatar
Length =/= diameter. I'm referring to diameter!
RayRay88 (06-28-2018)
Old 06-28-2018, 01:34 AM   #65
Bach415
Bach415's Avatar
Drives: Whiteout FRS
If I am correct, on one of his IG post, I think he did mention it was a new dyno that they used when tuning the ITB's where as the stock numbers were on the old dyno. Can't be too sure that the gains are that accurate imo.
Bach415 is offline   Reply With Quote
Old 06-28-2018, 06:11 AM   #66
churchx
churchx's Avatar
Drives: 2014 GT86
No biggie, it's normal for forum members to draw conclusions from different dynos numbers without baseline
CSG Mike (06-28-2018), Hyper4mance2k (06-11-2019)
Old 06-28-2018, 06:21 AM   #67
FunnyGopher
Drives: 2015 BRZ Limited
This looks exciting! It's fun to see a car actually running these NA. They sound FANTASTIC. I'm interested to hear how they feel, regardless of power. I hope they get their forum user working, we need answers!
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
The Following User Says Thank You to FunnyGopher For This Useful Post:
MisterSheep (09-29-2018)
Old 06-28-2018, 06:56 AM   #68
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
unless the baseline was taken the same day it is pretty useless anyways, temp, humidity, etc will make the baseline useless as well.
why? is offline   Reply With Quote
Old 06-28-2018, 07:14 AM   #69
churchx
churchx's Avatar
Drives: 2014 GT86
At very least having stock baseline is single biggest variable elimination to roughly/remotely add some comparison ground to compare relative gains against it, instead of marking all of dyno results out there as completely unusuable. Reducing differences between eg. +/-30% to eg. +/-5to10%. "Better then nothing".
Old 06-28-2018, 08:26 AM   #70
StraightOuttaCanadaEh
Wes
I commented on his post on IG and he said the most expensive part was the Motec. He mentioned that the price for the build was as much as a top end turbo kit or even a swap. But then again, he's planning to use it as a track car only. If I got this upgrade, I would need to know that the car would still be driveable in the winter
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
In for the long haul Ultimate NA build thread. celek Engine, Exhaust, Transmission 669 06-07-2020 06:26 PM
TOG ULTIMATE TOYOTA 86 GT86 FT86 SUBARU BRZ FA20 STAINLESS STEEL EXHAUST HEADERTOG UL Andrew666 AUSTRALIA 8 11-19-2018 04:24 AM
RallySport Direct's Ultimate Drivetrain Thread! ***New Website*** RallySport Direct Transmission and Driveline 92 09-01-2015 12:17 PM
RallySport Direct's Ultimate Interior Thread! RallySport Direct Interior Parts (Incl. Lighting) 45 03-25-2015 01:12 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
