Old 05-17-2018, 12:10 PM   #29
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by why? View Post
so you can run these with stock everything else? I'd be very interested, I seem to rub on absolutely everything, If the spring rate is oem or higher and the handling won't be destroyed anyways.
I finally got them tested at Eibach.
Chuhatsu lift springs:
Front: 129 lbs/in
Rear: 206 lbs/in
For comparison purposes:
Car: Front OE Spring Rate:
Subaru BRZ 27 N/mm (153 lbs/in)
Scion FR-S 23 N/mm (131 lbs/in)
Rear OE Spring Rate:
Subaru BRZ 34 N/mm (195 lbs/in)
Scion FR-S 37 N/mm (211 lbs/in)
The Following 7 Users Say Thank You to mav1178 For This Useful Post:
churchx (05-17-2018), lamawithonel (05-20-2018), Lonewolf (06-28-2018), Spuds (05-17-2018), Weasel Soup (08-15-2018), why? (05-18-2018), Yoniyama (05-17-2018)
Old 05-17-2018, 12:25 PM   #30
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
A bit of a hijack, but sort of related to Mav's post above: Are there different spring part numbers for our cars based on option packages/vehicle weight, or are all BRZ springs (non including special package models like PP, tS, etc) or FR-S springs the same rate? I've been wanting a set of BRZ front springs for my FR-S, but want to be sure my ride height is going to stay where it is right now. Since our cars have very few items that are optional, I assume they are all the same within a given model, but just want tbe sure.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 05-17-2018, 01:42 PM   #31
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm, it looks, like fronts may become a bit overdamped then? As side gain, maybe car will be less understeery then stock even without camber changes.
P.S.
Maybe worth adding those rates to OP.
Old 05-17-2018, 01:46 PM   #32
Yoniyama
Drives: BRZ 2018
Thank you so much for posting the spring rate information.
Near OEM spring rate and an extra 15mm of wheel travel, I am ready to get a set.
How do I order a set for AT for delivery in the US?
Yoniyama is offline   Reply With Quote
Old 05-17-2018, 01:49 PM   #33
Racecomp Engineering
Front: 129 lbs/in
Rear: 206 lbs/in
Thanks for that. Interesting...basically close to OEM FRS spring rates.
- Andrew
Racecomp Engineering is online now   Reply With Quote
Old 05-17-2018, 02:01 PM   #34
venturaII
venturaII's Avatar
Well, if you have extra travel available, you don't need a stiff rate to control movement in as restricted an area.
Old 05-17-2018, 03:23 PM   #35
mav1178
mav1178's Avatar
The fronts are barely softer than stock FR-S, so it may just be sample variation. Impossible to determine that conclusion based on one single spring test. In N/mm it's 22.68 front on Chuhatsu vs 23 on stock FR-S.
Old 06-24-2018, 09:29 PM   #36
H_K
Drives: '13 Scion fr-s
Are there any installation instructions in English? Any North American suppliers?
H_K is offline   Reply With Quote
Old 06-26-2018, 05:01 PM   #37
mav1178
mav1178's Avatar
https://frsport.com/chuhatsu-plus-cp...z-zn6-zc6-2013
No need for installation instructions in English unless you're doing spring installation for the first time ever.
Old 06-28-2018, 10:27 AM   #38
Wiscocrashtest
Drives: 14 BRZ, 16 FoSt
this is exactly what I need. Now to decide whether to use OEM dampers or get Konis...
Wiscocrashtest is offline   Reply With Quote
Old 06-28-2018, 11:35 AM   #39
churchx
churchx's Avatar
Drives: 2014 GT86
If not the shortages of Bilstein, i'd also think of B6. Otherwise .. OEMs, if they are in good shape. Used MY2017 when they appear among classifieds. Koni yellows? Hmm, also probably may work.
why? (08-08-2019)
Old 06-28-2018, 02:27 PM   #40
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
I've had a set for sale for dirt cheap for months... A little damage, but they still work. I don't think anyone really wants them. "Coilovers and slammy McSlamerson, camber, Bruh."
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 08-07-2019, 12:56 AM   #41
leevanf
leevanf's Avatar
Drives: 2014 BRZ Limited A/T
Front: 129 lbs/in
Rear: 206 lbs/in
Hi Mav, are the OE springs used for comparison on the BRZ, from the older MY or 2017MY?
leevanf is offline   Reply With Quote
Old 08-07-2019, 11:29 AM   #42
mav1178
mav1178's Avatar
Data pulled from other parts of the forum.
Where to Lift with Two Post Lift? Don Ivey Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 08-18-2022 08:51 AM
Anyone in the DMV with a lift? Rifle Mid-Atlantic 5 06-06-2016 03:35 PM
EZCarLift Easy car lift portable super easy car lift bren5279 Mechanical Maintenance and Tools 16 09-11-2015 01:57 PM
don't lift pr086 Scion FR-S / Toyota 86 GT86 General Forum 27 08-17-2012 11:51 AM
