Old 06-08-2018, 09:06 PM   #155
carlovestela
Drives: 2015 Firestorm FRS
Racers line told me that its normal for automatic. To drop down to 500or 600 and goes up to 700-800rpm
Originally Posted by brosifSmith View Post
I went and had it done. It still does it, but it has never stalled and actually died. Just goes down to 500 then back to 700. My best guess is it would be the Torque converter, but if its not actually stalling I'm sure it's not the biggest deal. it sure annoys me though.
carlovestela is offline   Reply With Quote
Old 06-11-2018, 11:43 AM   #156
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
How much does it cost to get this done?
N1rve
Old 06-13-2018, 10:55 AM   #157
brosifSmith
brosifSmith's Avatar
Drives: 2015 BRZ Limited
They were willing to do it as warranty work so they didn't quote me on a price. I said, "I don't care if I have to pay I just want the flash done" and they said, "don't worry we will put this under the warranty". I got a 12 month 12,000 mile when I bought the car used. One of the best dealerships I have dealt with, although like I said I think this only fixes super bad idle fluctuation and only during idle. It still fluctuates when the AC is on but this is to be expected
brosifSmith is offline   Reply With Quote
Old 06-17-2018, 04:38 PM   #158
N1rve
N1rve's Avatar
I just had this done on Friday 6/15. It's covered by the Emissions warranty which is like 8 years 80k miles or something really long. If you wanted to pay to get this done, its 1 hour labor ($130 dollars). If they try to charge you with Diagnostic fees, tell them it's under the Emissions Warranty and not anything else so they don't charge you. The dealership tried to charge me 1 hour diag but I fought it.
So the real question is... did it fix the idle issue with the DRL flicker? No.
Does the car drive any differently? Slightly yes, there is more a difference of sport mode and normal mode for the transmission. The sport mode lets the car take off harder while normal mode the car is a lot more sedate (similar to driving in snow mode). I think the car is re-learning at this point but it's been about 3 days and the car still feels a little off.
N1rve
Old 06-22-2018, 10:43 AM   #159
N1rve
N1rve's Avatar
Just wanted to make an update after 1 week.
The DRL flicker has been fixed. The car no longer dips below 500. Even panic emergency stops do not make the DRL flicker. The car holds a solid 500 RPM now.
Initially the car drove differently like it's slower, after one week, the car has relearned how I drive and the DRL does not flicker anymore. I have been trying to replicate the DRL flicker for the past week and I just can't anymore which is good
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
Tcoat (06-22-2018)
Old 06-22-2018, 08:32 PM   #160
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Soloside View Post
I've been very unlucky. No dealer wants to flash the TCM update for me in my 2014
Yea, it seems alot of dealers seemed to have that issue. However, a few people had luck buying later gen TCMs and plugging them in and curing the issue.
Originally Posted by carlovestela View Post
Did you already do that?
http://www.ft86club.com/forums/showthread.php?t=96615
FYI, I brought this issue to light and posted that TSB to this forum. It's not normal and if you have a 2015 you definitely should get the newer TCM flash done regardless like brosif had done.
Also the vin range should've been much much broader but they didn't for some stupid reason. If you are still under warranty it should only ever qualify as warranty work as its a TSB
Old 06-22-2018, 09:12 PM   #161
carlovestela
Yeah. I have 2015 frs AT. So i just need to go to toyota dealer and present the TSB form? Its free right?
Old 06-22-2018, 11:18 PM   #162
FRSBRZGT86FAN
Idk how your specific dealer will react to being handed a TSB. You should probably just say you have the idle fluctuation issue and describe it like the TSB. Also mention that you heard online that this was a well known issue and that theres a technical service bulletin out for it...
Old 06-23-2018, 01:37 PM   #163
carlovestela
Yeah let me try because it never happens to me while im at park mode.
Btw. You still using winjet headlights? Hows the quality and led strip?
Old 06-23-2018, 02:05 PM   #164
FRSBRZGT86FAN
Still good, slight condensation/fogging issues that come and go on the corner closest to the Toyota logo when it rains really hard and gets humid in the summer, however it goes away after the HIDs are on for an extended amount of time. A simple fix is to reseal them with the theretrofitsource sealant, but it really isn't that noticeable an issue.
My only gripe is that the projectors are obviously not designed for an HID bulb and took a lot of trial and error to get the beam pattern aimed properly. Even when aimed right they were great! but not good as other cars I owned with HID or LED headlights. But if it's your first car with HIDs they are perfect.
If I may make a reccomendation, buy them with 5000K HIDs as it matches the LEDs almost perfectly, get the DRL mod from 86speed, and they will look awesome.
Old 06-23-2018, 04:19 PM   #165
carlovestela
Does the condensation affect the bulbs? What about your led strip? It didnt go off after a few months? Cause i read some that theyre led went off. 5000k hid with diode? Is 5500k from morimoto good also?
Old 06-23-2018, 04:21 PM   #166
carlovestela
Sir. Do you have any fb messenger or something?
Old 06-24-2018, 12:47 AM   #167
FRSBRZGT86FAN
if you have questions you can just PM me on here
1) The condensation did not effect anything I've had these for 3 years with no hiccups, its so light and only appears when it rains and goes away when the headlights are on. Thats kind of normal as the HIDs heat up the housing to clear it out.
2) LED strip is still fine, they are OEM quality still no issues or flickers, that seemed to be hit or miss on earlier versions I guess
3) As for the HIDs or LEDs you choose to put in there you can go with morimoto, diode dynamics, or the morimoto H7 LEDS
Those are the best quality HID kits I used.
http://www.morimotohid.com/h7-morimo...=51328%2C51354
In the above link if you used LED bulbs you wouldn't have to worry about ballasts or anything....
As for color LEDs tend to be 5000-6000k so that range will work
Old 08-26-2018, 05:49 PM   #168
Tristor
Tristor's Avatar
I'm necroing this thread, but I just want to say a huge thank you to all the people who posted detailed explanations of the procedure for doing an ATF fluid change and provided shop manual excerpts. I'm about to attempt this as part of my installation of an ATF cooler, and the process seems straight forward if a bit time consuming, but was originally extremely intimidating.
Tristor is offline   Reply With Quote
The Following 2 Users Say Thank You to Tristor For This Useful Post:
FRSBRZGT86FAN (08-26-2018), phrosty (08-26-2018)
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 02:23 PM
Mt transmission fluid swap bdanisi Engine, Exhaust, Transmission 8 02-08-2013 02:09 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
