Old 06-03-2018, 07:46 PM   #2353
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
NOPE.
Originally Posted by Elliotw View Post
Am I meaty?
235/45/17?
Originally Posted by humfrz
I'm old and lazy
Old 06-03-2018, 07:50 PM   #2354
Leonardo
Country Boy 4 Life
Leonardo's Avatar
NOPE.
I didn't want to break his heart. lol
235/45/17 MPSS have the SAME tread width as 225/45/17 MPSS!!!!
I LIKE TIRES!
Old 06-03-2018, 08:18 PM   #2355
rvoll
Drives: 2018 BRZ Limited, 2017 Sportage
Just looked up the chart on Michelin site. The Pilot Super Sport doesn't have a 235/40 or 235/45 listed, so he couldn't buy it anyway. This has been replaced by the PS4S in which the section width of the 235 is wider than the 225. So you would not have broken his heart. Besides, you'd probably go 235/40 to get closer to the right circumference. If you are going wide for looks, and have rims wide enough, then 245/40's are the better option as the circumference is close to OEM.
rvoll is offline   Reply With Quote
Old 06-03-2018, 09:53 PM   #2356
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Read page one paragraph one of this thread. My attempt at humor aside,( Which may be terribly tire nerdy at best) This is the meaty tire thread, which is for "255 + , everything else is just a normal tire size" as per the OP.
I LIKE TIRES!
Impureclient (06-03-2018)
Old 06-03-2018, 10:10 PM   #2357
Impureclient
Drives: 2015 FR-S
I'm going to wait about another 100 posts and by that time the 225s should have worked their way into this meaty tire thread.
It did say 255+ for a reason, not sure why so many 245 and especially 235 were posted?
BRB, about to go post about my turbo in the FI section. Don't have one but....
The Following 3 Users Say Thank You to Impureclient For This Useful Post:
Leonardo (06-04-2018), NAEightySix (06-04-2018), sid94 (06-04-2018)
Old 06-04-2018, 01:41 PM   #2358
BAD ROD
Drives: 2014 BRZ
I don't have a Performance Package, just run-of-the-mill suspension.
Originally Posted by 15limited View Post
He meant Performance package "PP", relating to fitment that package comes with brembos and Sachs dampers, which might have a smaller spring perch? Common rub point in the front is on the oem spring perch
Sent from my SM-G950U using Tapatalk
BAD ROD is offline   Reply With Quote
Old 06-05-2018, 08:43 AM   #2359
GerrelleZeppeli
Drives: Toyota 86
Just a question:
I'm planning to get Work GT5 18x10.0 + 38 with 265/35/18 tires.
Currently on Tein Flex Z Coilovers and am thinking of going -3 in the front and -2 in the rear.
Will this cause any issues/rubbing?
GerrelleZeppeli is offline   Reply With Quote
Old 06-05-2018, 08:59 AM   #2360
15limited
15limited's Avatar
Originally Posted by GerrelleZeppeli View Post
Just a question:
http://www.ft86club.com/forums/showthread.php?p=3094769
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 06-09-2018, 12:01 PM   #2361
Thaeyo
Thaeyo's Avatar
I'm running 225/50/R16 is that meaty enough? :P
Thaeyo is offline   Reply With Quote
Old 06-09-2018, 02:35 PM   #2362
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Way less than 100!!
I LIKE TIRES!
Impureclient (06-09-2018)
Old 06-21-2018, 10:30 AM   #2363
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
Does anyone have any issues with rubbing with 265/35R18 on 18x9.5 +40? i'm worried about rubbing in the rear.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 06-22-2018, 05:24 PM   #2364
cjopant
cjopant's Avatar
Drives: 2015 Subaru BRZ
That'd mostly be dependent on ride height and camber. Spring rate and damping will contribute, too.
I run 18x9.5 +40 with 255/35R18 MPSS, -2.5 camber, and about finger gap of clearance. I'll rub if I have someone sitting in the back, have a bunch of full jerry cans in the trunk, or hit a particularly gnarly expansion joint at high speed.
cjopant is offline   Reply With Quote
The Following User Says Thank You to cjopant For This Useful Post:
15limited (06-25-2018)
Old 06-23-2018, 03:36 AM   #2365
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Originally Posted by drew_kar View Post
Previous owner of the wheels did that. I got them for a steal, would make anyone on this forum mad. I'm not too upset one isn't perfect but I will be fixing it soon regardless.
Sent from my Pixel using Tapatalk
Did you, by chance, buy those TEs from somebody with a red FRS out there in NC/SC?
The Following User Says Thank You to TylerLieberman For This Useful Post:
drew_kar (06-23-2018)
Old 06-23-2018, 01:49 PM   #2366
drew_kar
drew_kar's Avatar
Drives: WRB Brz / SR S14
Bingo. Ante sold me the wheels. He hit me up 3 years later and asked if i wanted them. I have been lusting after them the day he put them on his car haha. Small world.
drew_kar is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 06:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
