Old 05-28-2018, 03:03 AM   #2339
15limited
15limited's Avatar
Meaty
265/35/18 falkens
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
The Following User Says Thank You to 15limited For This Useful Post:
yberther (06-01-2018)
Old 05-28-2018, 06:26 PM   #2340
sactownbwoy
sactownbwoy's Avatar
Drives: 2014 BRZ Limited
WedsSports SA-20r 18x9.5 +45 wrapped in Sumitomo HR ZIII 265/35
sactownbwoy is offline   Reply With Quote
Old 05-29-2018, 12:16 PM   #2341
TurboLag23
TurboLag23's Avatar
Drives: 2018 BRZ w/Performance Package
Hey everyone! Quick fitment question, as I have not been able to find this exact setup so far...
I am considering running an 18x9.5 +38 with a 245/35R18 or 255/35R18 all-around. Suspension-wise, I am a 100% stock Performance Package car.
Will I run into any fitment issues, and if so what will they be?
Thanks in advance!
TurboLag23 is offline   Reply With Quote
The Following User Says Thank You to TurboLag23 For This Useful Post:
NAEightySix (05-29-2018)
Old 05-29-2018, 02:43 PM   #2342
BAD ROD
Drives: 2014 BRZ
I ran 18x9.5 +38 with 245/35R18 (not sure if 255's would fit on the front?) on all four corners for a few years on 100% stock suspension. No problems. No rubbing what-so-ever. Those tires look narrow for a 9.5 wheel, although some people like the stretch look. And the front poke some.
BAD ROD is offline   Reply With Quote
Old 05-29-2018, 03:45 PM   #2343
NAEightySix
Drives: 2015 Scion FRS 6MT (Asphalt)
Meaty Tire Thread
265’s fit for me all around with the same wheel specs (RPF1’s), I’m running -3 camber in front and I believe -2 in the rear. 255’s would be a better fit though
Edit: nvm this is for stock suspension. I can’t read :l
NAEightySix is offline   Reply With Quote
Old 05-29-2018, 04:38 PM   #2344
sid94
Drives: 2013 frs
18x9.5 won’t clear stock suspension however idk about you since you have the sport package
sid94 is offline   Reply With Quote
Old 05-30-2018, 04:32 PM   #2345
Greenbean
Drives: 2017 series yellow BRZ
18x9.5 +38 will clear stock with a 245 tire performance package or not. 255 will not for sure.
Greenbean is offline   Reply With Quote
The Following User Says Thank You to Greenbean For This Useful Post:
sid94 (05-30-2018)
Old 05-30-2018, 04:36 PM   #2346
Greenbean
245 should clear but in my opinion but 245 do not give a very clean look because of the decent amount of stretch on the tire plus their will be wheel gap for days. Stretched tires only look good with proper fitment but this is all my opinion. You could probably lay in the wheel gap tbh but i think lowering springs are a nice cheaper option if you do not want to spend the money on coilovers.
BAD ROD (05-31-2018)
Old 05-31-2018, 06:09 PM   #2347
15limited
15limited's Avatar
Depending on the maufactuer, 245 series tires can run wider/skinnier, theres no black and white line 245 will %100 fit and 255 %100 will not.
Old 06-01-2018, 02:44 PM   #2348
BAD ROD
Drives: 2014 BRZ
What's a "sport package"?
Old 06-01-2018, 07:34 PM   #2349
15limited
15limited's Avatar
He meant Performance package "PP", relating to fitment that package comes with brembos and Sachs dampers, which might have a smaller spring perch? Common rub point in the front is on the oem spring perch
sid94 (06-01-2018)
Old 06-01-2018, 10:27 PM   #2350
sid94
Drives: 2013 frs
Old 06-02-2018, 12:14 PM   #2351
Elliotw
Elliotw's Avatar
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Am I meaty?
235/45/17?
Elliotw is offline   Reply With Quote
The Following User Says Thank You to Elliotw For This Useful Post:
phm14 (04-21-2020)
Old 06-03-2018, 06:44 PM   #2352
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by Elliotw View Post
Am I meaty?
235/45/17?
Are those wedssports?
I LIKE TIRES!
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
