#57 |
Drives: DGM BRZ
Wow, COTA really put your car through some abuse!
| The Following User Says Thank You to jubella2 For This Useful Post: | Code Monkey (04-24-2018) |
#58 |
Drives: Subaru BRZ
Whiteline camber bolts went back in, got an alignment, and bled brakes and clutch.
-3.6 camber in front, rear camber is what it is because I can only change it in 0.5 degree increments with the UCA, still should work well. |
#59 |
Drives: Subaru BRZ
Is this too much lean? I feel like sway bars are in order.
| The Following User Says Thank You to Code Monkey For This Useful Post: | Tristor (05-25-2018) |
#60 |
Drives: Subaru BRZ
Flex Fuel kit installed.
#61 | |
Proud of BOXER
Drives: Subaru Boxer
Can you post up some more pics that show how you routed the fuel line? Looks like you came up with a different way to do it that keeps it further away from the engine.
| The Following User Says Thank You to Clipdat For This Useful Post: | Code Monkey (05-31-2018) |
#62 |
Drives: Subaru BRZ
Good eye for detail!
I did not like the suggested routing around the abs unit for the long fuel line so I routed it under the abs unit. First, I put some expandable braided sleeving on the fuel line, then wiggled the line through. No rubbing anywhere as far as I can tell but when I change wheels for the track, I will pull the wheel liner and see if I can add a rubber loop clamp to hold the line further. |
| The Following User Says Thank You to Code Monkey For This Useful Post: | Clipdat (05-31-2018) |
#63 | |
Proud of BOXER
Looks great, thank you so much for the additional pics. Great job routing it, and that nylon sheath looks like it'll add another layer of protection from abrasion/friction.
I'm still not totally content with mine that's using the suggested/default routing, but I went for a drive today and then popped the hood and touched the line at it's closest point to the engine, and it didn't even feel warm/hot to the touch. I still might put a reflective gold jacket around it for peace of mind. Thanks again.
#64 |
Drives: Subaru BRZ
Finished e85 tune (green and blue curves, the red curve is 93 octane).
#65 |
Drives: Subaru BRZ
Installed Hotchkis 25mm front sway bar, Hotchkis 19mm rear sway bar, and Hotchkis rear endlinks. I have the front sway bar on the soft setting, and the rear on the second soft setting. Aimed for a 3/8" rake with the right side a bit taller than the left side to account for drivers weight, pinch weld heights:
Code:
4.66 4.52 5.02 4.88 |
#66 |
Drives: Subaru BRZ
Another oil change (10,190 miles) in preparation for the upcoming two hpde's. Also changed the diff fluid.
#67 |
Drives: Subaru BRZ
Pulled the fender liner to see if the flex fuel line was rubbing anywhere. Did not notice anything problematic but secured the line with a p-clamp just in case it moves too much during hpde.
#68 |
Drives: In the market for an 86 twin
Did you find out what was making the squeak on Saturday?
#69 |
Drives: Subaru BRZ
#70 |
Could it have been your pads, or was it not that kind of squeak? I noticed you and Joe were both making a little noise on decel when they brought yall into the hot pits.
| Berzerk's 2017 CWP 'Slow and Steady' Build Thread | Berzerk | Member's Car Journals | 12 | 07-24-2017 05:57 PM |
| Rodie's slow '13 FR-S build | rodie | Member's Car Journals | 0 | 06-14-2015 09:05 PM |
| Slow Progression FRS Build | dgerny | Member's Car Journals | 1 | 04-15-2014 07:48 PM |
| Tkalz slow build! | Tkalz | Member's Car Journals | 15 | 10-13-2013 06:35 PM |
| Slow Build by Jooks | jooks | Member's Car Journals | 4 | 07-03-2013 11:53 PM |
