Old 06-20-2018, 01:54 PM   #15
Greenbean
Drives: 2017 series yellow BRZ
Originally Posted by Anderzz View Post
In the front? Either you're cambered wayyy out or you definitely rub fender liner at full lock.
Sent from my XT1650 using Tapatalk
running about 2.5 degrees of camber and no rubbing or scrubbing anywhere.
Greenbean is offline   Reply With Quote
Old 06-20-2018, 02:00 PM   #16
stlgrym3
Originally Posted by Greenbean View Post
correct but a 245/35 is a very conservative option and i know plenty of people running 45 offset with 245/35 no issues at all. I was originally getting wheels that was 9.5 +45 but wouldnt fit over my brakes. I dont think he will run into any rubbing issues and i would hit the fender liner before him but sway could be in question. if has adjustable swaybar endlinks he can manipulate the sway bar some in his favor.
Speaking of brake fitment. I do have Brembo GT BBK: 328mm rotors front and 326mm rear with 4pot calipers front and 2 pot rear. Do u think 18x9.5 +45 volk TE37SL will clear my BBK?
stlgrym3 is offline   Reply With Quote
Old 06-20-2018, 02:12 PM   #17
Greenbean
yeah you can almost 100% guarantee it. Those wheels influenced by racing will fit bc they take bbk fitment into huge consideration. im about 95% sure it will work but you can always email ft86speedfactory and they normally respond within 24 hours for a sure answer.
The Following User Says Thank You to Greenbean For This Useful Post:
Leonardo (06-20-2018)
Old 06-20-2018, 03:58 PM   #18
wparsons
wparsons's Avatar
There's a bunch of reports of 9" +45 wheels with 245's rubbing either the LCA or inner fender liner. Not every car rubs, but there's a chance it will.
flickr
Old 06-21-2018, 05:44 PM   #19
Greenbean
youre talking about a totally different sized wheel though if you can show me or link me to more people rubbing on a 9.5+45 then ill be satisfied
Old 06-22-2018, 03:02 PM   #20
wparsons
wparsons's Avatar
A 9.5" wheel in the same offset as a 9" wheel will need more room on both the inside and outside of the wheel. Why would a wider wheel magically have more clearance to the body/chassis than a narrower one of the same offset?
flickr
quick question 18x9.5+38 fitment/tire size BlaqkHavok Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 06-18-2018 09:41 AM
Fitment questions before I pull the trigger Jonnyfkncoolguy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-15-2018 08:22 PM
Enkei T6S wheel and tire fitment question chenshuo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-30-2014 09:25 PM
Help about to pull the trigger.... JerryMichaels7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 02-25-2014 06:12 PM
About to pull the trigger on Perrin.... FRSFirestorm Engine, Exhaust, Transmission 143 05-04-2013 01:25 AM
