Old 06-18-2018, 08:00 PM   #1
stlgrym3
Drives: 2017 Subaru BRZ Limited
Wheel and tire size fitment question before I pull the trigger
I’m interested in a set of 18x9.5 +45 with 245/35/18 tires. Will these fit on my BRZ with 1.5” lowered without any issues? Will the alignment specs fall at least close to the factory numbers without any alignment tools?
stlgrym3 is offline   Reply With Quote
Old 06-18-2018, 08:05 PM   #2
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
which wheels, which tires, how did you lower the car?
Old 06-18-2018, 08:20 PM   #3
stlgrym3
Volk TE37SL on mechelin pss tires. Lowered on Apexi coilovers
Old 06-18-2018, 10:40 PM   #4
Anderzz
Anderzz's Avatar
Drives: 2013 Subaru BRZ Premium
Talking completely off the top of my head but I'm around 80% sure you'll have issues in the front with rubbing. If you don't it will be by a hair's breadth.
Sent from my XT1650 using Tapatalk
Anderzz is offline   Reply With Quote
Old 06-19-2018, 07:31 AM   #5
mrg666
pessimistic skeptic
mrg666's Avatar
I would get square 18x8.5 rims with 245 tires for an easier fit.
Old 06-19-2018, 12:13 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
If this is what you want, then you can make them fit. And, depending on alignment and drop you may need a few other suspension parts like LCA, adjustable toe, end links etc. But, with your wheel and tire choices, Budget is probably not a serious issue.
I LIKE TIRES!
Old 06-19-2018, 04:22 PM   #7
wparsons
wparsons's Avatar
It wouldn't fit on stock diameter springs, but I think it'll clear on coilovers. Might rub at full lock on either the LCA or inner fender liner up front though.
flickr
Old 06-19-2018, 06:15 PM   #8
Greenbean
Drives: 2017 series yellow BRZ
i dont think he will rub im running 255/35 and 18x9.5 +38 no rubbing issues and im dropped quite a bit.
Greenbean is offline   Reply With Quote
Old 06-20-2018, 02:02 AM   #9
Anderzz
Anderzz's Avatar
In the front? Either you're cambered wayyy out or you definitely rub fender liner at full lock.
Old 06-20-2018, 02:39 AM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I rub the fender liner with 245/40/17 on 17X9 +38. Also looks it touches the sway bar at full lock a little. I am almost -1.75 dropped over stock with -3 camber.
Old 06-20-2018, 10:25 AM   #11
wparsons
wparsons's Avatar
The potential places it'll rub are inside the wheel well, either the LCA, sway bar or inner fender liner. Your wheels are 7mm further outboard because of the lower offset.
flickr
Old 06-20-2018, 12:09 PM   #12
tyler_win_photo
tyler_win_photo's Avatar
Rear camber will be off without lcas.
tyler_win_photo is offline   Reply With Quote
Old 06-20-2018, 01:48 PM   #13
Greenbean
your also running a 9 inch wheel so a 38 offset on a 9 inch is not the same as a 9.5 +38
The Following 2 Users Say Thank You to Greenbean For This Useful Post:
NoHaveMSG (06-20-2018), wparsons (06-20-2018)
Old 06-20-2018, 01:53 PM   #14
Greenbean
correct but a 245/35 is a very conservative option and i know plenty of people running 45 offset with 245/35 no issues at all. I was originally getting wheels that was 9.5 +45 but wouldnt fit over my brakes. I dont think he will run into any rubbing issues and i would hit the fender liner before him but sway could be in question. if has adjustable swaybar endlinks he can manipulate the sway bar some in his favor.
quick question 18x9.5+38 fitment/tire size BlaqkHavok Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 06-18-2018 09:41 AM
Fitment questions before I pull the trigger Jonnyfkncoolguy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-15-2018 08:22 PM
Enkei T6S wheel and tire fitment question chenshuo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-30-2014 09:25 PM
Help about to pull the trigger.... JerryMichaels7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 02-25-2014 06:12 PM
About to pull the trigger on Perrin.... FRSFirestorm Engine, Exhaust, Transmission 143 05-04-2013 01:25 AM
