Old 03-30-2018, 04:16 AM   #323
FunnyGopher
Drives: 2015 BRZ Limited
Originally Posted by Submarinesonce View Post
its interesting to compare our runs after DA correcting them. I did some calculations. DA corrected you ran a 14.273@99.538 compared to my 14.327 @ 96.194 ...that Ace header makes some impressive top end power. I might have had you at 1/8th mile, then you pull away to win by .054 and about half a car (7' 7") but 3 mph faster means youll keep on pulling.
Forgive my ignorance, I'm not completely familiar with thinking about times and such with DA, although I understand how the density of the air can play a role in how fast the car moves. When you say DA corrected, what exactly is it corrected to? 1000ft? 0ft? This is all very new to me.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
Old 04-29-2018, 02:29 PM   #324
shawnmcgettigan
Drives: 2014 Scion FR-S
I just did some track testing myself. One run on the factory tune and another on a custom tune. I have full exhaust (no cats), throttle body spacer, silicone intake tubing and intake manifold spacers. stock tires. Just for additional info, when we were done dyno tuning we took the air filter out and made a run with no measurable gains. All tuning and track runs were made in Florida (close to sea level) at about 85 degrees. I made about 8 runs each trip and backed up each of these times with similar times.
shawnmcgettigan is offline   Reply With Quote
Old 06-16-2018, 04:08 PM   #325
86TOYO2k17
Drives: 2017 toyota 86
This is using the gps device dragy, I have compared it to video runs and it seems to be consistently .1-.2 seconds slower (delayed). All in all seems pretty accurate.
57 degrees, 92octane, no weight reduction with a 2500rpm launch with an auto.
First 1/8th was flat, second 1/8th was slight incline.
ET on 1/8th 74.98 and ET 1/4th 92.89, 60ft 2.35seconds (I’ve heard/seen dragy is really accurate but not for 60ft times)
Grimmspeed intake, BPB, ace 250, header back, 4th e-tune revision, 4.556 fd swap. auto shifts to 3rd at about 54, and 4th at about 83, so not “optimized” for 0-60 / 1/4mile. But still .3 sec faster in both vs 4.1 fd which didn’t require that extra shift.
Old 06-17-2018, 07:01 AM   #326
Lantanafrs2
Drives: 2013 frs red
14s in a n.a. auto ain't bad.
Lantanafrs2 is online now   Reply With Quote
Old 06-17-2018, 06:04 PM   #327
86TOYO2k17
Thanks! I think with 93octane or especially E85, less gas in tank and colder weather. I could run sub 14.5s.
The 2500rpm launches vs 4500 in manual slows the 0-60/1/4 mile down almost a second from what I’ve seen stock vs stock comparisons. But on a roll I bet I’m just as fast if not faster then most bolt on MTs.
Old 06-17-2018, 07:15 PM   #328
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
How much are you betting?
Old 06-17-2018, 07:39 PM   #329
86TOYO2k17
A nice dinner date.
I’d love to see full bolt on MT (no E85) 0-60/1/4th without a launch.
Or even a verified 60-100 time.
I know stock MT typically 6.8-7.2 depending on 91-93 and weather, Auto is 7.8-8.2 same factors. Under perfect ideal scenario I’ve seen 6.4 vs 7.4, however from a 5 roll I’ve seen MT was only .2 faster then auto. Which leads me to believe .8seconds is from the launch .2 from gearing, with auto FD swap gearing isn’t a factor and might even now be in my favor. . So .8 sec faster from launch alone.
Old 06-19-2018, 08:20 AM   #330
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
14 second quarters, in a relatively torqueless 2.0 four popper , ain't bad at all. That's smack-in-the-middle of late 80's pony car territory, which again is also right in the middle of 1960's muscle car era territory. What once was considered such good performance that they actually wrote songs about it, is now considered below average. Funny how growing up with nothing but late model cars can skew perspective.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 06-19-2018, 12:21 PM   #331
Lantanafrs2
Funny how my frs with 1000$ of mods is "slow" yet would pull on my 68 lemans all day long and get twice the mileage.
Old 10-07-2018, 11:06 AM   #332
Colin86
Drives: 86
More of a road course guy but the drag strip is fun every now and again. First time I took my FRS out last year the track was rained out and I was only able to make one pass where I spun all the way down the track, ended up running a high 15 or something silly so I didn't post it.
Went again a week or so ago and go rained out again but had slightly better luck, was able to run a 3-4 passes. Car still has a lot left in it just because I have a lot to learn on launching the car without excessive wheel spin. Shame I wasn't able to make more passes as I'm confident I could have hit a 12 with some more practice.
Best ET
13.2 @107mph
Best Trap
13.6 @109
Car setup:
6spd FRS
Edelbrock w/ stock pulley
DW300c fuel pump and DW 700cc injectors
Delicious D box, flex fuel kit, and Edelbrock tune
Gruppe-S UEL header and over pipe (both coated)
HKS LegaMax
E85
Stock clutch
327whp 243wtq
215/45/17 MPSS on stock wheels aired down in the rear to 28psi (lol not exactly drag tires)
Colin86 is offline   Reply With Quote
Old 10-28-2018, 09:49 AM   #333
86TOYO2k17
NA / AUTO / 92octane / 3/4th tank gas/ 2k rpm launch with tires completely cold (idled in garage 8mins, drove 2miles, sat at longest stop light of my life then tested car was warm but not tires) so they where just spinning for a sec before hooking. Hard to find time/place to do more testing with my new work schedule.
With warm tires I can launch and hook right away at 2400rpm, I’ve had quicker 60ft and 0-20mph times and done a bit of mods since hence overall faster times. So fastest 1/4 and trap so far. Need to retest with 1/4tank and better launch without spinning. Thinking I can hit 6.5sec flat 0-60 and 14.7 flat in the 94mph range if i do that.
Old 11-07-2018, 09:56 PM   #334
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Went and made two passes at the last test n tune of the season. It was quite cold...
Ran on melted spark plugs wires, and way too little of tire, but it was fun. Spun for the first 100ft, backpedaled but couldn't get the grip back. Now to get a tune, and tires, and return in the spring.
Ran 12.53 at 116mph, with traction and a proper tune, I should probably see 11.90's in the spring.
[ame]https://www.youtube.com/watch?v=tjI8qz9f9Ks[/ame]
spitsnaugle is offline   Reply With Quote
Old 11-12-2018, 09:36 AM   #335
chazmuska
chazmuska's Avatar
Ran on melted spark plugs, and way too little of tire, but it was fun. Spun for the first 100ft, backpedaled but couldn't get the grip back. Now to get a tune, and tires, and return in the spring.
Nice Pass man! I bet you fool a lot of cars of the street light! lol
chazmuska is offline   Reply With Quote
Old 11-18-2018, 12:07 AM   #336
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Grab a bottle of Boostane off of Amazon if you need a bump in octane.
Trueweltall is offline   Reply With Quote
Scion's free 2 year/25K mile maintenance plan? whtchocla7e Scion FR-S / Toyota 86 GT86 General Forum 25 06-06-2012 03:26 PM
La Times reviews BRZ Sport-Tech BRZ First-Gen (2012+) — General Topics 7 05-18-2012 11:11 AM
He lives his life 1 quarter mile at a time ucla bruin Other Vehicles & General Automotive Discussions 8 12-21-2011 07:04 PM
$95 Track day at Willow Springs- Horse Thief Mile-Oct 16th Louie Southern California 1 10-11-2011 12:31 AM
$85 Track day at Willow Springs- Horse Thief Mile - April 2-3rd in SoCal Louie Southern California 2 03-20-2011 05:17 AM
