Old 08-21-2017, 07:04 PM   #309
PR138
PR138's Avatar
Drives: '14 WRB BRZ | '17 CB STi
Originally Posted by FRS Justin View Post
any new times?????
I wish, I've been waiting for someone to post a e85/JRSC equipped car's time forever and nothing
PR138
IG: @pr.138
2008 LBP Honda S2000
2013 UM Scion FR-S
PR138 is offline   Reply With Quote
Old 03-19-2018, 02:20 PM   #310
JoeeStacks
Drives: Brz
Ran Sacramento raceway yesterday. First run hit traction control and cut power to the wheels, hitting a 14.5. Then I ran a 14.158 with with traction off and sport mode, this is with a let off before the end (14.2 dial in). This is with the kraftwerks c30 Carb tune.
I think it could easily run a high 13 with the right conditions, but we didn’t get a second chance to practice before we dialed in a time. So I didn’t know what it would put down without traction control. My friends are doing test n tunes next month and it should be in the 13s then.
Mods:
Kraftwerks c30 CARB tune
Perrin 2.5 catback
Gram light 57dr 17x9
Almost used up hankook v12
Daily Project: Honda s2000
Track: 707 WHP Turbo Honda Civic EG
Old: Kraftwerks Supercharged Subaru Brz
JoeeStacks is offline   Reply With Quote
Old 03-19-2018, 02:36 PM   #311
PR138
PR138's Avatar
Mods:
Perrin 2.5 catback
Yikes at that 60 foot difference. If you could cut that down to the same 2.1 as the first run, you'd be in the lower 13s.
PR138
IG: @pr.138
2013 UM Scion FR-S
Old 03-19-2018, 10:14 PM   #312
JoeeStacks
Drives: Brz
Hopefully, I'll get a new run without traction control limiting the power.
What is considered a good 60' time? I don't expect good times with stock struts and Eibach lowering springs. I also didn't wanna launch hard and break something.
Old 03-19-2018, 10:35 PM   #313
PR138
PR138's Avatar
I haven't run mine yet, but looking through the stockish times on this thread and I'd say a 2.0-2.1 would be attainable with a good launch. If you have stickier tires than stock maybe even a bit better.
Knocking half a second off the launch would equate to much more than that by the end of the quarter.
PR138
IG: @pr.138
2013 UM Scion FR-S
Old 03-24-2018, 05:35 PM   #314
FunnyGopher
Drives: 2015 BRZ Limited
Took mine to the strip for the second time, and ran the best I've ever done!
Mods:
- Skunk2 Powerbox CAI
- Grams 72mm Throttle Body
- Delicious Tuning Flex Fuel Kit
- ACE Type-A 350 Header + OP
- CSG Touring 86 Catback
- Stock wheels and tires!
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
Old 03-27-2018, 11:20 AM   #315
ermax
ermax's Avatar
Mods:
My 1995 Integra GS-R with 175K miles ran a time very similar to this.
1/4mi 14.267secs @ 96.570MPH
1/8mi 9.211 @ 77.980MPH
60ft 2.223secs
That was on Bridgestone RE730s back in 2004. Mostly stock car. Type-R A-pipe to tip. Type-R pistons. Koni Yellows with Ground Control coilovers with ERS 500lbs/in F, 500lbs/in R. Type-R rear ARB. Lightened OEM flywheel down to 13lbs. HomeDepot special dryer hose into the wheel well CIA. I loved pissing guys off at the track with that car. Hahaha
Long story short, seems like your car would be faster than this with those mods.
Old 03-27-2018, 01:03 PM   #316
Submarinesonce
Drives: Frs
60ft 2.223secs
that trap and ET are odd...Do you happen to know what your DA was that night? for reference, I ran :
2.191 60'
6.149 330'
9.395 @ 76.81 1/8
12.169 1000'
14.521 @ 94.8 1/4
at a DA of 1260ft. spare/jack/baby seat still in the car and all tires at normal pressure.
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
Old 03-27-2018, 07:37 PM   #317
ermax
ermax's Avatar
2.191 60'
6.149 330'
9.395 @ 76.81 1/8
12.169 1000'
14.521 @ 94.8 1/4
Not sure exactly. It was in the winter if I recall and it was in Gainesville, FL so basically at sea level. I did this run with all the mats removed, spare tire jack and rear seat back. The GSR was a 5 speed and didn’t have super short gears. 3rd ran out around 93mph and once you shifted to 4th it didn’t pull that fast so the trap isn’t all that high.
I coordinated with a friend of mine and plan to go to the strip on April 21st with my FRS for the first time. It will be interesting to get a base run out of it.
Old 03-28-2018, 12:41 AM   #318
FunnyGopher
Yeah, I definitely think I can be faster with more practice. That time was ran on my 9th? time down the track. I definitely improved my launching that night though. I'll go again after I put some wider wheels and better tires on the car.
Old 03-28-2018, 09:26 AM   #319
Submarinesonce
Drives: Frs
oops, quoted the wrong post, I meant to ask funnygopher what his DA was
Old 03-28-2018, 09:52 AM   #320
ermax
ermax's Avatar
If I recall from my years of frequent trips to the drag strip to unnecessarily abuse my daily driver, lots of wheel spin would typically translate to a bad ET but high trap speed. He had a higher 60ft so maybe he had more wheel spin which impacted his trap speed.
Old 03-29-2018, 03:42 AM   #321
FunnyGopher
After doing some googling for temperature, pressure, etc. for the area that night, the DA came out to 2072 feet.
Old 03-29-2018, 08:12 AM   #322
Submarinesonce
Drives: Frs
its interesting to compare our runs after DA correcting them. I did some calculations. DA corrected you ran a 14.273@99.538 compared to my 14.327 @ 96.194 ...that Ace header makes some impressive top end power. I might have had you at 1/8th mile, then you pull away to win by .054 and about half a car (7' 7") but 3 mph faster means youll keep on pulling.
Scion's free 2 year/25K mile maintenance plan? whtchocla7e Scion FR-S / Toyota 86 GT86 General Forum 25 06-06-2012 03:26 PM
La Times reviews BRZ Sport-Tech BRZ First-Gen (2012+) — General Topics 7 05-18-2012 11:11 AM
He lives his life 1 quarter mile at a time ucla bruin Other Vehicles & General Automotive Discussions 8 12-21-2011 07:04 PM
$95 Track day at Willow Springs- Horse Thief Mile-Oct 16th Louie Southern California 1 10-11-2011 12:31 AM
$85 Track day at Willow Springs- Horse Thief Mile - April 2-3rd in SoCal Louie Southern California 2 03-20-2011 05:17 AM
