Old 05-28-2018, 04:57 PM   #1
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
2qt Accusump, -10 AN line, fittings, bracket, remote operating cable
Are you fast? Like, sustained 1.7g in a long sweeper fast? Massive aero and Hoosiers fast? Concerned about uncovering the pickup and losing oil pressure while bending physics in the twisties fast? Then have i got a deal for you!
I am not that fast. I am maxxis rc1, drives HPDEs for fun and still has a deskjob fast. But I like tinkering on the car for a hobby as much as I like driving, and thus pieced together this accusump setup. I drew up, cut bent and welded the bracket you see here. Its not art quality metal fab, its totally functional spirit of original racecar guy quality. Someday I might be fast enough to need this, but not today Selling it to pick up other fun car parts to tinker with...probably pick up an Aim solo2 dl if they ever come out...collect data...use it to get faster.
Asking $200 shipped UPS in the USA. The accusump is 100 %functional, clean and leak free. The bracket is rattle can black and could use a touch up. This includes all the hardware and fittings you need to hook it up. Route the actuation cable into the cab, mount as you'd like, and dazzle passengers at your next HPDE who'll ask what it does. I usually answerd "james bond smoke screen" I put up pictures of it installed with the A.C. compressor in place as well - it totally fits!
Any questions, requests for more pics etc, pm or Email me.
Thanks!
Joe V
Joesurf79 is offline   Reply With Quote
Old 05-30-2018, 01:12 PM   #2
Joesurf79
Joesurf79's Avatar
I'd also be interested in trades possibly. For a light weight exhaust system (stainless) or an aluminum 1 piece driveshaft. Or IRP shifter in good shape.
Old 06-01-2018, 10:24 AM   #3
Joesurf79
Joesurf79's Avatar
Bump for $425 shipped. Because Racecar!
Old 06-04-2018, 10:22 AM   #4
Joesurf79
Joesurf79's Avatar
Lots of Views, no PMs yet. Send me questions, offers - any interest out there?
Old 06-06-2018, 06:25 PM   #5
Joesurf79
Joesurf79's Avatar
Buy the cool race car parts. You know you want to. Do itttttt...
Old 06-08-2018, 11:06 PM   #6
Joesurf79
Joesurf79's Avatar
Yummy engine saving oil provided under pressure on demand....
Old 06-12-2018, 06:25 PM   #7
Joesurf79
Joesurf79's Avatar
How about $400 for every thing? Bump bump
Old 06-15-2018, 09:41 AM   #8
Joesurf79
Joesurf79's Avatar
Bump
Old 06-15-2018, 12:01 PM   #9
ermax
ermax's Avatar
Just curious, what sort of oil pressures are you getting with this setup?
Old 06-16-2018, 10:13 PM   #10
Joesurf79
Joesurf79's Avatar
So the way the system works is that the accumulator is plumbed into the oil gallery, and is open to the same oil pressure the pump is producing, full time. There is an adjustable air spring on one side of the piston, and engine oil on the other.
This means that there's an additional 2 qts (ish) under the last pressure that the pump put out, waiting to discharge, sitting in the accumulator.
If your oil pressure drops below the compressed air spring pressure, it automatically pushes the oil it has under pressure into the oil gallery. So if you uncover the pickup in the pan, as oil pressure drops from the pump - the accusump makes up the oil pressure to the mains. So that hopefully by the time it's fully discharged, you're out of the high g corner and the pickup is covered again.
Doesn't really add pressure in addition to the pump, but keeps you from running out of oil pressure for a while.
The Following User Says Thank You to Joesurf79 For This Useful Post:
whataboutbob (06-25-2018)
Old 06-20-2018, 08:27 AM   #11
Joesurf79
Joesurf79's Avatar
$375 shipped bump!
Old 06-25-2018, 08:53 PM   #12
Joesurf79
Joesurf79's Avatar
Bump for racecar parts - USA made racecar parts !
Old 06-28-2018, 08:20 AM   #13
Joesurf79
Joesurf79's Avatar
Anodized blue parts parts make your lap times drop. Unless you're me - but it will totally work for you! Buy them and see!
Old 06-30-2018, 10:50 AM   #14
Joesurf79
Joesurf79's Avatar
Yoda says :"buy joes parts you should, faster, you will be." Or something like that
Chimera (05-09-2019)
Replacing oil cooler line fittings? 1Cor10:23 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 09-17-2015 01:43 AM
FS - Unchip + Download Cable + Fuse Box mounting bracket FRSGeek Engine, Exhaust, Bolt-Ons 4 04-14-2014 06:51 PM
SOLD: like new Unichip + Download cable + Mounting Bracket yamsta Engine, Exhaust, Bolt-Ons 3 11-18-2013 11:36 AM
FS - Unchip + Download Cable + Fuse Box mounting bracket enwave Engine, Exhaust, Bolt-Ons 4 11-06-2013 10:04 PM
Unichip w/ Bracket, Cable, Software & Instructions Cross Engine, Exhaust, Bolt-Ons 1 09-18-2013 03:55 PM
