Old 06-16-2018, 04:19 PM   #45571
Originally Posted by krayzie View Post
Made in China is probably the weakest link here.
Ultramaroon is offline
krayzie (06-16-2018), Spuds (06-16-2018)
Old 06-16-2018, 04:41 PM   #45572
My luck will have it
Just FYI that’s not a stock wheel stud. That’s ARP stud. It seized on Muteki nut.
Well, now, that's too bad ……
How did you do that ..??
* impact wrench?
* @Ultramaroon 's 24" breaker bar?
* you forgot - rightsy tightsy; lefty loosey?
* other?
humfrz is offline
ichitaka05 (06-16-2018)
Old 06-16-2018, 05:06 PM   #45573
Teseo
Drives: frs
Yeah it’s front, but I think other 19 studs are seized as well, so I gotta replace all of em FML
Try tu put a pea size antiseize grease
Teseo is offline
Old 06-16-2018, 06:08 PM   #45574
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
No, that's bad for lugnuts. You want them to stay put under all sorts of vibrations and forces. Antiseize will change the frictional forces that keep the lugnuts in place. It also changes the ratio between axial force and tangent force, which can damage threads and wheels if you torque it to spec. If you don't torque to spec (or reasonably close) other bad things can happen.
TLDR:. Don't use antiseize on threaded parts with a torque specification.
Spuds is offline
The Following User Says Thank You to Spuds For This Useful Post:
cjd (06-16-2018)
Old 06-16-2018, 06:09 PM   #45575
NOW, you tell him!
humfrz is offline
Old 06-16-2018, 06:14 PM   #45576
So true!
If you use anti-seize on lug nuts, when tightening them, you can't hear them squeak. Remember, two squeaks and a grunt is "lug nut tight".
Bubba
humfrz is offline
Spuds (06-16-2018)
Old 06-16-2018, 06:34 PM   #45577
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
* impact wrench?
* other?
No, no impact gun. Simple 24” breaker bar to loosen the lugnuts THEN use electric impact gun to screw out the lugnuts. I was trying to loosen the lugnuts (& yes I know righty tighty, lefty loosy) and next thing I know, it SNAPPED!
& FYI I’ve snapped 2 more. Right now, I’m scared to loosen rear ones, cuz if this keeps up, I will snap all other ones.
Just a pure curiosity...
I’ve heard both side of the story. I usually put lil bit on mine, but when I put new lugnuts, I didn’t, result, I’ve snapped lugnuts... even strong ARP ones. How do you make it not seize the studs & lugnuts without anti-seize.
ichitaka05 is offline
Old 06-16-2018, 06:56 PM   #45578
Ryan GT86
Ryan GT86's Avatar
Drives: 2019 Toyota 86
So it turns out one of my closest friends from high school is gonna put Lamborghini-style doors on his Toyota 86. I think I'm going to have to schedule an intervention. He keeps insisting "It looks way better in person! Trust me!"
Ryan GT86 is offline
Old 06-16-2018, 07:11 PM   #45579
cjd
cjd's Avatar
Drives: 2017 BRZ
How does one shear studs like that?! I have wheels on and off far to often and nothing... Though I'm always prepared with replacements and tools for the job...
Sucks! Kinda like this weather. This is late July/early August weather.
cjd is offline
Old 06-16-2018, 07:25 PM   #45580
Welp, since your recent discovery, I'd suggest you take your car up to a local tire shop and ask them to replace all the studs on your wheels.
As far as the use of anti-seize, I've been tightening nuts on wheels for going on 70 years …. and NEVER used any anti-seize compound nor have I used a torque wrench to tighten up the lug nuts. I've never busted off a wheel stud nor have I ever had a wheel come loose.
My secret, two squeaks and a grunt (over the age of 70, maybe two grunts), using a tool such as this.
PS - Always be sure that your lug nut wrench is lined up straight with the stud ….. like, NO jumping on it ….
humfrz is offline
Old 06-16-2018, 07:42 PM   #45581
ichitaka05
Site Moderator
ichitaka05's Avatar
Same here, I’ve never busted a wheel stud til today. Specially I didn’t expect ARP stud to bust off. As for tighting the lugnuts I’ve always tighten em w tq wrench to make sure it tq to the spec & never over tighten them.
Also to add, I’m not frustrated at ARP, cuz they make great parts... I’m just frustrated at the timing. I just wanted to replace my brake pads, but now, I’ll be doing more work. I’ll be picking up more ARP studs & lugnuts today. I’m wondering new lugnuts caused this... or maybe I’m overthinking? I used to have Kics lugnuts and they were working nicely, but when I replace it w Muteki this happened. Either way I’ll be picking up different brand & I’m thinking Gorilla. They have forged steel, so it should be strong for daily instead of chrome Vanadium... so I hope
Old 06-16-2018, 08:03 PM   #45582
Replace with OEM lugs and nuts. Done. I've had mine off countless times. Like new.
humfrz (06-16-2018), krayzie (06-16-2018), Spuds (06-16-2018)
Old 06-16-2018, 08:04 PM   #45583
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I've used OEM and McGard all my life and no issues. Then again I don't track.
krayzie is offline
The Following User Says Thank You to krayzie For This Useful Post:
Ultramaroon (06-16-2018)
Old 06-16-2018, 08:19 PM   #45584
Doesn't matter.
