Old 08-25-2017, 10:19 PM   #1
Blorb
Drives: GBS BRZ
2017 Upgraded Leather Interior Part Numbers
I recently ordered the 2017 one piece leather dashboard panel for my 2013 BRZ, and had to have everything else match. It was slightly difficult to find all the part numbers, of course the first time I ordered I got all the parts with yellow stitching instead of red (goodbye restocking fee). You also have to be careful to get the correct smooth textured panels that are only available in 2017 or later models.
!!!! WARNING !!!!: These are SMOOTH textured leather padded panels, the earlier years either came with hard plastic or ROUGH textured padded leather.
!!!! WARNING !!!!: The dash piece only fits certain years (the early year models with sat nav for example). Read more about if the piece will fit your car in this thread http://www.ft86club.com/forums/showthread.php?t=110948
I think the rest of the panels will fit any car.
Here's the list:
66077CA200 Center Panel Assembly http://parts.subaru.com/p/__Limited-...6077CA200.html
66068CA120 Center Console Knee Pad Right http://parts.subaru.com/p/__Limited-...6068CA120.html
66068CA130 Center Console Knee Pad Left http://parts.subaru.com/p/__Limited-...6068CA130.html
94267CA180VH Lower Arm Rest Right http://parts.subaru.com/p/__Limited-...67CA180VH.html
94267CA190VH Lower Arm Rest Left http://parts.subaru.com/p/__Limited-...67CA190VH.html
94243CA160VH Upper Arm Rest Right http://parts.subaru.com/p/__Limited-...43CA160VH.html
94243CA170VH Upper Arm Rest Left http://parts.subaru.com/p/__Limited-...43CA170VH.html
94245CA080 Speaker Grill Ring Right http://parts.subaru.com/p/__Limited-...4245CA080.html
94245CA090 Speaker Grill Ring Left http://parts.subaru.com/p/__Limited-...4245CA090.html
94245CA001VH Speaker Grill Right http://parts.subaru.com/p/__Limited-...45CA001VH.html
94245CA011VH Speaker Grill Left http://parts.subaru.com/p/__Limited-...45CA011VH.html
904500024 Tapping Screw for Speaker Grill (I needed 4, some people needed 8?) http://parts.subaru.com/p/__Limited-...904500024.html
94257CA160VH Door Speaker Knee Pad Right http://parts.subaru.com/p/__Limited-...57CA160VH.html
94257CA170VH Door Speaker Knee Pad Left http://parts.subaru.com/p/__Limited-...57CA170VH.html
66180CA240 Gauge Cluster Hood http://parts.subaru.com/p/__Limited-...6180CA240.html
( I didn't actually order this, but thanks @fx1mark for posting it here http://www.ft86club.com/forums/showp...&postcount=309 )
Total cost: around $700. I ordered from Subaru Online Parts because they almost always have a 5% discount code floating around.
Be aware, I had some issues with the glue coming apart on a couple of parts, apparently this is common and you need to glue things back down as necessary.
Thanks to @Trojan_SC for the install guide thread here http://www.ft86club.com/forums/showthread.php?t=13583 and @Summerwolf for posting the Dash panel part number in the big thread.
Blorb is offline   Reply With Quote
The Following 3 Users Say Thank You to Blorb For This Useful Post:
Bonburner (05-17-2023), jorgerendonjr (09-19-2017), TofuJoe (10-26-2017)
Old 09-19-2017, 03:30 AM   #2
jorgerendonjr
Drives: Frs
What adhesive did you use to glue thinga back together?
jorgerendonjr is offline   Reply With Quote
Old 09-19-2017, 01:41 PM   #3
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
I used contact cement. that's what upholsterers use and what I am sure was originally used.
fx1mark is offline   Reply With Quote
Old 09-22-2017, 02:30 PM   #4
Blorb
Drives: GBS BRZ
I used small dabs of superglue because I was gluing back edges where you can't see after installation and I was too lazy to get the right stuff.
I imagine if you used super glue on a visible area it would look bad (indented?) and be unforgiving if you screw up, get some proper contact cement for that.
Old 06-14-2018, 11:02 AM   #5
Gyzm0
Gyzm0's Avatar
Drives: 2013 Toyota GT86
Hello @Blorb,
sorry to dig up this.
Are you aware of any Rough textured OEM gauge cluster hood?
I've seen the 2018 86 and BRZ, but it seems they're either alcantara or smooth texture. There's JPM but they're gone now.
I'd like the texture to match the 2013 GT86 as I recently had the matching OEM armrest. But I can't seem to find any.
Thanks in advance.
Gyzm0 is offline   Reply With Quote
Old 06-14-2018, 12:52 PM   #6
fx1mark
fx1mark's Avatar
Originally Posted by Gyzm0 View Post
Hello @Blorb,
Thanks in advance.
which Armrest? mine matches.
Old 06-14-2018, 01:12 PM   #7
Gyzm0
Gyzm0's Avatar
Thanks @fx1mark, which cluster hood is that?
It shouldn't match the one piece center dash then, as I've seen the smooth texture on the center dash doesn't match the rough texture on the doors inserts.
Edit: I mean the old models door inserts, as the new models should have matching everything
Old 06-14-2018, 05:41 PM   #8
norcalpb
norcalpb's Avatar
I don’t think the 16 and below twins came with a textured cluster with red stitching.
You should check out Sweidit or Redlinegoods, sweidit wraps your stock piece for you but redlinegoods you’ll have to install yourself or pay someone to do it ~$75usd.
Old 06-14-2018, 05:47 PM   #9
Gyzm0
Gyzm0's Avatar
I know the 16 and below don't have any textured stitching.
I'm aware of JPM Coachworks and Redline Goods offers, but I would prefer a OEM solution if available, as I believe the newer models cluster hood fit the older models.
Edit: so far I've seen red and grey stitching Alcantara and red stitching smooth leather.
Old 06-14-2018, 06:05 PM   #10
norcalpb
norcalpb's Avatar
13-16 = old texture
17- = new texture
So it seems like you know you’re SOL and need to go custom to get the exact look you want.
The Following User Says Thank You to norcalpb For This Useful Post:
Gyzm0 (06-14-2018)
Old 09-02-2019, 10:53 AM   #11
RickyBobby
Drives: 2013 Firestorm FR-S AT
I'm interested in purchasing the one piece leather dashboard panel. FT86Speed Factory is selling it for $160.57 +$11.35 ground shipping. http://www.ft86speedfactory.com/suba...l#.XW0ZzChKiUm
That price is more than a bit much. They state it fits the 2013+ FR-S /BRZ /86. They are selling part #66077CA200 which has been discontinued and replaced with part #66077CA201.
I found this Subaru dealership in Houston, TX that is selling part #66077CA201 for $109.85 + $8.93 shipping. https://www.subarupartsource.com/oem...-ay-66077ca201
Does anyone know what, if any, difference there is between CA200 and CA201?
I emailed the dealership the same question.
RickyBobby is offline   Reply With Quote
The Following User Says Thank You to RickyBobby For This Useful Post:
RToyo86 (09-02-2019)
Old 09-02-2019, 11:00 AM   #12
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
There’s no real difference, the 201 is the new part number that supersedes 200. Form/fit/function is the same.
Old 09-02-2019, 11:32 AM   #13
RickyBobby
And you know this how? Just want to make sure they are the same before ordering.
Old 09-02-2019, 01:17 PM   #14
Yoshoobaroo
TRACKBREAD
You said it yourself, it’s been discontinued and replaced by 201. If the new part wasn’t backwards compatible they wouldn’t show it as superseded with the new part on Subaru’s website.
Also look here, 201 part number: https://www.rallysportdirect.com/par...-red-stitching
dash panel, knee pads, leather
2017 BRZ Performance Package Brembo Brakes Part Numbers Veloist Suspension | Chassis | Brakes -- Sponsored by 949 Racing 146 04-27-2023 10:36 AM
Part numbers or part diagram? pacemkr Engine, Exhaust, Transmission 6 08-22-2016 02:44 PM
OEM part numbers nikitopo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-29-2014 01:59 PM
Part Numbers tommy Scion FR-S / Toyota 86 GT86 General Forum 3 12-31-2013 05:33 PM
ANyone know these part numbers? J-Money Scion FR-S / Toyota 86 GT86 General Forum 3 04-22-2013 01:37 PM
