Old 06-12-2018, 05:53 PM   #1
Impureclient
Drives: 2015 FR-S
5mm spacer that is 5.25"/133mm OD?
Anybody here have a 5mm spacer or know where to find one that is 5.25"/133mm outside diameter to match the rotor in the front.
All I am seeing is 6" ones and you can see it sticking out the sides behind the wheel. The bolt on ones are the 5.25" but I can't seem
to find a 5mm the same and in black if possible. Searching in here or anywhere comes up with nothing about the OD of these things.
Old 06-13-2018, 09:21 PM   #2
Impureclient
Drives: 2015 FR-S
Found it: https://propartsusa.com/products/H-R...BoCoIMQAvD_BwE H&R 1025560SW
I must have sent 20 emails to different vendors, all 150mm. With this car being 5 years old, you'd think this would have come up at least once in here.
Maybe everybody just got lucky with 5mm spacers that happened to fit or maybe they were just fine with them sticking out all goofy in the front.
Either way, now it's here for others so they don't pull out hair finding one for the front that fits properly.
The Following 2 Users Say Thank You to Impureclient For This Useful Post:
Leonardo (06-13-2018), sato (06-14-2018)
17" SUBARU BBS | KICS SPACER SonnyBRZ Wheels and Tires 4 08-29-2015 11:08 PM
SOLD! FS: 3/4" PVC Speaker Spacer/Adapter Formula Vee Audio/Visual, Electronics, Infotainment, NAV 3 11-16-2014 02:05 AM
Sprint Kit + RPF1 17x9+35 To spacer or not to spacer? Khorne Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-03-2014 12:53 PM
License Plate "spacer" mount Help? Lord Peth Cosmetic Modification (Interior/Exterior/Lighting) 6 03-29-2014 06:41 PM
25mm conversion spacer with 5mm spacer = safe or unsafe? deedz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2013 11:59 AM
