Old 06-13-2018, 03:53 PM   #1
Brink
Drives: 2017 BRZ
AT manual mode
Is it possible (and safe for the transmission) to switch an AT from D to manual mode (or from manual back to D) while the car is moving? Is there a speed limit for doing this? So far I've only been shifting in and out of manual while stopped, but I'd like to be able to do it at any time just don't want to break the transmission doing it at the wrong time. I don't see anything in the owners manual specifying this.
Brink is offline   Reply With Quote
Old 06-13-2018, 04:00 PM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
It doesn't effect anything switching from D to manual mode or vice versa on the move. Also if you want, you are able to use the paddles while in D it's just slower and only really useful as like a pseudo kickdown switch if you want to wake up the transmission on a highway to prepare for a pass or to engine brake and make loud noises when you have an exhaust
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Brink (06-13-2018)
Old 06-13-2018, 04:22 PM   #3
Brink
Drives: 2017 BRZ
Thanks. I knew about using the paddles in D, I do tend to use them a bit. Good to know I can go in and out of manual mode any time.
Old 06-13-2018, 04:41 PM   #4
https://www.buddssubaru.com/assets/b...ner-Manual.pdf
Old 06-13-2018, 04:50 PM   #5
Jordanwolf
Rice King
Jordanwolf's Avatar
You might blow your blinker fluid thus resulting in a totaled car. Don't shift and drive.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
The Following User Says Thank You to Jordanwolf For This Useful Post:
DaBoBo21 (06-14-2018)
Old 06-13-2018, 04:52 PM   #6
spike021
spike021's Avatar
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 06-13-2018, 05:03 PM   #7
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Sport mode just changes the shift points. It makes NO physical, mechanical changes to the vehicle. It isn't like engaging 4LO where you have to be stopped because you are mechanically locking things. Toggling sport mode is like toggling your computer from battery saver mode to high performance mode.
Even if it did, your car wouldn't let you do it when it wasn't safe to do so. Just as vehicles don't allow you to engage 4LO until you are stopped, and the transmission is placed in neutral.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 06-13-2018, 05:44 PM   #8
FRSBRZGT86FAN
He was referring to manual mode not sport mode, sport mode does nothing in manual mode
Old 06-13-2018, 06:49 PM   #9
Stang70Fastback
A.K.A. Starlord
Well, the same thing applies for manual mode.
The Following User Says Thank You to Stang70Fastback For This Useful Post:
FRSBRZGT86FAN (06-14-2018)
Old 06-13-2018, 07:05 PM   #10
Grady
Grady's Avatar
Just make sure you are above 30 before you go to Race Mode. its the R on the shift lever.
Question about A/T using it in Manual mode Oburn Engine, Exhaust, Transmission 46 07-07-2022 06:40 PM
Manual mode issue. Please help jsonx9000 Engine, Exhaust, Transmission 3 06-01-2018 01:28 AM
More MPG in manual mode (AT) aceangel BRZ First-Gen (2012+) — General Topics 11 03-27-2013 02:12 PM
AT Manual Mode Easter Egg? whataboutbob Engine, Exhaust, Transmission 2 12-14-2012 12:03 PM
AT Manual Mode Downshifting Reprobate Scion FR-S / Toyota 86 GT86 General Forum 2 07-23-2012 12:40 PM
