Old 07-11-2012, 09:46 PM   #337
slow_frs
Drives: turbo scion tc
Originally Posted by cruzinbill View Post
pretty sure toyota has never ran a cat before a turbo.... seems it would reduce overall flow to the turbo as well, at least to me.
Goodness gracious.... Obviously with a probperly sized turbine the loss of exhaust flow( which is minimal) will be compensated for...
slow_frs is offline   Reply With Quote
Old 07-11-2012, 09:56 PM   #338
cruzinbill
Drives: Argento 6spd FR-S
Not with theirs, I meant with oem I dont understand why they would do it post cat. I understand the multiple reasons why this one is. You would just think in designing an FI engine that maximum flow for both spool and performance would be a primary goal.
cruzinbill is offline   Reply With Quote
Old 07-11-2012, 10:05 PM   #339
Don@Accelerated
Don@Accelerated's Avatar
Pretty sure anymore #1 goal IS the mighty MPG's and emissions!
Don@Accelerated is offline   Reply With Quote
Old 07-11-2012, 10:10 PM   #340
slow_frs
Smaller a/r exhaust housing = faster spool, properly sized wheel= maximum flow. Yes it will rob a few ponies due to higher egt but the engine will prob Mac out before the setup does
Old 07-11-2012, 10:11 PM   #341
slaxx
Drives: '13BRZl, '14FiestaST2, '10Insight2
Looks great!
I can imagine a top-mount IC rear entry, front exit, with cold air intake under an STI-esque hood scoop.
Good luck with the test runs *fingers crossed*
slaxx is offline   Reply With Quote
Old 07-11-2012, 10:26 PM   #342
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I wonder what overlap the cams run with the variable cams. This will help in designing the right turbine and AR size when you know what overlap you are dealing with.
Low overlap and a small AR will be really responsive, but more overlap and a free-flowing setup will have a lot more gains.
Coheed is offline   Reply With Quote
Old 07-11-2012, 11:40 PM   #343
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
Sad isn't it.... I wonder what they would say about the ethanol backfires and 6 mpg I got in the Evo on Saturday
Originally Posted by ImAwesome
Great info in here. arghx7 what do you do?
He's obviously a very knowledgable landscaper.
jedibow is offline   Reply With Quote
Old 07-11-2012, 11:40 PM   #344
Roadstercycle
FRS Rear Mount Turbo
Roadstercycle's Avatar
Drives: 2013 FR-S Raven, Rear Turbo
Originally Posted by cobrabyte View Post
Looks good. Keep in mind that some of us are going to relocate the battery. Think there's room to swing the intake into that space? Leaves open the option of a strut bar. Can't see one going on the car with the intake in the current configuration.
I've seen a couple strut bars already installed, in fact MotoP has one and I don't believe there is any issue in clearance at this point.
Roadstercycle is offline   Reply With Quote
Old 07-11-2012, 11:41 PM   #345
Unleashed
Unleashed's Avatar
Drives: 13' WRX
I would say thats badass and totally worththe money you invested haha
Unleashed is offline   Reply With Quote
The Following User Says Thank You to Unleashed For This Useful Post:
civicdrivr (07-12-2012)
Old 07-12-2012, 12:07 AM   #346
Synack
Boosted
Synack's Avatar
Drives: Sideways
And at least 250whp
Synack is offline   Reply With Quote
Old 07-12-2012, 12:36 AM   #347
jedibow
Old 07-12-2012, 12:55 AM   #348
Unleashed
Unleashed's Avatar
Drives: 13' WRX
Haha nice. I am stuck inbetween so many rocks and a hard places with this kit! 1.) I really want to turbo the car, but I dont want to do anything that is going to break something and then make it very difficult to get fixed under warranty. 2.) I want to buy and exhaust system, but havent made up my mind about this turbo kit which would require some customization of whatever exhaust I get. 3.) Lastly, price will determine my choice and if its easy enough to get on and off, if something breaks i will just tow to the house, replace with stock parts and then take in to get fixed hahahaha
Old 07-12-2012, 01:01 AM   #349
jedibow
Don has designed it purposely to only remove the downpipe. He could clarify, but I think any downpipe back should work. He's done the guess work, now all we have to wait for is numbers, and tune results.
Old 07-12-2012, 01:06 AM   #350
Unleashed
Unleashed's Avatar
Drives: 13' WRX
Yeah but most systems are the catback, i guess i could get an axle back system.
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 11:24 AM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-03-2012 11:24 PM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 07:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 08:14 PM
