Old 06-10-2018, 04:56 PM   #19041
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
Went autocrossing today. It was fun but too much time spent standing around and too little time spent driving.
Quentin is offline   Reply With Quote
Old 06-10-2018, 05:27 PM   #19042
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
I gotta know... Is the scoop functional?
Not yet man but it will be
Old 06-10-2018, 06:09 PM   #19043
Ashikabi
Ashikabi's Avatar
I've always wanted a functional roof scoop but I don't know what it's function would be
Old 06-10-2018, 06:15 PM   #19044
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Hair dryer ?
Old 06-10-2018, 06:23 PM   #19045
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Installed extended studs and 10mm spacer to the rear. Now my 18x9 rears are +32. I will be installing the front spacers tomorrow, which will make my 18x8 +19. Both front and rear will have 41mm of poke compared to stock. Front camber will get adjusted too, and new lca are going on for the rear. Pics soon...
I LIKE TIRES!
Old 06-10-2018, 06:47 PM   #19046
Impureclient
Drives: 2015 FR-S
Can you check how many turns you get til tight on those. If you have the 50mm ones from Ebay, I think they are the same length as the ARP that are 1.95". I thought the stock ones are 1.75". That means with a 10mm spacer and the 1.95" ARP one, there would be not enough length to get 8 turns on there with a 10mm spacer.
Old 06-10-2018, 09:02 PM   #19047
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I just took off a lug nut and put it back on. 15 turns. with the 10 mm spacer included. Thats because these can handle up to 15mm spacer, if im not mistaken...
via Imgflip Meme Generator
I LIKE TIRES!
Impureclient (06-10-2018)
Old 06-10-2018, 09:26 PM   #19048
mrg666
pessimistic skeptic
mrg666's Avatar
If those are noname studs from eBay, are you sure they have the strength of OEM? Please be careful!
The Following User Says Thank You to mrg666 For This Useful Post:
Leonardo (06-10-2018)
Old 06-10-2018, 09:34 PM   #19049
Impureclient
Drives: 2015 FR-S
Considering the OEM ones are just above feta cheese on the hardness scale, it seems like it should be OK. Is it even possible to make a stud weaker than the stock ones?
The Following User Says Thank You to Impureclient For This Useful Post:
Old 06-10-2018, 10:45 PM   #19050
Ashikabi
Ashikabi's Avatar
Right? I thought about rear brake cooking ducts but I thought the cabin noise would be horrid
Hair dryer ?
Old 06-10-2018, 10:55 PM   #19051
Quentin
Some video
Old 06-11-2018, 01:02 AM   #19052
juicyg6
juicyg6's Avatar
Drives: 2017 Toyota 86
Red vinyl wrapped my tail lights
Sent from my SM-G955F using Tapatalk
juicyg6 is offline   Reply With Quote
The Following User Says Thank You to juicyg6 For This Useful Post:
monkeybike (06-11-2018)
Old 06-11-2018, 05:31 PM   #19053
Face_Plant
Face_Plant's Avatar
Drives: 2015 Scion FR-S
Today I FINALLY discovered why my cup holder was wobbly: it was in the damn slot backwards...
Next thing I did was inspect my left rear tire to see why it was flat and found a nail, which explained a lot.
Thanks to that nail I was forced to install the spare tire.
While I had the jack out I decided to install the factory mudflaps I've had laying around for about 2 months.
Face_Plant is offline   Reply With Quote
The Following User Says Thank You to Face_Plant For This Useful Post:
Raven86Project (06-11-2018)
Old 06-11-2018, 05:35 PM   #19054
Ashikabi
Ashikabi's Avatar
Originally Posted by Face_Plant View Post
First thing I did was inspect my left rear tire to see why it was flat and found a nail, which explained a lot.
Lastly, I FINALLY discovered why my cupholder was wobbly: it was in the damn slot backwards...
Move that spare to the front. Hard on your diff to run on a spare
The Following User Says Thank You to Ashikabi For This Useful Post:
Face_Plant (06-11-2018)
