Old 05-27-2018, 11:21 PM   #85
dgschmidt01
dgschmidt01's Avatar
Drives: 2013 Hot Lava FR-S
Originally Posted by HeresMyMind View Post
It looks like you got headlights with the wrong plugs, probably a poor vendor or Chinese replica of those headlights. contact the seller for more help.
-B
Okay thanks, I wasn't sure if it was my fault for not researching enough or not. Appreciate the help!
Sent from my SM-G950U using Tapatalk
dgschmidt01 is offline   Reply With Quote
Old 05-31-2018, 03:59 AM   #86
razor_1996
Hey, I've got a set of Winjet headlights in my FRS. I'm thinking about doing halos, but have no idea on what size of halos to even look at for those headlights. Any idea without tearing them apart and measuring?
razor_1996 is offline   Reply With Quote
Old 05-31-2018, 02:27 PM   #87
norcalpb
norcalpb's Avatar
My oem driver side BRZ headlight has been flickering a ton lately. What exactly could be causing this? Could it be a bad relay?
Old 05-31-2018, 02:37 PM   #88
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
I’ll get that info for you tonight!
-B
HeresMyMind is offline   Reply With Quote
Old 05-31-2018, 02:38 PM   #89
HeresMyMind
Given you are driving a 2013 brz. The bulbs could be on their way out or it could be the oem d4s ballasts. Swap the bulbs from 1 side to the other. See if the problem persists in the same side. If so it’s the ballast
-B
The Following User Says Thank You to HeresMyMind For This Useful Post:
norcalpb (05-31-2018)
Old 06-01-2018, 02:57 AM   #90
razor_1996
-B
Whenever you get a free moment is fine, I'm not in a big rush right now.
Old 06-09-2018, 08:31 AM   #91
HeresMyMind
https://www.86speed.com/products/mor...back-halo.html
it looks like you can use 1 of 3 sizes depending on how large you want the halo to appear or fit.
-B
Old 06-09-2018, 12:27 PM   #92
norcalpb
norcalpb's Avatar
-B
Forgot to mention I swapped bulbs and the other side started flickering, so I replaced bulbs and problem solved thanks so much man!
Old 06-09-2018, 01:27 PM   #93
HeresMyMind
Awesome. Glad I could help.
-B
Old 06-19-2018, 05:05 PM   #94
razor_1996
-B
Just now saw this, but thank you for finding that info for me I’m prolly gonna do the 90mm eventually!
Old 06-19-2018, 07:51 PM   #95
mnguyen266
Drives: 2014 Scion FR-S Monogram
Hi there,
I'm new to the forum, sorry if this might be asked before.
I have a 2014 Scion FR-S Monogram series. When I purchased the car it came with OEM foglights and recently my driver side foglight got busted and was wondering which aftermarket foglight is closest to OEM quality? Found out that one OEM foglight from Toyota costs around $300, not sure if I want to spend that much..
Also I plan on switching out the bulbs to match my OEM HID headlamps, any suggestions on which bulbs to use without melting the foglight housing?
mnguyen266 is offline   Reply With Quote
Old 06-19-2018, 07:52 PM   #96
HeresMyMind
Originally Posted by mnguyen266 View Post
Hi there,
your best bet for performance is to replace the pair with LED ones from Morimoto for 180$ or from Baja Designs (if you want the best of the best) for like 250.
Otherwards ebay has a ton of used ones cheap. The brz and FRS use the same fog light housing so feel free to search for either.
If interested in either let me know, I can get you special pricing through them!
-B
TRS - Morimoto
https://www.theretrofitsource.com/sc...to-xb-led.html
Baja Designs
https://www.bajadesigns.com/products...Light-Pair.asp
Brackets
https://www.paranoidfabrications.com...gn-fog-bracket
Old 06-19-2018, 11:12 PM   #97
mnguyen266
Thanks for the advice.
I'm thinking of going for the Morimoto foglights from ft86speedfactory.
http://www.ft86speedfactory.com/mori...l#.WynFzKczphE
Old 07-03-2018, 08:35 PM   #98
airrick
Drives: TRD R.S. 1.0 FRS
Okay. So i have a rs 1.0. They dont have fog lights. I bought the winjet fog lights for the monogram/release 10 series. Because i wanted to have the oem factory cover with switch on it. All it comes with is everything except oem cover thing. If i buy one of them from 86speed.com will it fit my rs frs?
https://www.86speed.com/new-products...witch-kit-frs/
I would have gotten the normal one but where normally frs have an unused button next to the trunk lock button, the rs 1.0 uses the unused slot for moving up the headlights
This is such a pain for fog lights.
airrick is offline   Reply With Quote
OEM foglight install question DarkSideFRS Cosmetic Modification (Interior/Exterior/Lighting) 3 06-12-2017 03:21 PM
FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides Verge Exterior Parts (Aero, Lighting, Etc.) 12 11-21-2014 08:56 PM
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 01:19 AM
