@anthonysestito
Drives: 2013 Sterling Silver Metallic BRZ
Anyone ever open up/install the GCS V2 Brake/Reverse housing?
Didn’t realize I bought the v2 version but none the less the instructions were quite vague.
Tried to hook the brake/fog light into my previously installed Fn’ A fourth brake light kit to get the F1 style flash but it kept blowing the fuse so I yanked that out the chain. Now I’ve got black wire to ground and red wire to parking wire off stock harness - yellow wire, I plugged into brake & parking wire in stock harness and it yielded nothing for me. My question is, is there a way to wire the fog light to operate both as a fog light (when parking lights are on) AND as a brake light? So slightly dimmer when fog and bright as brake? Also, I totally hate the “U” shaped portion of the light. I can’t really tell if it’s lit up because the light from the fog light is bleeding into it, or if it’s power source was tied into the red wire? I assumed power to that portion came from the yellow wire. Regardless, I don’t want it, can the housing be opened up to remove them physically? Should mention I have valentis as well. Sent from my iPhone using Tapatalk
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO |
#2 | |
Drives: 2014 BRZ Limited
#3 |
Here is a video of what I did.
#4 |
Drives: 2014 brz
I opened mine to disconnect the brake light from the running lights. When i got it they were wired together so the triangle was on with the running lights and its wayyy to bright for that. I didn't see any immediate way to dim the triangle so that would take some more effort.
FYI the light opens like a headlight so heat the glue and work it open. Its not like the valenti ones that just unscrew. |
#5 |
@anthonysestito
Ok that’s awesome! Not what I want to do but I can certainly appreciate that - looks great! Sent from my iPhone using Tapatalk
#6 | |
@anthonysestito
Hmm it looks like that back unscrews - it’s on the car now so I’ll have to give it a crack another day. Did you see anyway to disconnect the running lights and just keep the brake light on? Did connecting the red wire (+ terminal of the brake light I assume) to the brake wire on the stock harness give you the triangle in the center as brake light? For some reason that didn’t work for me. Sent from my iPhone using Tapatalk
#7 | |
| The Following User Says Thank You to sactownbwoy For This Useful Post: | brzzy (06-09-2018) |
#8 | |
Drives: 2014 brz
This light was originally designed for an over seas market where they have a rear fog light and when they modified it for the us market they put a jumper between the running lights and brake light. There are screws in the back that hold it together, but it also has glue and clips all the way around the outside. When i first opened mine i didn't realize it was glue and thought it was just the clips. The clear plastic is quite brittle so i broke a corner off my light. Thankfully, it wasn't large enough to prevent it from sealing and it is hidden by the bumper. Take your time, heat it up and work it apart. |
| The Following User Says Thank You to Firecruiser For This Useful Post: | brzzy (06-11-2018) |
#9 | |
Drives: 2013 Scion FRS
#10 |
Drives: 2014 brz
See my original thread here https://www.ft86club.com/forums/showthread.php?t=114970
There are some photos of the wiring in there. |
| WTB: OEM reverse light housing | tobin | Want-To-Buy Requests | 0 | 04-24-2018 04:10 PM |
| Reverse Cam Install | mleko | Electronics | Audio | NAV | Infotainment | 4 | 11-11-2017 05:05 PM |
| Cleared out reverse taillight housing | subiestyle | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 04-10-2014 02:28 PM |
| Third brake light housing keeps popping off | Grey | Issues | Warranty | Recalls / TSB | 0 | 07-11-2013 10:40 PM |
| Reverse light and red triangle reflector housing part number? | dem00n | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 07-06-2013 03:12 PM |
