Old 06-07-2018, 04:57 PM   #57
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Originally Posted by jsimon7777 View Post
I was not totally correct in my earlier post. On Speed Element's site, it says:
"The accumulator also protects against oil pickup starvation due to high g turns. So if you’re running racing slicks and aero, when your oil sloshes away from the oil pickup tube in the OEM pan, the accumulator again forces high pressure oil to the critical main and rod bearings. Kits start at $349 and with the Billet Brackets as show the kit is $458"
http://elementtuning.com/competition...r-wrx-fa20dit/
So, if you're running slicks and aero, look at getting an accumulator.
Would Moroso / cosworth oil baffle works? or is a waste of $?
botbs is offline   Reply With Quote
Old 06-07-2018, 05:04 PM   #58
Is it a hard core track rat that has logged oil pressure drops on turns? If not then it is money not well spent. Up to you to decide if it was wasted.
botbs (06-08-2018)
Old 06-08-2018, 06:41 AM   #59
Dake
Dake's Avatar
Dake is offline   Reply With Quote
Old 06-08-2018, 02:12 PM   #60
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
OK...I have a stock '14 FRS that is a DD but which will also be running stuff like turn 17 at Sebring on track-compound rubber. First thing I have to do is get an oil pressure and temp gauge, and oil cooler. I expect to run Mobil 1 5w30 year round because it gets hot in Florida and I see 7 grand on the tach regularly on the street. Do I need more mods than that to keep this engine together on the track?
Qwimby1 is offline   Reply With Quote
Old 06-08-2018, 02:13 PM   #61
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
We can ask someone like @CSG Mike
I think its important to note Squad Rogue was always a troll and randomly theorizing things in posts
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Tcoat (06-08-2018)
Old 06-08-2018, 02:35 PM   #62
Meh. It doesn't take a specialist to know that if you are not driving your car under extreme conditions an oil baffle is overkill.
Old 06-08-2018, 02:42 PM   #63
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Track question? There's a thread for that
http://www.ft86club.com/forums/showthread.php?t=38926
Tcoat (06-08-2018)
Old 06-08-2018, 03:02 PM   #64
LOL People that don't know Squady and don't read to far in may think that this is a legitimate thread.
For anybody that does not know the history please read this:
http://www.ft86club.com/forums/showthread.php?t=81548
finch1750 (06-08-2018), FRSBRZGT86FAN (06-10-2018)
Old 06-08-2018, 03:13 PM   #65
I'll reply here regardless. I have a pretty special oil cooler setup. People would consider it oversized but I can manually adjust the flow after the thermostat.
Based on specs published in the service manual, the important number to watch for is the target maximum oil pressure of around 70-75 PSI. 0W20 is fine for me if I keep it under 185 F. I haven't experimented with other viscosities because I like the fuel efficiency benefit.
A couple of the local guys have beaten the piss out of their engines with no oil cooler and are still running strong. I think engine longevity is mostly a numbers game with respect to build quality and manufacturing tolerances.
I suggest getting the pressure gauge first so you can watch it and make informed choices. For instance, you will notice how high the pressure is when it's cold. It's a struggle for me to keep it under 120 PSI for the first few minutes. 140 PSI is where it bypasses to protect gasket and o-ring seals, and the pump. Keep that in mind as you play with viscosity.
Last edited by Ultramaroon; 06-08-2018 at 09:45 PM. Reason: Remembered the more important reason to watch cold pressure..
Old 06-08-2018, 03:15 PM   #66
I suggest getting the pressure gauge first so you can watch it and make informed choices. For instance, you will notice how high the pressure is when it's cold. It's a struggle for me to keep it under 120 PSI for the first few minutes. 140 PSI is where it bypasses to protect the pump. Keep that in mind as you play with viscosity.
Ultramaroon (06-08-2018)
Old 06-08-2018, 09:39 PM   #67
Link to DIY?
Old 06-08-2018, 09:45 PM   #68
Link to DIY?
No diy given. The guy that posted it got banned before he could go into detail. He was a bit odd anyway.
Old 06-08-2018, 10:53 PM   #69
Too bad. It looks legit.
Old 06-08-2018, 11:08 PM   #70
Who knows. He was the kind of guy that would drive around with two holes where his exhaust tips should be and no back up lights. You know the type.
Sapphireho (06-09-2018)
Auto launch blows! feldy Engine, Exhaust, Transmission 83 04-14-2017 10:42 AM
Dr. Destructo blows a rocker apart Element Tuning Engine, Exhaust, Transmission 82 12-04-2015 03:00 PM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
This blows... finch1750 Electronics | Audio | NAV | Infotainment 19 06-21-2012 12:03 PM
