Old 06-06-2018, 12:42 PM   #15
sfruski
Drives: Many
My issue ended up being that the signal wire coming from the ecu and going to the relays was cut. It was cut because someone tried to splice in a different ecu, so most likely my issue won't be the same as yours.
Pull the coolant temp sensor connector, then turn the car to ON. It should start both fans if the signal wire is good. If not, that is one place to start looking.
sfruski is offline   Reply With Quote
Old 06-06-2018, 01:13 PM   #16
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
Appreciate the help! Will try tonight.
Joesurf79 is offline   Reply With Quote
Old 06-07-2018, 10:16 PM   #17
Joesurf79
Joesurf79's Avatar
Unplugged the temp sensor, both fans immediately on when key turned to on. So that means I'm good to go I think!
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 08:21 PM
It appears that the buts are gone.... echo419 Off-Topic Lounge [WARNING: NO POLITICS] 66 10-25-2015 02:38 AM
Blue Coolant turning green? rhood168 Issues | Warranty | Recalls / TSB 5 06-17-2014 01:44 PM
ft-86 II appears in GT Racing 2 for ios/android (free) chickdigger802 Scion FR-S / Toyota 86 GT86 General Forum 1 11-14-2013 10:40 AM
fr-s appears in Asphalt 8 chickdigger802 Scion FR-S / Toyota 86 GT86 General Forum 6 08-23-2013 09:05 AM
