Old 06-05-2018, 01:57 AM   #1
twag4
Drives: frs
DeatschWerks 300C fuel pump($100) and 700C injectors($200)
300C fuel pump and 700C injectors by DW. Injectors have plug and play leads, fuel pump has everything to install, but recommend a new fuel pump inlet filter. Both were on the car from July 2016 to November 2016 and used with e85. Now finishing up built engine with larger pump and injectors, so these are no longer needed. Less than 4000 miles on each.
300C fuel pump- $100
700C injectors- $200
twag4 is offline
Old 06-06-2018, 02:20 PM   #2
sid94
Drives: 2013 frs
Did you ever get the car running!?!?
sid94 is offline
Old 06-07-2018, 01:15 AM   #3
twag4
Drives: frs
Should be picking it up any time now.
twag4 is offline
The Following User Says Thank You to twag4 For This Useful Post:
sid94 (06-07-2018)
Old 06-07-2018, 08:14 AM   #4
majixmatrix
BRZ Wannabee
majixmatrix's Avatar
Drives: 2013 Limited BRZ
What kind of setup did you run these on?
majixmatrix is offline
Old 06-07-2018, 03:30 PM   #5
twag4
Drives: frs
Jackson Racing c30 kit with ace header and Delicious flex fuel kit.
twag4 is offline
Old 06-09-2018, 01:03 PM   #6
twag4
Drives: frs
***SOLD
twag4 is offline
DEATSCHWERKS DW 925cc Fuel Injectors & DW65c Fuel Pump ZeroTo86 Engine, Exhaust, Bolt-Ons 0 08-08-2016 07:39 AM
Deatschwerks 700cc injectors and fbm 270lph pump $275 shipped boostedbrz Engine, Exhaust, Bolt-Ons 9 03-06-2016 11:57 PM
DeatschWerks Fuel Pump C130NAV Engine, Exhaust, Transmission 20 04-01-2014 08:06 PM
Deatschwerks BRZ/FR-S Fuel Injectors! RallySport Direct Engine, Exhaust, Bolt-Ons 2 09-07-2012 07:29 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
