#30 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
They've been awesome. No complains. They recently put up with three days worth of abuse including full 20 minute sessions at Road Atlanta with 120F surface temps without getting greasy at all. Relentless dry grip and great wear rate. Can't ask for more. |
#31 |
34 hot is significantly better than 38 hot, but I suspect still a bit too high. I'm going to try 32 and 30 hot next time out.
Haven't been out driving nearly as much this summer as last year and haven't played with setup at all, been busy hanging out with this guy:
| The Following User Says Thank You to wparsons For This Useful Post: | DarkSunrise (09-20-2016) |
#32 | |
Drives: GT86 Cosworth
I've found 32 works well. |
| The Following User Says Thank You to ajc209 For This Useful Post: | wparsons (09-20-2016) |
#33 |
Senior Misanthrope
#34 |
Drives: 13' BRZ
I've had 4 HPDE track days on these tires so far and really like them. Coming from Hankook RS-3's, these Maxxis VR-1's have much stiffer sidewalls and the notorious road noise (humming @ 70-75mph) is nonexistent.
My current alignment (-3F/-2.2R/0T) doesn't seem to work well with these tires. The outside shoulder is showing increased wear vs the inside (No, I do not have a pyrometer, just visual). Although 3 days at BW CW13 is pretty abusive on the front driver side tire. 36psi hot, will try lower 33 or 34 next time. I will try increasing the camber to -3.3 or -3.5 at the next track day - Buttonwillow CW13 - 2:06.22 Curious to see if others have run into different or similar issues? EDIT: 255/40/17 - 17x9 Last edited by Tenino; 04-30-2017 at 07:10 PM. Reason: EDIT: 255/40/17 |
#35 | |
Senior Misanthrope
edit: Before that weekend, I had flipped the tires on the wheels, so the damaged shoulder used to be on the inside. I knew the tires were almost dead, so I was extra rough on them that weekend. edit2: damage was to rear tires ![]() edit3: they gave up on me mid-corner. See 4:50: [ame="https://www.youtube.com/watch?v=3YOo0uZmrF0&t=4m50s"]TWS with TDE 10/23/16 - last session drift - YouTube[/ame] |
#36 |
Drives: 2015 Subaru BRZ Limited DGM
Any insights on the new "S2" compound?
#37 |
#38 |
#39 |
There's another company that advertises a "VR1 S2".
Now the actual VR1S2 is a compound update... should be rolling out soon, but hasnt hit the market yet in all sizes. |
#40 | |
#42 |
I can't talk about anything yet.
| Maxxis Victra RC1 Review | whataboutbob | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 12-18-2016 12:17 AM |
| Maxxis RC-1 tire notes | Doozer | Tracking / Autocross / HPDE / Drifting | 26 | 06-11-2015 09:39 AM |
| FS: (4) Maxxis RC-1's 255/40/17 | BeltedBiscuit | Wheels and Tires | 5 | 09-08-2014 09:38 AM |
| Hankook Ventus RS3... I have a 200TW RS3? | CSG Mike | Tracking / Autocross / HPDE / Drifting | 41 | 05-24-2013 05:49 PM |
| new R compound from Maxxis | Matt Andrews | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-08-2012 02:27 PM |
