Drives: gt86...among others
Maxxis RC-1 tire notes
Wanted to share some tire data for everyone else who runs the RC-1.
Over 200+ race miles on a set of these bad boys
racing gods live deep in corners
| The Following 13 Users Say Thank You to Doozer For This Useful Post: | CSG Mike (01-05-2015), DaDr00 (01-05-2015), dp1 (01-05-2015), juliog (01-05-2015), mav1178 (01-05-2015), Pat (01-05-2015), phastafrican (01-04-2015), philooo (06-07-2015), RehabJeff86 (02-01-2015), RJasonKlein (07-31-2017), Totality (01-28-2015), Touge Factory (06-10-2015), zdr93523 (01-06-2015) |
Drives: 2013 FRS, 2014 BMW 335 M-Sport
Very nice. These are on Ohlins Road and Track kit? Are you using stock kit spring rates are custom rates and valving?
I may try your setup with a new set of RC's. |
I like this thread.
#4 | |
"Stock" 380lbs spring front and rear and "stock" valving. Tried a few times to put on 500/550lb springs but the car become too stiff. Even with sticky tires like V710's or Michelin's, it seems the car (or driver) prefers a slightly softer set-up. Next season i will change spring rates only because we've swapped our control arms and the rear could stand to be slightly stiffer. I'm thinking 400/425 range. At some point in the future I'll post scale sheets with corner balancing numbers, just haven't digitized them yet.
| The Following User Says Thank You to Doozer For This Useful Post: | dp1 (01-05-2015) |
#5 | |
driving smoother faster
Drives: Sold
This is an awesome post! Much appreciate your response to my PM... My Ohlins R&T are currently with Ohlins and were just about to get rebuilt with new springs...was going for 450f/500r but I will go for 380f/425r after reading this. Car is my daily and track/AX toy with Ohlins used Apr-Nov. Stock control arms and sways, Nitto NT01 235/40-17 on 17x9 RPF1. Just moved to HPD3 with NASA and practiced gas/steering rotation on LRP AX course a few times, in 2014, so still have a lot to learn. Would like the car to rotate a little easier without much throttle (with JRSC) and it looks like you found a good formula. Looking forward to trying this out, thanks! |
| The Following User Says Thank You to dp1 For This Useful Post: | Doozer (01-05-2015) |
#6 | |
Drives: 2004 Toyota RAV-4 5M
| The Following User Says Thank You to ja1217 For This Useful Post: | Totality (01-28-2015) |
#7 | |
Springs are just one piece of the grand equation then I can't fully comprehend. With our set-up, the stiffer springs caused "flat slides with late hook-up". Meaning by the time the outside tires got traction they were over the curb and mowing the grass. Best measure of all this mumbo-jumbo is driver comfort and lap times. Keep us posted after your first track day with 'em and let us know how it works. If you gain a few seconds, maybe it's worth a shot! Take care
#8 | |
Haven't raced LRP since they repaved it. Have a blast!
#9 | |
Drives: Sold
#10 | |
Drives: Sold
I'm having fun on their awesome half mile AX track (http://www.limerock.com/index.php?op...690&Itemid=286), very safe setup and a great way to learn car control at lower speeds with very little chance of damaging the car. Perfect for tires that heat cycled out and have some tread left...slide away
#11 |
Most recent scale #'s
1st is standard ohlins 380lbs springs front and rear. 2nd is 500lb front and 550 rear springs wights are without driver
#12 |
Drives: Sold
I think that standard spring rates are 343lb front and rear. Ordered 380lb front and 425lb rear. Will see how they do at NJMP in April and May.
BTW, I thought that standard spring rates were very good as compromise for street and track, and they devoured curbing as if it wasn't there, but it took quite a bit of throttle (with JRSC) to rotate the car. Hope revalved 380lb front and 425lb rear helps, it should. |
#13 |
I just got my set of RC-1's today and happened to have a set of Hoosier R7's laying around to do some quick comparisons.
First off, width. From what I can tell, Hoosier's always run pretty wide and the R7 is no exception. My RC-1's are 225/45R17 and my R7's are 225/40R17. The R7's are about an inch wider than the RC-1's, despite the fact that they are both considered 225 width. Here's a pic comparing the widths: ![]() ![]() The overall width of the R7 is just about 10 inches while the RC-1 is a little over 9. When you factor in that the RC-1 has a more rounded edge than the R7, the actual contact patch will be even narrower. I also did a very scientific weight measurement (weigh myself, then weigh myself holding a tire) and found that the RC-1 is a little over 5 pounds heavier than the R7 (24.8lbs vs 19.2). This NASA TT season is going to be interesting running the RC-1's. I'm betting that the points I got back from switching tires and spent on full exhaust and intake will overcome the time lost due to the lower grip of the RC-1's. I'll have to wait until my first event in March at VIR to find out how they compare. |
| The Following User Says Thank You to ja1217 For This Useful Post: | Doozer (02-02-2015) |
#14 |
Drives: 2023 BRZ
Wow, that's a big difference in weight. I figure the width and height differences probably offset each other in terms of weight. Thanks for sharing.
| The Following User Says Thank You to Pat For This Useful Post: | Doozer (02-02-2015) |
| Tags |
| csg mike, essex |
| NASA Maxxis Contingency and Konig Wheel discount | DaDr00 | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2014 12:25 PM |
| FS: (4) Maxxis RC-1's 255/40/17 | BeltedBiscuit | Wheels and Tires | 5 | 09-08-2014 09:38 AM |
| CSG BRZ, Maxxis Victra RC-1 Racer Testimonial Video and microsite | CSG Mike | BRZ Photos, Videos, Wallpapers, Gallery Forum | 11 | 05-28-2013 02:32 PM |
| Snow wheel / tire install notes | Ingen | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 12-21-2012 02:43 PM |
| new R compound from Maxxis | Matt Andrews | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-08-2012 02:27 PM |
