Agent 86
Drives: 2017 Toyota 86
Just thought I'd post some of the OEM part numbers in one thread. Some Toyota/Scion parts will have a Subaru part number too. It'll help someone ID used OEM suspension.
Sources: https://parts.toyota.com and http://parts.subaru.com/ BRZ PART NUMBERS Front Strut (Right) 2013-14 - 20310CA020, 20310CA021 2015-16 - 20310CA120 2017-17 - 20310CA160 (SACHS), 20310CA220 Front Strut (Left) 2013-14 - 20310CA030, 20310CA031 2015-16 - 20310CA130 2017-17 - 20310CA170 (SACHS), 20310CA230 Front Springs 2013-16 - 20330CA010 2017-17 - 20330CA200 Rear Springs 2013-16 - 20380CA010 2017-17 - 20380CA210 Rear Shocks 2013-14 - 20365CA010, 20365CA011 2015-16 - 20365CA110 2017-17 - 20365CA120 (SACHS), 20365CA210 FR-S/86 PART NUMBERS Front Strut (Right) 2013-14 - SU00300371 - 20310CA000 2015-16 - SU00305256 - 20310CA100 2017-17 - SU00306792 - 20310CA200 Front Strut (Left) 2013-14 - SU00300372 - 20310CA010 2015-16 - SU00305257 - 20310CA110 2017-17 - SU00306793 - 20310CA210 Front Springs 2013-16 - SU00304144 2017-17 - SU00307193 Rear Springs 2013-16 - SU00304147 2017-17 - SU00307196 Rear Shocks 2013-14 - SU00300382 - 20365CA000 2015-16 - SU00305258 - 20365CA100 2017-17 - SU00306797 - 20365CA200 Last edited by Scourge; 08-28-2017 at 10:43 AM. |
| The Following 5 Users Say Thank You to Scourge For This Useful Post: | chaoskaze (08-28-2017), Iceman (05-30-2018), LancePower (08-28-2017), pumice (08-09-2018), Vital (08-24-2017) |
#2 |
Drives: 2015 BRZ
This might be a silly question, but is it possible to use the PP Sachs dampers in the pre MY2017 cars? Or has anyone upgraded their suspension to the PP suspension on their pre 2017 cars? sorry if this has been covered before im just curious
#3 | |
Drives: '13 FRS - STX
Probably the best bang for buck upgrade to an early car at this point is a set of low mileage '17+ coilovers for a few hundred bucks given the reviews the new cars get. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Vital (08-24-2017) |
#4 |
Drives: 2014 GT86
strat61caster: but how well they will work with older spring rates, or everything including springs and rollbars (IIRC also changed vs older?) should come over?
#5 | |
Drives: 2015 BRZ
Same, id like to know how well the older model springs would work with the Sachs dampers. |
#6 | |
In any case I believe it would be close enough to not be "bad" (or anywhere close to bad) but maybe not as good as possible. I'd say most agree, as far as I can tell almost nobody aftermarket is changing part numbers for dampers (i.e. Koni and Bilstein) or lowering springs (i.e. RCE, Eibach, H&R) as they all say they can be used with whatever chosen spring or damper. @Vital part of the reason why I suggested it was the new spring rates play a factor in the good reviews the '17+ cars are getting, if you're not going to change springs I would think an aftermarket damper would be more satisfying, but if you can get a good price then I think the '17+ OE is a viable replacement. |
#7 |
Agent 86
Yeah, using old springs with new dampers is sometimes an issue. I have a 2017MY Toyota 86. I ordered a set of Eibach Sportlines and was about to install them until I found out from Eibach themselves said they don't ride great with the 2017 86 struts/shocks (but their Pro-Kit is fine). I ended up getting some used 2015-16 struts/shocks cheap to use on the springs.
I'd also imagine the Sachs setup would feel fine if you used the 2017 BRZ springs and swaybars. |
#8 |
OK, I finally managed that there is even another part number for Sachs shocks and springs for JDM BRZ STi Sport. Do you know if this specific model is lowered or not?
#9 |
Drives: 2014 GT86
BTW, for completeness sake shouldn't also list be updated with swaybar partnumbers in zenki & kouki, as they imho are designed to work with as system with updated spring & damping rates of new shocks/springs? And whatever else might be updated in suspension .. weren't there some bolts too? Or that was in MY2015? Memory is vague ..
| OEM Suspension Upgrade Part Numbers - Group N, STI, Bilstein, etc. | Createddeleted | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 03-12-2017 03:49 AM |
| Part numbers or part diagram? | pacemkr | Engine, Exhaust, Transmission | 6 | 08-22-2016 01:44 PM |
| Part Numbers | tommy | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 12-31-2013 04:33 PM |
| ANyone know these part numbers? | J-Money | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 04-22-2013 12:37 PM |
| part numbers | Staticfrost | BRZ First-Gen (2012+) — General Topics | 5 | 05-29-2012 12:02 PM |
