Old 03-06-2015, 03:16 PM   #1
Createddeleted
Drives: 2014 BRZ - 2004 GLI
OEM Suspension Upgrade Part Numbers - Group N, STI, Bilstein, etc.
Since I have a spread sheet with a bunch of parts numbers and there has been recent discussion of these parts I figured I would post them. (my website for this stuff really never kicked off an maybe someone will appreciate it.)
From the findings below you can see that the GAZOO Race series 86's use a number of Group N parts from the 2008MY car; which is good news for all of us. I had not seen a cross reference and did some digging.
- The Group N Strut mount is the same for the BRZ as it is/was for all the other models.
-I need to verify if 2011 STI Rear mounts will work for the BRZ, if they are any different, and if they provide a substantial upgrade.
I might continue to update this thread. Please let me know if this needs to be moved. I have also omitted some non suspension, chassis, brakes components to make this thread relevant.
TLDR: Some Group N bushings from the 2008MY work.
Description Subaru Part# Notes Category
Motor Mount R ST41022AS000 BRZ Chassis Specific Driveline
Motor Mount L ST41022AS010 BRZ Chassis Specific Driveline
Transmission Mount ST41020AS000 BRZ Chassis Specific Driveline
Air Filter ST16546ZA000 TOYOTA sized filter - crosses to other models Engine
Front Upper Strut Mount ST2031055000 Same as STI Group N Mount Suspension
Lower Arm Bushing ST20204ZR010 Group N Bush - Legacy? Suspension
Lower Arm Bushing #2 ST20204ZR000 Group N Bush - 2008MY Suspension
Lateral Control Rod Bushing ST20204ZR020 Group N Spherical Bush - 2008MY Suspension
Rear Upper Arm Bushing ST20254ZR040 Group N Bush - 2008MY Suspension
Rear Trailing Bushing ST20254ZR010 Group N Bush - 2008MY Suspension
Rear Suspension Arm Bushing #2 ST20254ZR030 Group N Bush - 2008MY Suspension
Rear Stabilizer Bushing ST20254ZR060 Group N Bush - 2008My Suspension
Subframe Bushing ST20174AS000 BRZ Chassis Specific Suspension
Steering Rack Bushing ST34112AS000 BRZ Chassis Specific Suspension
Differential Mount L ST41322AS000 BRZ Chassis Specific Suspension
Differential Mount R ST41322AS010 BRZ Chassis Specific Suspension
Air Duct R 57750AS000 BRZ RA Chassis Specific Brakes
Air Duct L 57750AS010 BRZ RA Chassis Specific Brakes
BackPlate R 26290AS020 BRZ RA Chassis Specific Brakes
BackPlate L 26290AS030 BRZ RA Chassis Specific Brakes
RA Spring Set 20300AS010 BRZ RA Chassis Specific Suspension
RA Shock Absorber Set 20300AS000 BRZ RA Chassis Specific Suspension
Bilstein Front Strut L ST20310AS050 BRZ TS Chassis Specific Suspension
Bilstein Front Strut R ST20310AS040 BRZ TS Chassis Specific Suspension
Bilstein Rear Shock L+R ST20365AS020 BRZ TS Chassis Specific Suspension
STI Sport Spring for Bilstein/STI Front ST20330AS010 BRZ TS Chassis Specific - Fits Yellow or Silver Struts Suspension
STI Sport Spring for Bilstein/STI Rear ST20330AS020 BRZ TS Chassis Specific - Fits Yellow or Silver Struts Suspension
STI Sport Spring for OEM Strut Front ST20330AS000 BRZ Chassis Specific Suspension
STI Sport Spring for OEM Shock Rear ST20380AS000 BRZ Chassis Specific Suspension
Createddeleted is offline   Reply With Quote
The Following 3 Users Say Thank You to Createddeleted For This Useful Post:
cslntuee (03-07-2015), NissanGuy (03-09-2015), Trap63 (05-11-2015)
Old 03-06-2015, 05:37 PM   #2
dave-
Drives: 86 GT
Any chance you can post the actual spreadsheet for lazy people to copy&paste the part numbers
dave- is offline   Reply With Quote
Old 03-06-2015, 08:09 PM   #3
Createddeleted
I tried to post it as an excel sheet and it didn't work. I also exported it out of excel and vbulletin would not let me use HTML. So until I can figure out how to post stuff in a formatted form, you're out of luck. :/
Old 03-06-2015, 08:19 PM   #4
Chimera
Drives: FRS
Post it as tab delimited text?
The Following User Says Thank You to Chimera For This Useful Post:
burdickjp (03-07-2015)
Old 03-09-2015, 10:14 PM   #5
Derka
Drives: 2015 frs
Where can you purchase the ra stuff in the us
Derka is offline   Reply With Quote
Old 03-09-2015, 10:35 PM   #6
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
Nice research!
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline   Reply With Quote
The Following User Says Thank You to NissanGuy For This Useful Post:
Createddeleted (03-09-2015)
Old 03-09-2015, 10:44 PM   #7
Createddeleted
You can't. Japan only
Old 03-09-2015, 10:44 PM   #8
Createddeleted
I will try this tomorrow.
Old 03-09-2015, 11:56 PM   #9
cslntuee
Drives: Subaru BRZ Limited
Do you know what's different between yellow and silver BRZ TS struts?
Thanks.
cslntuee is offline   Reply With Quote
Old 03-10-2015, 11:03 AM   #10
Createddeleted
Thanks.
As far as I know, the Silver's are STI made shocks and the Yellows are Bilstein shocks made specifically for STI. Both have an extended length as compared to the OEM suspension. I believe this is also the reason for two different spring sets.
First post also updated with just text for the people who just ant to copy and paste.
The Following 2 Users Say Thank You to Createddeleted For This Useful Post:
cslntuee (03-11-2015), dave- (03-16-2015)
Old 05-26-2015, 04:25 AM   #11
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I tried a couple of months ago to order some RA parts from Japan. They are not selling them.
Old 05-27-2015, 12:51 AM   #12
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Does anybody know if any of these struts would be a good option with the Swift BRZ springs?
JoeBoxer is offline   Reply With Quote
Old 03-12-2017, 03:49 AM   #13
choi0706
Drives: t
figure about the 2011 rear sturt mounts?
choi0706 is offline   Reply With Quote
OEM part numbers nikitopo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-29-2014 12:59 PM
Part Numbers tommy Scion FR-S / Toyota 86 GT86 General Forum 3 12-31-2013 04:33 PM
ANyone know these part numbers? J-Money Scion FR-S / Toyota 86 GT86 General Forum 3 04-22-2013 12:37 PM
Part numbers 20valvewynn83 Cosmetic Modification (Interior/Exterior/Lighting) 1 07-24-2012 06:16 AM
How do I get JDM part numbers? InstantNoodles Cosmetic Modification (Interior/Exterior/Lighting) 2 07-09-2012 04:29 PM
