Drives: 2017 World Rally Blue BRZ
LED front turn signals and Valenti tailights
This is my first post on here
![]() I am looking to upgrade the front turn signals to LED's and taillights to Valenti sequential ones. If I were to install a hyperflash-fix flasher under the dash, how does it affect the sequential function of the taillights? - Does it prevent the tail light turn signals from fully "extending"? If the flasher would mess with the rear tail light sequential function would I need resistors, and if so which wires to tap into(for the front turn signals)or would the front not hyperflash? |
#2 |
A.K.A. Starlord
Drives: 2015 Series.Blue
I don't have experience with Valenti sequential tail lights, but an electronic flasher is no different from the stock flasher. It just uses electronics to control the on/off current flow to the turn signals, as opposed to a mechanical mechanism. At the end of the day, the tail lights still see the same current, for the same amount of time (give-or-take any slight difference in the rate at which the specific module you purchased flashes.)
TL;DR, I don't think it would affect the sequential function of the tail lights, but I'm also just guessing based on my limited knowledge of how it operates. I'm sure you can get a better answer from someone with those actual lights. /kinda-sorta-useless-reply
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
#3 |
Drives: GR Corolla
I sold my neighbor my switchback LEDs for the front. He has the sequential rear taillights, and he told me that the rear turn signals will only go halfway before restarting. I'm not sure if that's because it is a switchback style, or simply being LEDs in the front. He just switched it to non-sequential turning.
#4 | |
Human
Drives: 2015 BRZ Black
Without the hyperflash fix, the turn signal cycles too fast for the sequential to keep up.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
#5 |
Drives: 2015 Firestorm FRS
Is the quality good for the switchback front turn lights?
Also planning to install toms tail lights. Will i have to put 2 relay flasher? |
#6 |
Drives: Black 86 GTS
You need need an led relay to stop the hyper flashing caused by the front led indicators. The Valenti has built in resistors so don’t need a relay installed to function. The reason why the other post was only getting half the sequence on the tail lights is because the front led was causing hyper flash and so the sequence of the tail lights is too rapid to do the full sequence. Again just needs an led relay and only one.
#7 |
Those after aftermarket relays suck. Just mod the OEM flasher like this:
http://www.ft86club.com/forums/showthread.php?t=114284 |
#8 | |
Drives: red 2014 FR-S
no complaints on my $15 relay. |
#9 | |
A.K.A. Starlord
#10 |
And I couldn't care less that the first blink might be slightly longer than the other blinks.
#11 |
The delay on first blink is exactly why I say the aftermarket ones suck. You can pull the OEM blinker, desolder the shunt resistor and solder in a new one for about $0.10 and still maintain the burnt bulb detection (something the aftermarket relays don't do) and not have that annoying lag on the first flash.
#12 |
Valenti make a relay that don’t have the first flash delay and also has tap to turn.
https://led86.com.au/collections/86b...-flasher-relay |
#13 | |
A.K.A. Starlord
www.autowindow.com Here's a video I made to demmonste some of the features on my car (the approach and departure function was disabled during this demo.) [ame]https://www.youtube.com/watch?v=18w39RmVZjY[/ame]
#14 |
Your right if your in the states, you don’t see tapturn in oz.
| 2015 OEM Headlights, turn signals, side markers, reverse light, & Valenti tail lights | Vinsanity091 | Exterior Parts (Aero, Lighting, Etc.) | 4 | 06-11-2017 05:56 PM |
| Turn as tail timing not matching with the front turn signals | NahumCC | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-03-2016 10:40 PM |
| switchback turn signals with toms tailights | Celigts | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 02-18-2015 11:51 PM |
| WTB: Front turn signals (FR-S) | sirsol66 | Want-To-Buy Requests | 2 | 12-16-2014 03:20 AM |
| smoked front turn signals | dawnst3ar | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 05-21-2013 08:17 PM |
