Old 05-28-2018, 04:04 PM   #15
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Definitely a bailer lol
One post and poof! Ninja style!
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 05-28-2018, 05:18 PM   #16
Grey86
Grey86's Avatar
Drives: Tornato grey 86
I have many chips on the side of the car that were caused by rocks that were thrown up. Even have about an inch long groove in the paint just below the rear side window on the passenger side that was caused by a rock big enough that I saw it coming. Cars and trucks can and do throw rocks out at weird angles.
Been in AUS passenger side is facing away from other cars driving by so realistically my driver door should have it, but i see where you're coming from.
Grey86 is offline   Reply With Quote
Old 05-28-2018, 05:21 PM   #17
Mine was on my passenger side as well and it still faces away from the other cars just in the opposite direction. Was a stone thrown up by a truck I was passing.
Old 05-28-2018, 06:08 PM   #18
Mine was on my passenger side as well and it still faces away from the other cars just in the opposite direction. Was a stone thrown by a truck driver I was passing.
FIFY, Mario.
Old 05-29-2018, 08:18 PM   #19
staplesja
Drives: 2017 Subaru BRZ
Wow - sorry _ as you may have realised I'm not a forum regular and obviously need to check this more often !
Thanks kindly for all the responses.
I have uploaded a pdf attachment with photos of the defect areas for reference.
Sounds like I'm not the first to have BRZ/86 paint problems. For such a generally high quality brand as Subaru / Toyota I'd be very surprised if they don't investigate this for their own QA regardless of how my case ends up.
Cheers - and sorry for slow reply !
staplesja is offline   Reply With Quote
Old 05-29-2018, 08:23 PM   #20
Those are certainly not the chips the rest of us are talking about. There is almost guaranteed to be an outside influence causing that. Do you live where there are a lot of seagulls?
Old 05-29-2018, 08:24 PM   #21
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
That's a paint defect.. not rock chips
VIP BRZ is offline   Reply With Quote
Old 05-29-2018, 09:17 PM   #22
staplesja
I certainly think it's a defect.
Even if it is an 'outside influence' (and I realise this next question is difficult to answer) what should a consumer 'normally' expect from the product?
I.e. what should the paint be able to withstand w.r.t. bird liming etc. I repeat that I just can't accept that my car has so many severe defects spread all over the bonnet and roof after just 123 days and 1,200km. It seems totally ridiculous.
In terms of seagulls - no - I don't live near the coast. I'm in a region of Australia that does have possums; however, my wife has a new Mazda CX-5 and this is parked next to the BRZ in our driveway. Her car has no such damage - which suggests it's not some animal causing it as you would expect damage to both cars.
Old 05-29-2018, 09:59 PM   #23
highway7
Drives: FRS 2013
It's definitely a defect, there's no way a cluster of rocks can hit the same place like that. Possibly vandalism? Brake fluid will destroy paint and looks just like water.
highway7 is offline   Reply With Quote
Old 05-30-2018, 01:12 AM   #24
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Take it to a body shop and ask them for an opinion. You may be able to use that to fight back cause that is not normal.
Old 05-30-2018, 01:33 AM   #25
Let us know how this pans out.
Old 05-30-2018, 01:45 AM   #26
staplesja
Yes - I'm seeking a written qualitative opinion from a paint specialist (in addition to the other quantitative tests I'm seeking) - I plan to send this along with I'm story / photos to Subaru Global in Japan. Even if this isn't resolved in my favour in Australia - I sincerely hope that Subaru International look at it seriously as part of its normal QA.
I will def let you know where this ends up - but I suspect it has a few months to run yet.
Thanks again for your comments.
Old 05-30-2018, 01:49 AM   #27
Ya, @staplesja , I'm also thinking along these lines.
I reckon that either the paint wasn't applied properly when the car was first painted …. or someone threw some chemical on your car that ate through the paint.
Did this happen gradually or over a period of time …. ??
Either way, about the only fix is to have the car repainted.
Come back.
Old 05-30-2018, 09:47 AM   #28
atomicalex
Drives: 2018 BRZ Limited Perf Pack
@staplesja Do you have the hi-res images? I have having trouble seeing the subsurface. This looks like a problem with the primer, but I can't really tell what I am looking at except splotchy paint. Also would like to see a pic of the entire car.
Please find a multimeter and check the resistivity of the surfaces. Use the barrel of the probe, not the tip, as the tip can do damage. Please report for the grey surfaces and for the intact paint surfaces against body ground in ohms.
<-- works in the pretreatment industry, knows marginally more than the average bear about this crap
atomicalex is offline   Reply With Quote
Paint defect FROM DAY OF DELIVERY! Raven_FR-S Issues | Warranty | Recalls / TSB 22 03-12-2015 09:46 PM
Paint expert opinion needed, paint defect or rocks? ducky369 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 02-08-2015 03:54 AM
Paint chip or paint defect? please help. BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 11 01-16-2015 09:30 PM
factor paint defect, should i repair it or leave it alone? tracerit Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 03-30-2013 10:38 PM
Driveline Defect skoodge Issues | Warranty | Recalls / TSB 0 01-18-2013 12:16 AM
