#435 |
Drives: FT86
#436 | |
Drives: Toyota GT86
K00G
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
| The Following User Says Thank You to elBarto For This Useful Post: | tomm.brz (05-24-2018) |
#437 | |
Drives: frs
#438 |
Drives: Hyper Blue BRZ
Hi all, does anyone know and can provide the Engine Load Limits on OTS 4.0 maps ?
#439 |
Drives: FT86
#440 |
Drives: Taco
Awesome. Thanks for the info.
Another question came to mind. I'm considering the Jackson Racing Supercharger kit with the Factory Tuned version for CARB reason because I'm from California. So my question is: is it possible to use the ecutek to save the JRSC CARB tune AND an E85 tune to switch on the fly or is that not possible and will require a complete reflash to go from tune to tune? I read a bit on piggyback tuning but not sure if it'll help with what I'm trying to achieve. |
#441 |
#442 | |
Drives: UK GT86
.: Stealth 86 :.
#443 | |
Drives: FT86
Maybe im not understanding what your trying to do but as the carb tune is a legal tune i reckon with al!ost 100% certiantly it will be locked so you cannpt fiddle with it since its emmissions legal. Also i doubt the carb tune is flex. Also map switching between petrol and e85 of varing content would be pretty dangereous on forced induction you rearly need full flex fuel setup especially in usa The best you could do would likely be have the carb tune as a backup and get a full flex fuel tune from a tuner. When its emissions time flash in the carb tune |
| The Following User Says Thank You to steve99 For This Useful Post: | Teseo (05-26-2018) |
#444 |
Drives: '17 PP BRZ
Would anybody know why I'm getting a weird rasp/rattle for the first few minutes upon starting the car, in the 3-5k range. At first I thought it was the engine being cold but it happens when it's warmed up too. I took everything apart and retightened it all so nothing is loose. All mods are in my sig
FT86 Speed Factory Catted UEL Headers, Motiv Overpipe, Ark Test Pipe, Ark Grip Exhaust, GrimmSpeed Intake, V4 Stage 2 OFT Tune, Illusion Red Powdercoated Enkei Raijin 18x8 Squared, Eibach Pro Springs, MTEC Clutch Spring, Audio Upgrade, Random Accessories
#445 | |
Drives: brz 2017 hksv2
You can try but it run shitty on our car. I like more the b01c settings Last edited by tomm.brz; 05-26-2018 at 10:44 AM. |
#446 |
hey steve99
i downloaded the library file for rom raider, but missing the actual bin map so cant even use the library. missing the A01G files, only have the C files for US please post the actual engine load if possible |
#447 |
you re not trying to be lazy, but you are : )
steve wrote also how to edit the defs the engine load limits on v2 and v4 ots maps are same as stock 800 \ 0,88 1000 \ 0,90 1200 \ 0,89 2000 \ 0,92 2200 \ 0,92 2400 \ 1,07 2500 \ 1,11 3000 \ 1,10 3200 \ 1,3 |
| The Following User Says Thank You to tomm.brz For This Useful Post: | neilvosko (05-28-2018) |
#448 | |
Drives: FT86
If your not seeing load limit tables in romraider is because the definition doesnt reference those tables. All tables are in all roms, its just the definitions that index into the rom may not have some tables defined. If you need stock roms do to the tactrix info link in signiture below it has most of the stock roms at end of post. |
| Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Software Tuning | 130 | 08-25-2020 07:29 AM |
| The latest EU/AU OFT tunes (D00G) don't come with launch control | jamesev93 | Software Tuning | 4 | 03-12-2018 04:14 PM |
| Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Engine, Exhaust, Transmission | 3 | 08-27-2016 02:04 PM |
| ***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes | Garrett@Openflash | Engine, Exhaust, Bolt-Ons | 54 | 06-11-2014 06:29 PM |
| OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) | Rombinhood@OpenFlash | Software Tuning | 237 | 02-10-2014 03:35 PM |
