Old 05-24-2018, 06:20 PM   #435
steve99
Drives: FT86
Originally Posted by 86_Life View Post
Do most people run Openflash on the stock/factory ECU? is a stand-alone ECU necessary if I wanted to save more than one tune to change on the fly?
No you can run ecutek and have map switch on stock ecu ,4 maps
Old 05-24-2018, 06:25 PM   #436
elBarto
elBarto's Avatar
Drives: Toyota GT86
Originally Posted by tomm.brz View Post
If there is only a01g he would still need to modify a real k00g map to include those v4 tables in it
A01G was an example. All the others are also available.
K00G
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
The Following User Says Thank You to elBarto For This Useful Post:
tomm.brz (05-24-2018)
Old 05-24-2018, 07:45 PM   #437
Teseo
Drives: frs
Originally Posted by Jasonb View Post
From everything I've read, even the stock tune knocks quite a bit. And I've also read that the engine should protect itself just fine. That's what IAM and flkc are for. To me it seems totally random as to when and where it knocks. I'll go weeks where my IAM will not drop at all, then all of a sudden it'll show a lil bit of knock, then in the same exact load range with the same type of driving the IAM will quickly rise right back to 1.
Thanks mate, asking because i have blend 93 oct (10% ethanol) available but more cheaper than pure 93oct. So i wanna know if someone had bad reaction with that type of gasoline
Old 05-24-2018, 08:10 PM   #438
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
Hi all, does anyone know and can provide the Engine Load Limits on OTS 4.0 maps ?
neilvosko is offline   Reply With Quote
Old 05-24-2018, 08:24 PM   #439
steve99
Drives: FT86
if you 2012-2016 car defs in fist post have load limit tables
Old 05-24-2018, 10:06 PM   #440
86_Life
Drives: Taco
Awesome. Thanks for the info.
Another question came to mind. I'm considering the Jackson Racing Supercharger kit with the Factory Tuned version for CARB reason because I'm from California. So my question is: is it possible to use the ecutek to save the JRSC CARB tune AND an E85 tune to switch on the fly or is that not possible and will require a complete reflash to go from tune to tune? I read a bit on piggyback tuning but not sure if it'll help with what I'm trying to achieve.
86_Life is offline   Reply With Quote
Old 05-25-2018, 12:28 AM   #441
neilvosko
neilvosko's Avatar
I am not trying to be lazy, just unable to open them, could someone post a screenshot of them please!
Old 05-25-2018, 02:28 AM   #442
Kodename47
Kodename47's Avatar
Drives: UK GT86
Yes. I think it's time to do some research
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-25-2018, 04:30 AM   #443
steve99
Drives: FT86
Maybe im not understanding what your trying to do but as the carb tune is a legal tune i reckon with al!ost 100% certiantly it will be locked so you cannpt fiddle with it since its emmissions legal.
Also i doubt the carb tune is flex.
Also map switching between petrol and e85 of varing content would be pretty dangereous on forced induction you rearly need full flex fuel setup especially in usa
The best you could do would likely be have the carb tune as a backup and get a full flex fuel tune from a tuner. When its emissions time flash in the carb tune
Teseo (05-26-2018)
Old 05-25-2018, 07:24 PM   #444
texastwurkt3am
texastwurkt3am's Avatar
Drives: '17 PP BRZ
Would anybody know why I'm getting a weird rasp/rattle for the first few minutes upon starting the car, in the 3-5k range. At first I thought it was the engine being cold but it happens when it's warmed up too. I took everything apart and retightened it all so nothing is loose. All mods are in my sig
FT86 Speed Factory Catted UEL Headers, Motiv Overpipe, Ark Test Pipe, Ark Grip Exhaust, GrimmSpeed Intake, V4 Stage 2 OFT Tune, Illusion Red Powdercoated Enkei Raijin 18x8 Squared, Eibach Pro Springs, MTEC Clutch Spring, Audio Upgrade, Random Accessories
texastwurkt3am is offline   Reply With Quote
Old 05-26-2018, 10:34 AM   #445
tomm.brz
Drives: brz 2017 hksv2
Originally Posted by JIM THEO View Post
I am not going to try many different maps as I'll do my own remap on the dyno, just want to know from you that have already experienced what is the best base map I could use from the available V4 maps as it seems they are a good compromise between power gains, smoothness and fuel consumption in daily basis.
What is your opinion Steve99?
So the eu v4 is just a usa v4 hacked back to eu
You can try but it run shitty on our car. I like more the b01c settings
Old 05-26-2018, 04:14 PM   #446
neilvosko
neilvosko's Avatar
hey steve99
i downloaded the library file for rom raider, but missing the actual bin map so cant even use the library. missing the A01G files, only have the C files for US
please post the actual engine load if possible
Old 05-26-2018, 04:40 PM   #447
tomm.brz
you re not trying to be lazy, but you are : )
steve wrote also how to edit the defs
the engine load limits on v2 and v4 ots maps are same as stock
800 \ 0,88
1000 \ 0,90
1200 \ 0,89
2000 \ 0,92
2200 \ 0,92
2400 \ 1,07
2500 \ 1,11
3000 \ 1,10
3200 \ 1,3
neilvosko (05-28-2018)
Old 05-26-2018, 05:56 PM   #448
steve99
Drives: FT86
hey steve99
Im not sure what you want
If your not seeing load limit tables in romraider is because the definition doesnt reference those tables. All tables are in all roms, its just the definitions that index into the rom may not have some tables defined.
If you need stock roms do to the tactrix info link in signiture below it has most of the stock roms at end of post.
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Software Tuning 130 08-25-2020 07:29 AM
The latest EU/AU OFT tunes (D00G) don't come with launch control jamesev93 Software Tuning 4 03-12-2018 04:14 PM
Openflash FLEXFUEL OTS Tunes! Shiv@Openflash Engine, Exhaust, Transmission 3 08-27-2016 02:04 PM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 06:29 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 03:35 PM
