Old 05-19-2018, 03:54 PM   #18929
Leonardo
Country Boy 4 Life
Leonardo's Avatar
via Imgflip Meme Generator
Took one hour to take off my bumper, drill 6 holes, install quick latch, and reinstall bumper!! Hell yeah!!
Thank you @BirdTRD Great DIY
And the "Beer" pic!!! lol. Lemon/lime radler, dont knock it till you try it!!!
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
BirdTRD (05-19-2018), Spuds (05-19-2018)
Old 05-19-2018, 04:43 PM   #18930
Originally Posted by pcguru2000 View Post
You are absolutely right. To make sure that the car is used properly, it needs to be raced. ............
OK, pcguru2000, I took your advice and raced up to Walmart.
You should have seen those old coots, pushing their walkers, scatter, when I drifted into the parking lot ......
Leonardo (05-19-2018), pcguru2000 (05-21-2018)
Old 05-19-2018, 08:40 PM   #18931
Leonardo
Country Boy 4 Life
Leonardo's Avatar
So I have been having so much fun working on my car today, I decided to flush the brakes too! New fluid!!!
I LIKE TIRES!
humfrz (05-20-2018)
Old 05-20-2018, 11:14 AM   #18932
arxm
Drives: 2013 FR-S, 2023 BRZ
does everybody hate on the sbd500x because its apparently a rip off of the greddy or whatever or does it have actual issues, im so torn between turbo or sc. I keep telling myself im gonna want 500+ hp so i should just turbo but deep down i know ill stop at 300 so sc is better, sheesh twin problems lol
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 05-20-2018, 09:23 PM   #18933
notout86
Drives: GTS 86 auto
yes, increases air flow 72%
My plate is central over the lower part of the grille, PLUS I have fly-wire mesh with 1.2mm square holes to keep bugs off the radiator. It does not overheat ,ever, even on a day of 40 degrees Celsius. I wouldn't have the mesh with an intercooler.
Having the plate off-center would mess with the aerodynamics and cause different drag left-to-right and cause the car to go in a circle?
GTS86 Auto (Australia)
The Following User Says Thank You to notout86 For This Useful Post:
MJones_RB (05-22-2018)
Old 05-20-2018, 09:26 PM   #18934
notout86
Drives: GTS 86 auto
Originally Posted by Grady View Post
Depended on what state your plate came from. 72% is the average. I think texas plates only block 60% of the airflow where California plates block 90%.
Thinking laterally about this important topic, why don't plates come perforated?
Old 05-20-2018, 09:30 PM   #18935
Brink
Drives: 2017 BRZ
Car doesn't go in a circle as long as you have your alignment done to offset it. The drag from the off-center plate makes it pull right so you need a little toe out on the left front wheel, and a matching amount of toe in on the right, so they both point to the left a bit.
Brink is offline   Reply With Quote
The Following User Says Thank You to Brink For This Useful Post:
notout86 (05-20-2018)
Old 05-20-2018, 09:40 PM   #18936
notout86
Drives: GTS 86 auto
I thought of that but to get the alignment right you'd need to do a dynamic alignment that varies with air speed.
Ultimate idea is an holographic plate projected. Top that if you can smarty!
Old 05-21-2018, 02:06 PM   #18937
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Originally Posted by johan View Post
Just replace the grill, they're not that expensive.
https://parts.olathetoyota.com/oem-p...le-su00301532/
Thanks.
Upon further research It turns out that part# is for the 13-16 cars, and not the 17+. The photo shows the 17 grill, which is misleading.
The 2017+ grill #SU00306844
https://parts.rosevilletoyota.com/p/...U00306844.html
Old 05-21-2018, 03:53 PM   #18938
jordan7831
Drives: 2016 Halo FRS
Today was nice and sunny so I put on the rims I bought a little while back ago.
Rims are replica Audi, 5X100, 17X7.5 Inch, +35MM Offset, riding on 225/45/R17 tires.
Thoughts?/validations?/Offers to buy them right from me because they are so sweeetttt... Lol
jordan7831 is offline   Reply With Quote
The Following 3 Users Say Thank You to jordan7831 For This Useful Post:
mrg666 (05-21-2018), Pbrown (05-21-2018), SuperTom (05-21-2018)
Old 05-21-2018, 04:19 PM   #18939
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
They look better than the OEM 13-16 wheels!
Originally Posted by humfrz
I'm old and lazy
jordan7831 (05-21-2018)
Old 05-21-2018, 04:20 PM   #18940
pcguru2000
pcguru2000's Avatar
Drives: toyota 86 2017
Gotta do the drift into the handicap parking spot!
Were the younger ones asking you to make the car bounce? I was in a Christmas parade in a pace car and the younger folks would yell that request out. Somehow, they thought the pacecar should have 16 switches and big sub-woofers.
pcguru2000 is offline   Reply With Quote
Old 05-21-2018, 06:47 PM   #18941
Pbrown
Drives: 2013 Scion FRS Raven
Got some new tires for her
Did the tire lettering thing as well. First ones lasted 3 summers.
Pbrown is offline   Reply With Quote
Old 05-21-2018, 06:53 PM   #18942
Nah, after the younger ones saw me hit that speed bump at 50 MPH, they all scattered ….that's all the bouncing they wanted to see out of my car …...
