Old 05-17-2018, 11:43 PM   #267
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Looking to confirm ECU part number on a q3 BRZ limited 6 speed?
Jmonty is offline   Reply With Quote
Old 05-18-2018, 12:00 AM   #268
alxtheoreo
alxtheoreo's Avatar
So I got my car back today. I filed a formal complaint to Toyota Corporate three weeks ago when this issue occured & they help tremendously with lowering the price of the repair. I greatly appreciate their customer service.
Overall, the dealership only replaced ONE cam sprocket, and they did a bad job of re-sealing the front end of the engine. I was able to drive no more than 5 miles away when my TCS, CEL & battery lights came on. I then noticed a considerable amount of smoke from behind the car & flowing up under the hood. I immediately pulled over & shut the car off. I got on the ground & it was pouring oil. After some phone calls, I had it towed back to the dealership & they gave me another rental.
At this point, I can't trust these mechanics at this dealership anymore. I'll be making calls to the service manager & Toyota Corporate. I believe I need a new engine, or a new car, or some sort of money to cover the value of my FRS.
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
alxtheoreo is offline   Reply With Quote
Old 05-20-2018, 11:45 AM   #269
EigenGuy
I purchased two of 22765AG511 from ebay to use in my 2013 MT BRZ. Both came out of wrecked cars with about 30k miles. I used Techstream to change the VIN numbers. Theres a good write up on the swap on here.
EigenGuy is offline   Reply With Quote
Old 05-23-2018, 01:40 PM   #270
TheStig85
Drives: 2013 Subaru BRZ
Any reason I'd still get the P0016 code even after replacing the cam gear sprockets? I've swapped OCVs and Sensors around in the past. Or does it take some mileage for the ECU to remove this code permanently?
Sent from my Pixel 2 XL using Tapatalk
TheStig85 is offline   Reply With Quote
Old 05-23-2018, 01:43 PM   #271
alxtheoreo
alxtheoreo's Avatar
From what I've read & experienced, you'll need to replace the ECU.
Old 05-23-2018, 01:43 PM   #272
TheStig85
Did that before I replaced the sprockets. Hence my confusion!
Old 05-23-2018, 01:56 PM   #273
Hmmm... This is where techstream and the manual slew function would come in handy. The servos can individually be toggled to check them. It's really handy.
BTW, I heard from my friend that moved. He went back to driving it and hasn't had any issues since we last exercised the spool valve.
Old 05-23-2018, 07:22 PM   #274
TheStig85
These are new sprockets. I'll attempt to massage them later and double check the sensor/OCV. Being a complete noob though, how hard would it be to get techstream and use it to view and adjust any values?
Old 05-23-2018, 08:53 PM   #275
ermax
ermax's Avatar
P0016 on a 60k mile car
Techstream can’t fix your problem, it’s simply for diagnostics. What Techstream allows you to do is manually advance or retard the timing for testing purposes. There is a TSB around here somehwhere that basically tells you to advance the cams until the car stalls which proves that they are at least working.
You can get an OBD2 adapter that is compatible with Techstream on amazon for $18. Some of these cables come with Techstream but normally older releases. It’s not had at all to locate the latest release with google. The software is easy to use and is a great tool to have. The Tactrix cable works with Techstream if you happen to have their cable.
The Following User Says Thank You to ermax For This Useful Post:
Ultramaroon (05-23-2018)
Old 05-23-2018, 10:29 PM   #276
^^^ Exactly. It has become an essential diagnostic tool. I was stupid. I already had the Tactrix and bought another j2534 device before I learned any better.
Old 05-23-2018, 11:10 PM   #277
TheStig85
Techstream work with a BRZ? I was hearing otherwise from local guys.
Old 05-24-2018, 12:19 AM   #278
Yes, it does. My friend's is a 2013 BRZ with EcuTek.
Old 05-27-2018, 01:38 AM   #279
kinghurl
Drives: BlueBurz
It will take many(as many as 5K per Subaru Tech line) for the ECU to relearn. You'll continue to throw the code and the ECU will use a fixed value for the cam gears(loss of power). This happens even before the code is thrown(CEL), as long as it's a pending code. Experienced this first hand and finally changed the ECU. No issues since.
kinghurl is offline   Reply With Quote
Old 05-29-2018, 03:39 PM   #280
TheStig85
Okay, quick rundown of what I've done.
  • Got P0016 code
  • Swapped Sensor, nothing.
  • Swapped OCV, nothing.
  • Massaged Plunger on Cam gear, nothing.
  • Replaced ECU, went away.
  • Few months pass and the code returns.
  • Tried swapping Sensors/OCVs/Massaging again, still nothing.
  • Pulled the motor and replaced all 4 Cam sprockets (found the doors on the back of the sprockets was loose) and both timing chains, nothing.
At this point, I don't want to buy ANOTHER ECU. Should I just buy new Sensor(s)? OCV(s)? Or rub my magic Genie bottle for a few more wishes?
P0016 fixable without new ECU? Mr.Jay Issues | Warranty | Recalls / TSB 8 02-06-2022 05:15 AM
P0016/P0017 cause AVOturboworld Issues | Warranty | Recalls / TSB 18 04-16-2021 11:09 PM
P0016 Code Shady195 Engine, Exhaust, Transmission 30 02-21-2019 02:31 PM
p0016 need help asap lol Issues | Warranty | Recalls / TSB 25 10-30-2018 03:49 PM
OFT P0016 and TSB question mmmcambelsoup Software Tuning 10 05-24-2017 09:24 AM
