Drives: 2015 FR-S - Ultramarine
Edelbrock Supercharger Install - Will not start, Cranks forever. I'm out of ideas.
So a quick summary-
Car is a 2015 FR-S (AT) Relevant Mods installed - Edelbrock Supercharger - Delicious Tuning Flex Fuel kit w/Edelbrock Dbox - UEL Header - Currently running w/stock injectors and fuel pump. (ID1050x injectors wouldn't fit without spacers and no point installing my fuel pump without the injectors.) - Fuel pressure in the lines leading up to the fuel rails. - Checked relevant fuses in the underhood fuse box, couldn't find anything blown. - I've checked all my harnesses as best I know. - Everything else turns on and works in the car, battery is good. - FF Basemap for stock injectors from Delicious Tuning on the ECU. Any help would be appreciated. Reddit thread: https://www.reddit.com/r/ft86/commen...fuel_kit_will/ Last edited by WinterWolf; 05-16-2018 at 01:50 PM. Reason: adding link |
#2 |
Check your grounds
#3 |
I posted in the other thread, but will cross post as well.
Is the tune for sure expecting the stock injectors? If it's scaled for the bigger ones you're not getting the right amount of fuel with the stock injectors.
| Tags |
| delicious tuning, diy, edelbrock supercharger, flex fuel kit, starting issue |
| Edelbrock Supercharger Install - Will not start, Cranks forever. I'm out of ideas. | WinterWolf | Issues | Warranty | Recalls / TSB | 12 | 05-26-2018 07:12 AM |
| Edelbrock needs an auto 86/BRZ for a supercharger install! | Lonewolf | Southern California | 0 | 06-22-2017 10:31 AM |
| Edelbrock supercharger potential | mitch t | Forced Induction | 37 | 01-13-2017 05:16 PM |
| EDELBROCK SUPERCHARGER | BRZFRSSTORE | Forced Induction | 1 | 12-05-2016 04:41 AM |
| Edelbrock E-Force Supercharger FRS/BRZ Install | Titanmotorsports | Forced Induction | 1 | 02-17-2016 11:24 AM |
