Old 12-07-2016, 10:07 PM   #1
mitch t
mitch t's Avatar
Drives: stx class lava frs
Edelbrock supercharger potential
Ok, so here is the question.
I'm currently running an Edelbrock supercharger kit, (which I am extremely happy with) in the as supplied configuration.
I would like to know how much more power I can make with this kit on the stock engine. is there a bunch more power waiting for me, or should I leave it alone?
mitch t is offline   Reply With Quote
Old 12-07-2016, 10:17 PM   #2
gramicci101
Off Topic
Are you looking for how much power the blower can make, or how much power the engine can hold?
Delicious made 420 whp on E85. It was a built engine, but it had the same compression ratio as stock.
http://www.ft86club.com/forums/showthread.php?t=112955
They recommend building the engine around 350 whp. People have made 5-600 on the OEM block, but I don't know how long that'll last.
The Following User Says Thank You to gramicci101 For This Useful Post:
why? (12-09-2016)
Old 12-07-2016, 10:17 PM   #3
D_Thissen
D_Thissen's Avatar
Some people are running 350+ on the stock motor with no headaches, some aren't so lucky. You could pick up some power buy running ethanol and that should be relatively safe. Unfortunately, there is only one way to find out how much power YOUR motor can handle.
The Following User Says Thank You to D_Thissen For This Useful Post:
why? (12-09-2016)
Old 12-08-2016, 08:11 AM   #4
bfrank1972
Drives: 2013 FR-S Argento
Answer: There's a bunch more power waiting for you, and you should probably leave it alone
bfrank1972 is offline   Reply With Quote
The Following 5 Users Say Thank You to bfrank1972 For This Useful Post:
BigFatFlip (12-09-2016), FRS Justin (12-12-2016), mitch t (12-08-2016), why? (12-09-2016), wparsons (12-09-2016)
Old 12-08-2016, 12:22 PM   #5
strat61caster
strat61caster's Avatar
You're in California, stick with the emissions legal setup you'll need in ~2 years when you get your first smog check. I don't know how available E85 is down South, up here it's more trouble than it's worth imo for a car that's daily driven.
I'd call up Delicious and see what they can get out of it with just a tune, iirc it's a noticeable step up, but keep it easy to revert back to CARB legal in an afternoon imo.
https://www.delicioustuning.com/node/483
Looking at this, 20hp from the tune, another 10+hp from downsizing the pulley, swap pulley back and reflash for smog, swap back for funsies. If you can put e85 in it you're up a total of 90hp from the regular CARB tune, but I don't know what it'll take to do it safely (injectors, flex fuel rig, heat management now that you're double stock power), how that'll fly during an emissions test, and I wouldn't push any more out of a stock block.
@whataboutbob is probably your best resource if you're still autocrossing it, seems nice enough, but I don't actually know the guy.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
funwheeldrive (12-08-2016), mitch t (12-08-2016), whataboutbob (12-09-2016)
Old 12-08-2016, 12:38 PM   #6
mitch t
mitch t's Avatar
Yea, what I'm looking for is the reliable power limit on 91 octane, with the stock engine internals. I do need to keep smog in mind, so I would like to avoid doing anything that is too hard to undo once every 2 years or so.
Interesting to see that folks are getting 400 plus from this supercharger unit, though. right now i am trying to build a company, so not too many spare $$ laying around, but its nice to see that the blower will be ready to make some pretty big power as soon as I can afford to build an engine for it.
is Bob running an Edelbrock? did he get rid of the Sprintex?
The Following User Says Thank You to mitch t For This Useful Post:
Old 12-08-2016, 02:55 PM   #7
strat61caster
Ah, I might be totally mistaken then, idk why
But yeah, sounds like a slightly smaller pulley and tune is what you're looking for, nice ~30-ish bump over CARB trim according to them. Maybe I misread and the smaller pulley is no bueno on 91, idk.
Good luck, nice to see someone thinking modestly and not another 'yo I NEEEED 300 whp, how do I get it'
ineedyourdiddly
Old 12-09-2016, 01:09 AM   #8
Bob runs an Ace A/350 header now. NA.
Old 12-09-2016, 01:41 PM   #9
mitch t
mitch t's Avatar
You might be giving me too much credit. 300 to the wheels does have a nice ring to it.
Old 12-09-2016, 07:08 PM   #10
whataboutbob
AutoX-10/10ths every run
Correct. I do have the Delicious FF kit so E85 does make a noticeable difference in power, even NA.
I sold my Sprintex (Innovate) kit. I'm not totally sure what the next boost solution will be but I'm shooting for 400WHP on a mustang on E85.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
mitch t (12-11-2016)
Old 12-09-2016, 07:13 PM   #11
whataboutbob
I'd leave the boost level the same and just get a Delicious Flex Fuel kit if you want to make a bit more power safely.
Build thread:Here
Old 12-12-2016, 12:18 AM   #12
mitch t
mitch t's Avatar
How was the FF kit to install?
I assume pump and injectors?
Man I really want to pick up another engine to build a little bit.
Do you have any thoughts on compression ratio, if I'm looking to go "big" , power wise?
Old 12-12-2016, 01:50 AM   #13
FRS Justin
Drives: 2013 Asphalt FRS
What do you call big and how much you want to spend????
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
wparsons (12-12-2016)
Old 12-12-2016, 10:17 AM   #14
wparsons
wparsons's Avatar
One thing to watch with a twin screw blower is how the tune works down low if you start cranking up the boost. A turbo or centrifugal blower will build boost linearly and not try to load up the engine too much at lower rpm. A twin screw blower can be much trickier to tune down low and can blow an engine easier even if the peak hp is the same.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Teseo (12-12-2016)
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
FS: BNIB Edelbrock Supercharger Avo1789 Engine, Exhaust, Bolt-Ons 52 02-03-2017 11:44 AM
EDELBROCK SUPERCHARGER BRZFRSSTORE Forced Induction 1 12-05-2016 04:41 AM
Review: Edelbrock Supercharger Kit NotSoJDM Forced Induction 153 02-25-2016 06:53 PM
Edelbrock supercharger is out. Need expert thoughts on it. stockysnail Northwest 125 09-04-2015 01:51 PM
