Old 05-15-2018, 06:04 PM   #1
Deorio
Drives: 2013 Scion FRS
Tighten my LCAs in the Air
I recently installed a set of TRD lowering springs and everything went quite smoothly. Its been a few days now and I just found out that you're supposed to torque the LCAs while the car is lowered onto the ground or preloaded with jacks.
I loosened the LCA to chassis bolt in order to slip out the rear struts. When I put in the new springs and replaced the struts, I just torqued the bolt while the car was in the air and hubs a little bit sunken. Is this going to kill my bushings? Should I jack her up and do it properly or does it even matter? Thanks
Deorio is offline   Reply With Quote
Old 05-15-2018, 06:36 PM   #2
Tristor
Tristor's Avatar
I've never messed with the suspension yet, but I do generally believe if you find yourself asking "Should I redo this properly", the answer is always "yes". If it's worth doing, it's worth doing right. Good luck.
Tristor is offline   Reply With Quote
Old 05-15-2018, 08:02 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
Deorio: also if you did install of those springs/struts/LCAs yourself, very probably you didn't also redid properly alignment by yourself?
I suggest to not just retighten when on ground, but visit some suspension shop and pay to check/do alignment instead of just lowering and re-tightening LCAs bolts.
One can DIY alignment with eg. strings method .. but it takes a lot of time and is major PITA. Better to pay some money and have pros relatively quickly dial right camber/toe on laser alignment rig while having some coffee.
Ultramaroon (05-15-2018)
Old 05-15-2018, 08:37 PM   #4
Deorio
That was the plan! But I won't be able to get into an alignment shop until the springs fully settle. Would my bushings be okay until then?
Old 05-15-2018, 09:28 PM   #5
Yes, they can tear. It's a valid concern. Rhino ramps are a godsend.
LOOKING FOR LCAs MrAsh2222 Canada Classifieds 2 04-17-2018 04:58 PM
Do you think I will need LCAs? FaDuck Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-06-2017 11:54 AM
question on SPC LCAs DuMa Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 01-05-2016 06:36 PM
How to tighten handbrake? Ocean-Grown 86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-31-2014 12:07 PM
AP Rear LCAs JDLAutoDesign Brakes, Suspension, Chassis 2 04-17-2014 03:43 PM
