Old 05-07-2018, 12:21 AM   #267
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Originally Posted by gtpvette View Post
I wish I knew. I was looking over dates,,, I pulled the original motor the tail end of July last year. Would of never thought it take this long. I suspect if I can get it done by July this year I'll be doing good.
It's funny,,, never thought it take this long.
Lol, I get it. I thought I would have been driving mine last summer.
ILLSMOQ is offline   Reply With Quote
The Following User Says Thank You to ILLSMOQ For This Useful Post:
gtpvette (05-07-2018)
Old 05-07-2018, 11:36 AM   #268
gtpvette
Drives: 2015 FRS - FFR GTM
Good news,,,, Driveshaft will be ready this week!!
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
The Following 3 Users Say Thank You to gtpvette For This Useful Post:
DustinS (05-07-2018), ILLSMOQ (05-07-2018), Sportsguy83 (05-07-2018)
Old 05-07-2018, 12:05 PM   #269
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
It takes a lot longer to put something together that is well thought out and works under any reasonable driving condition than it does to just slap something together for show-only.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following 2 Users Say Thank You to venturaII For This Useful Post:
gtpvette (05-07-2018), ILLSMOQ (05-07-2018)
Old 05-08-2018, 03:29 AM   #270
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Hofstadter's Law: It always takes longer than you expect, even when you take into account Hofstadter's Law.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
JazzleSAURUS (05-31-2018), venturaII (05-08-2018)
Old 05-08-2018, 10:53 AM   #271
gtpvette
Amen to that. If I might add ,,,,, it costs more as well.
Old 05-09-2018, 08:40 AM   #272
gtpvette
And speaking of costs,,, for those that may be interested,,, attached below is the costs so far. We're at $7,129.47. Please note I may have missed a few items but if so not many. As there still is some larger ticket items left,, looks like $8K (not $6500) might be a better estimate when all is said and done.
The Following User Says Thank You to gtpvette For This Useful Post:
Ultramaroon (05-09-2018)
Old 05-09-2018, 02:49 PM   #273
I paid twice as much for my shitty, beat up spare transmission.
Old 05-13-2018, 03:59 PM   #274
gtpvette
Doing some research today,,,, rear gears. Way back when (see page 3 lol) I did research on the transmission ratios,,, FRS versus the Camaro MV5.
The Camaro setup is quite a bit different than the FRS. 1st gear (4.48),, and to an extent 2nd (2.58) in the Camaro is way more than needed. Couple that with the fact the Camaro had a 3.27 rear end ratio and a 2" taller tire,,, my current rear gear will be way out of wack.
If I'm reading the other threads correctly, Weir Performance has a 3.58 gear that'll get me pretty close. With a max speed just below the FRS in 1st and 2nd,,, it should hit it pretty hard off the line,,, but cruise well at 75MPH.
First pic is stock running gear on left,, on the right V6 Camaro running gear and 3.58 rear gear. Second pic is V6 Camaro running gear and stock 4.10 rear end.
Old 05-14-2018, 01:06 PM   #275
ILLSMOQ
Not sure what ratios are availble for the stock rear end but 3.58 looks like it gets you to a good place. That Camaro transmission has some wide gear splits doesn’t it?
Old 05-14-2018, 02:28 PM   #276
gtpvette
I reached out to Weir to see what the options are. Frankly something numerically lower (I.E. 3.2x) might even be better. The Camaro trans ratios are a bit strange. I guess getting the weight of the Camaro moving in 1st and 2nd leads to those ratios.
Should of gotten the CTS transmission....
Old 05-14-2018, 03:18 PM   #277
ILLSMOQ
I like how 3.58 looks on paper compared to taller and shorter gears...I think if you switch to a gear numerically lower than the 3.58, your higher speed performance will suffer. I’m thinking if it were me, I’d leave the 4.10 in place until you’ve had a chance to drive it and then decide where the performance is lacking....also, instead of changing the diff maybe you look harder at switching to that other transmission if the ratios are an improvement.
Old 05-14-2018, 04:24 PM   #278
venturaII
venturaII's Avatar
If you could take gears 1, 2 and 3 from the FRS, and combine them with 4, 5 and 6 of the Camaro 'box, you'd be good with the stock 4.10s. Or you could make a less drastic change to 3.73, and have the V6 turning a little more relaxed speed...
EDIT: Of course, this is all in Imaginationland...lol
Old 05-14-2018, 06:31 PM   #279
AJPG
Drives: 22RE, FA20, 4G63
That could be done! It will be the frs gear box. The 4, 5 and 6 gears are almost identical on both.
AJPG is offline   Reply With Quote
Old 05-14-2018, 06:38 PM   #280
AJPG
True curiosity, not trying to be a troll.
Why not to use the OEM gear box?
I have read completely and is one of the best swap treads, as recorded and details. About engine selection I’m in! Reliable, strong, tons replacement parts, good prices.
Should I have just got a new motor? SoundsOfTheUniverse Issues | Warranty | Recalls / TSB 12 07-31-2017 08:51 PM
Seized motor!! What STX mods should I do while I have the motor out?? BlaineWasHere Tracking / Autocross / HPDE / Drifting 27 12-11-2014 03:39 PM
K2 Motor? Ronin Sascha Engine, Exhaust, Transmission 8 08-16-2014 07:51 PM
Does every motor say #1 sosick Engine, Exhaust, Transmission 21 05-05-2014 10:28 AM
MOTOR UNION David Southern California 0 06-22-2013 02:32 PM
