Old 05-14-2018, 04:48 PM   #15
tomm.brz
Drives: brz 2017 hksv2
yes if you open the hood is pretty violent noise but from the cabin it just sounds as crickets
Old 05-14-2018, 04:58 PM   #16
Originally Posted by tomm.brz View Post
mm nope. idle when hot it uses only DI.
cold start it does DI PI together, then switch quit fast to ONLY PI during warm up, then switch to normal idle and use only DI
after 191 flash on my brz i learnt this too good to be wrong
you can see the Pi to DI % maps to check that at idle load it doesnt use PI
can t trll you right now what is louder from outside, but from inside the cabin of my my17 i hear louder clicks when only the DI is used
Yep. Sorry I used some bad phrasing there. By "together" I didn't mean both at once just by switching back and forth that they are work "together" to deliver what the car is asking for. They are working together independently.
Old 05-14-2018, 05:24 PM   #17
tomm.brz
mmm i don t really like the word "independently" but yes they work together based on the percentages written on those tables
Old 05-14-2018, 11:28 PM   #18
Decep
Drives: 2013 FR-S Series 10
gotta love that diesel-like injector clatter.
Old 05-15-2018, 12:21 AM   #19
churchx
churchx's Avatar
Drives: 2014 GT86
Is that noise injectors or high pressure fuel pump, whose chirping noise been brought up here few times? For me it is not enough an issue to care about though, til it's nothing wrong mechanically or electric, and if it's not affecting performance or life of engine. Just a trait of car to get used to.
Old 05-15-2018, 12:50 AM   #20
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Wow that's an oxymoron if I've ever seen one.
The Following User Says Thank You to Spuds For This Useful Post:
tomm.brz (05-15-2018)
Old 05-15-2018, 02:17 AM   #21
Hey, Spuds, @Tcoat is getten long in tooth ...... cut him some slack .....
Old 05-15-2018, 05:50 AM   #22
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I'd never get out of the driveway.
It'd be pretty difficult to drive out of your driveway while listening to your engine with a stethoscope. If you pull it off, post a video.
guybo is offline   Reply With Quote
Old 05-15-2018, 06:06 AM   #23
LOL Yes that was indeed the intent.
Old 05-15-2018, 06:07 AM   #24
Nope. The fuel pump is a whole different set of noises. More like and old V belt that has hardened up.
Old 01-02-2020, 12:49 AM   #25
73TORANA!
Drives: Orange GTS
Hi all, there does seem to be lifter noise when hot but if you bring the idle up to around 1500 then turn the engine off it is considerably quieter as the engine runs down indicating to me that it does have a lot of injector noise.
73TORANA! is offline   Reply With Quote
The Following User Says Thank You to 73TORANA! For This Useful Post:
Tristor (01-03-2020)
Where is the idle air control valve on our cars? devtec Engine, Exhaust, Transmission 5 07-05-2017 02:58 AM
Clutch chatter or nah? kt45 Issues | Warranty | Recalls / TSB 2 10-09-2016 12:27 AM
Bad Idle, stalling, clutch chatter, gear lockout, failed clutches: My story and fix Pneub Engine, Exhaust, Transmission 11 08-05-2016 10:29 AM
Valvetrain chatter on KW SC FRS nlowell Issues | Warranty | Recalls / TSB 4 05-03-2015 11:20 AM
Flywheel Chatter samisons Issues | Warranty | Recalls / TSB 13 12-05-2014 09:30 AM
