Old 05-11-2018, 01:54 PM   #1
davidsn_670
Drives: 2015 Scion FRS
Squirrels, rats or critters in engine bay solution!
As stated in the title, I have found a way to prevent most critters away from chewing, or nesting in the engine bay all year round. I have tried dryer sheets, traps and mothballs. All of them failed and stunk really bad. So I used Tomcat Aerosol spray https://www.homedepot.com/p/Tomcat-1...0605/302683092. This does not stain the engine, does not stink or enters the cabin. You only need to use it once a month. Started applying this in January and a light coating on the entire engine and potential entry areas once a month. I have not seen a single branch/mud/dogfood/trash or chewed on component since then. Works for me and just wanted to share this idea with you! It does smell like peppermint/garlic when first applying but quickly goes away. I know it specifically says not to use it on the engine bay/ cars but I did and it works.
davidsn_670 is offline   Reply With Quote
The Following 2 Users Say Thank You to davidsn_670 For This Useful Post:
humfrz (05-11-2018), Tcoat (05-11-2018)
Old 05-11-2018, 02:46 PM   #2
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
I would be worried about this gumming up my engine..
theirs a reason they warn not to use it on wiring/ battery / engine (to save there ass)
some of the reviews even mention it being "sticky"
VIP BRZ is offline   Reply With Quote
Old 05-11-2018, 03:25 PM   #3
davidsn_670
I can see your concern but I don't see it happening unless you douche it on there, you know? So far with over 4 months of use engine bay is not sticky or collects dirts. When I say light coats, I mean light coats.. but again I can understand your concern. Thanks for the input!
Old 05-11-2018, 03:55 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I live chatted with Tomcat a few minutes ago. They are saying not to use it on engines because:
It is flammable.
They have not tested it on engines.
Liability reasons.
Sodium lauryl sulfate and sodium benzoate are pretty safe chemicals. the first is used in toothpaste and the second is a food preservative. The essential oils are self explanatory.
I had Norwegian rats in my engine bay...
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
davidsn_670 (05-11-2018), VIP BRZ (05-11-2018)
Old 05-11-2018, 03:56 PM   #5
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I just put a cat in mine.
Don't feed said cat.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 05-11-2018, 04:48 PM   #6
Did they have little Viking helmets?
chaoskaze (05-11-2018)
Old 05-11-2018, 05:15 PM   #7
Leonardo
Country Boy 4 Life
Leonardo's Avatar
No, not the one I caught one with a small bear-style trap that I chained/staked to the ground. It weighed 13oz and from nose to tail tip, stretched across the entire lid of a normal 33gallon trash can. like this one... Can't find my pic right now... Little crapping BASTARDS! My engine stunk for awhile. I have since moved out of the boondocks and no longer have a rat problem.
via Imgflip Meme Generator
I LIKE TIRES!
chaoskaze (05-11-2018), Tcoat (05-11-2018)
Old 05-11-2018, 07:16 PM   #8
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I Just wanna know if OP lives under a tree. Post a picture of your front yard!
*1 I didn't have tis problem when I used to live in the northwest. XD
*2 I did live in the middle of a neighborhood atop of a small hill.... so maybe that helped.
Back to topic, why not just spray it inside the wheel fender/By undercover & near wiper area....instead of the engine bay? It's not raining no more.
FS: Perrin 3" Intake, Torque Solution engine mounts jonesy Engine, Exhaust, Bolt-Ons 4 01-10-2017 05:03 PM
Rats in my FR-S KR-S Scion FR-S / Toyota 86 GT86 General Forum 55 01-01-2016 12:53 AM
Critters chewing on my car. feedbag Issues | Warranty | Recalls / TSB 9 03-30-2013 12:06 AM
rats or mice chewing under hood decoratordm CANADA 3 01-08-2013 04:36 PM
