#43863 | |
Got rejected from the place I wasted five hours interviewing at last week. Then today I had scheduled meeting with my boss and he flaked on me after forty minutes of me waiting and not hearing back from him if something had come up. Wooooo /s
Kinda ridiculous.
Instagram: @spike.grc
#43864 | |
The Dictater
Drives: '13 Red Scion FRS
Just wait till you get a temperature swing and it throws everything off. I get swings of 6% between summer and winter.
| The Following User Says Thank You to Spuds For This Useful Post: | Ultramaroon (05-09-2018) |
#43865 |
Oh can I go reply to his reply latest statement? Please. Please!
#43866 |
The Dictater
![]() Todas site specifically states the benefit is underdriving components and less inertia, but nothing about vibration. My redacted post said as much, gave an experimental procedure to prove the point and then reiterated my offer to do the math.
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | Tcoat (05-09-2018), Ultramaroon (05-09-2018) |
#43867 |
Glad it's not just me. I get so much "Pshhh, whatevs!" whenever I express concern about OTS tunes that I quit talking about it.
I don't want to turn it over to anyone because I'm not looking for maximum anything. I just want to get it to run as sweetly as possible on 92 octane and understand exactly how I changed the stock tune to get there.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (05-09-2018) |
#43868 |
Not to mention that isn't the ONLY thing they do to the engines. It is one small spec of the overall picture and not the reason people win races. Bolt on one part and you have yourself a race car! If it was only that simple.
| The Following User Says Thank You to Tcoat For This Useful Post: | Spuds (05-09-2018) |
#43869 |
Site Moderator
Drives: ichi 86 Project
Hahaha I read it. We only wait and see if he does make a new thread bout pulley or not. From there, I'm not doing anything about it in that thread. Cuz I'm not going to read one word in that thread.
On topic of this random thought, I'm kinda tempted to leave work early to get emission and registration done for my car (due this month)... or just procrastinate til 25th (which I've taken off) to do it. |
| The Following User Says Thank You to ichitaka05 For This Useful Post: | Tcoat (05-09-2018) |
#43870 | |
The Dictater
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | humfrz (05-09-2018), ichitaka05 (05-09-2018) |
#43871 | |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | ichitaka05 (05-09-2018) |
#43872 | |
Drives: 2017 Series Yellow BRZ
| The Following User Says Thank You to Azzudien For This Useful Post: | ichitaka05 (05-09-2018) |
#43873 |
Wayward Member
Drives: Hot Lava 86
So what you're saying is... If I do a full exhaust and tune, but ALSO add pulleys and a driveshaft, then I'll be driving a rocket ship?
#43874 | ||||
Drives: Toyota GT86
You just need 3 logs: 1) 3-4x WOT pulls from 2000 to redline in 3rd gear. 2) A log with 10x CL pull (<30% accellerator) from 1600 to 4500 rpm. Do them in different gears (2nd or 3rd), with different inclination (hills help but it's not a necessity) and different pedal pressure to reach into as many manifold pressures as possible. 3) A 20 min log with normal driving in different gears and speeds and without being too aggressive on the throttle. All logs needs to be done at the same temp. Don't make long frequent stops. It's the intake temp that needs to be the same. Best is around 69 deg F (20 c) as this is what the compensation tables are zeroed around. Thats all the easy part. Next is filtering the data to sort out crap. You want to use KN47's formulas to calculate an error % and change (delta) in MAF voltage over time (dV/dt). Sort on dV/dt less than 0.5 (excludes tip in errors) and error % less than 18 (excludes overrun). Sort on CL first, then OL. Use the log stats tab of vgi's tool, as it gives you much more control. Now you have a "raw" corrected MAF. The next challenge if filtering out things that are off and should be corrected else where, like wierd bumps in the curve. I use KN47's adaptation of 86inches tool which makes a logarithmical smoothing. Still it requires manual inputs and takes some practice to use. When all this is done, you proceed to step 2. Make the same kind of logs again, and this time apply the error correction to the "Engine Load Compensation" table. I will sort correct the bumps you sorted away in the MAF scaling. The thing is: You can hit the same MAF at e.g. 3600 rpm 0.5 MAP (manifold pressure) or e.g. 2400 rpm and 0.7 MAP... just as an example. The flow in the intake manifold may be different, so you will have different error % in the two areas for the same MAF value. So the same MAF value won't fit in both cases. Hence the ELC table to compensate for that. In short: You want to keep the MAF scale smooth and adjust bumps in ELC (kind of average them in MAF first so the ELC corrections can be kept as small as possible). You may want to go back and forth adjust MAF then ELC then MAF etc. Depending on how much practice you have sorting out which correction belongs where. This is just a fraction of all the steps that are involved in my process. To be honest I don't think more details will help. Because there is still an amout of "feel" you need to develop that you only get from practice. So the things you need to ask your self: - How good do I want my result to be? - How much time am I willing to spend doing it? - Would I be better off paying someone to do it? I'm not trying to discourage you in any way. But this is a steep learning curve and in my opinion a waste of time to learn to tune ONE car (unless you really like it as a hobby). Quote:
Also "scratch" is a stretch in any case as almost any tune is basically a light modification compared to the complexity of the stock ECU logic.
| The Following 5 Users Say Thank You to Tor For This Useful Post: | cjd (05-09-2018), humfrz (05-09-2018), Spuds (05-09-2018), Teseo (05-09-2018), Ultramaroon (05-09-2018) |
#43875 |
Famous Potatoes
Drives: '15 ultramarine
| The Following 3 Users Say Thank You to Sapphireho For This Useful Post: |
#43876 | |
Drives: 2017 BRZ
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 10:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
