Old 05-09-2018, 01:34 AM   #1
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
ENEOS RACING Series Pro/Street
Eneos's new line of oil just hits the market recently.
*atleast I didn't know about them till today.
Has anyone gave them a try yet? @viscositosis.rex @mav1178
http://www.eneos.us/products/eneos-racing-series/
Been using Sustina for the last 50k miles.... gonna give these bad boy a try next.
The Following 3 Users Say Thank You to chaoskaze For This Useful Post:
Bonburner (11-05-2018), NyC Zn6 (05-09-2018), snk828 (05-11-2018)
Old 05-09-2018, 02:42 AM   #2
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
I will try them out on my next oil change. I have been running Sustina from day 1.
The Following User Says Thank You to NyC Zn6 For This Useful Post:
chaoskaze (05-09-2018)
Old 05-09-2018, 01:16 PM   #3
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Interesting. Wonder if it's just marketing hype or worth trying. Currently using Eneos 0w-20.
Originally Posted by humfrz
I'm old and lazy
Old 05-09-2018, 06:35 PM   #4
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
ohhh yesss
Just try it with us it wont hurt.
The Following User Says Thank You to chaoskaze For This Useful Post:
NyC Zn6 (05-10-2018)
Old 05-09-2018, 07:21 PM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Lemme know where you end up ordering yours from and what variety you go with.
I'm old and lazy
Old 05-09-2018, 08:03 PM   #6
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
You can order them online at http://koruworks.com/search.php?sear...=eneos&Search=
They seem to be the only place online where you can order them already.
I will be getting mine at my local auto shop Uehara motor @ vegas, Been getting my supply from them for the last 4 years & they told me they will have the racing series in 2 weeks.
I just don't know what I wanna try first yet... another thing is that racing street is actually cheaper then sustina by a dollar every QT. so that's a saving of 6 dollars every oil change if they are just as good. :P
Clipdat (05-09-2018)
Old 05-09-2018, 08:10 PM   #7
Clipdat
Proud of BOXER
Clipdat's Avatar
There's a lot of marketing hype and buzzwords on the Eneos site regarding what is actually different between the Street and Pro versions. My tiny brain is having trouble figuring out which one is better.
I'm old and lazy
Old 05-10-2018, 09:46 AM   #8
bluesubie
Drives: 2004 Subaru Forester 2.5XT
No question that you’ll want to run the street version unless you have a 100% dedicated catless track car. The details aren’t out yet but I expect the track version to have higher ZDDP and no API or ILSAC certifications.
The street version has a nice shot of zinc for anti-wear and moly for friction modification. But phosphorus is low to get the API/ILSAC certification and to keep it cat friendly. It likely also has higher detergent levels.
NOACK volatility is within allowed limits but I’m surprised that it’s at 12% when the allowed limits are 15% and the better oils are closer to 10%. Probably due to the limitations of the Group III base stocks.
bluesubie is offline   Reply With Quote
The Following 5 Users Say Thank You to bluesubie For This Useful Post:
Bonburner (11-05-2018), chaoskaze (05-10-2018), Clipdat (06-15-2018), lextrueno (05-16-2020), Tristor (06-15-2018)
Old 05-11-2018, 11:56 AM   #9
wulfstan
Drives: 2014 Whiteout Monogram 6MT FR-S
Cool
I will be keeping an eye on this thread... I ordered the Sustina 0w20 as I always have and saw the Racing/Street... Opted to stay with Sustina 0w20...
Here are the spec sheets from the Eneos site between the two if that helps anyone. I've had no problems with the Sustina other than a lighter wallet, LOL.
Maybe someone more knowledgeable than I, can help dawn some light on the differences... I guess if I researched more, I could... but I know there are so many other "experts" out there.
And I ordered my last case from the site mentioned previously: http://koruworks.com/search.php?sear...=eneos&Search=
wulfstan is offline   Reply With Quote
The Following User Says Thank You to wulfstan For This Useful Post:
chaoskaze (05-11-2018)
Old 06-15-2018, 09:26 AM   #10
viscositosis.rex
Drives: Currently 2018 Taco
I have not tried this new ENEOS Racing Street oil yet.
Looking at the numbers, it appears to be a highly specialized oil, intended for short term performance, and not high temperatures.
I look forward to seeing your results.
vis.
viscositosis.rex is offline   Reply With Quote
Old 06-15-2018, 09:38 AM   #11
viscositosis.rex
My Blackstone VOA on Sustina 0W20 actually showed phosphorus content significantly higher than zinc.
I point to high density as a positive attribute.
It astounds me that these oils with VI's of 229 and 239 have NOACK's of ~12.
I have used Ravenol 0W16 for ~ 50k miles w/10k OCI. It is designed with a reasonable NOACK, low VI, ~ 40% ester content, and 2x Mobil 1 trimer moly. It is quite stellar. PLEASE report this to Shannow.
FWIW, my new favorite oil is Valvoline Advanced Full Synthetic 5W20. VI 147. NOACK 7.6. I am now in a marathon mindset, aiming for such things as clean piston rings at 500k miles !
It is hoped that this Valvoline oil is a bluesubie approved oil, although maybe a little thin for your taste.
Old 06-15-2018, 03:29 PM   #12
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
vis.
O.O Not for high temperatures? or just basically a track oil type thing?
Old 06-15-2018, 09:33 PM   #13
viscositosis.rex
I might change my mind if it can be substantiated that ENEOS used W Base here.
The VI of 239 suggests high dose VI improvers.
Read the product description.
Old 06-16-2018, 01:16 PM   #14
Teseo
Drives: frs
No 5w-30?
FS: NEW Megan Racing Street Series Coilovers Maste Brakes, Suspension, Chassis 8 08-07-2017 11:29 PM
Megan Racing EZ Street Series Coilovers Smiley Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 04-17-2017 01:26 PM
FS: SoCal: Megan Racing Street Series haloterence Brakes, Suspension, Chassis 2 04-05-2014 01:57 PM
Megan Racing street series review Drftfan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 09-18-2013 09:31 AM
Megan Racing Street Series Coilover Kit DeeJayMajesty Brakes, Suspension, Chassis 4 03-22-2013 05:59 PM
