Old 03-27-2014, 02:37 AM   #1
haloterence
haloterence's Avatar
Drives: 2013 whiteout fr-s
FS: SoCal: Megan Racing Street Series
Sold!
Megan Racing Street Series 32 Way Adjustable Coilovers.
I had these coilover professionally installed at Fuzion Technique about a month ago. Used for less then 1K miles. Selling because I'm not optimizing the uses of these coilovers. I have a very steep driveway and I can"t lower the car more then an 1".
Spanner wrenches and front sway bar links are included.
Here are the specifications and features copied from Megan Racing website.
SPRING RATES:
F: 62mm ID; 150mm length; 8 kg/mm
R: 62mm ID; 180mm length; 6 kg/mm
DAMPER SPECS:
F: 110mm stroke; 220mm length; M1 valving code
R: 95mm stroke; 180mm length; A11 valving code
- 32 Levels of Damper Force Adjustment
- Pillow Ball Upper Mounts
- Rubber Dust Boots
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
haloterence is offline   Reply With Quote
Old 03-30-2014, 08:46 PM   #2
icecreammmm
Drives: 6MT - 2013 BLACK
damn, if only i didnt buy other things... im local and if these dont sell for about a month... than i might consider.
till than glws!
icecreammmm is offline   Reply With Quote
Old 04-05-2014, 12:57 PM   #3
RedFRZ
Drives: Red FRS
Still for sale?
RedFRZ is offline   Reply With Quote
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
FS: Perrin Intake / Megan Street Series Coilovers / Swift Springs peteralfonso Engine, Exhaust, Bolt-Ons 1 09-27-2013 06:08 PM
Megan Racing street series review Drftfan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 09-18-2013 08:31 AM
megan racing street series coilovers w/front camber plates 256brz2013 Brakes, Suspension, Chassis 33 07-01-2013 09:39 AM
Megan Racing Street Series Coilover Kit DeeJayMajesty Brakes, Suspension, Chassis 4 03-22-2013 04:59 PM
