Old 05-05-2018, 09:07 PM   #3277
EffaressNOOB
EffaressNOOB's Avatar
Drives: Halo 2016 Scion FR-S, 6MT
Originally Posted by smg1138 View Post
I don't know if I've ever seen anyone run a 17x9 +30 wheel on this car. If you could even find some they're likely to rub the fenders unless you have crazy camber. One of the most popular wheels in STX are Enkei RPF1's in 17x9 +35. For me they don't poke at all with a 1.5" drop and -2.5 front -2.0 rear camber. Maybe not the most original setup, but they're a proven design that's light, relatively strong, and reasonably priced.
I wondered that myself. Someone on FB is selling a set of used RPF1s with with those dimensions. I was concerned about the poke myself. He is running on 235/45 which is not wide enough for my needs anyway. I have pics of his setup and they looked decent enough, even with a little stretch. Just wondering if someone had any insight or experience with that offset.
Enkei TFR (Copper) 17x9+45 | Hankook Ventus V12 Evo2 245/40 | Tein Flex A
OFT Stage 2, E85 | Kraftwerks Skunk2 CAI
Open Flash Unequal Length Header
Invidia N1 CatBack
InstaGram: 49RJ
EffaressNOOB is offline   Reply With Quote
Old 05-05-2018, 11:57 PM   #3278
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Probably a typo, iirc the wheel specs are inscribed inside rpf1s including offset, ask for a picture.
Like this: 17x7.5 +48 offset
ineedyourdiddly
EffaressNOOB (05-06-2018)
Old 05-06-2018, 12:01 AM   #3279
EffaressNOOB
I asked for tons and actually talked to him on the phone!
Invidia N1 CatBack
InstaGram: 49RJ
The Following User Says Thank You to EffaressNOOB For This Useful Post:
strat61caster (05-06-2018)
Old 05-06-2018, 12:02 AM   #3280
EffaressNOOB
Once they’re off, I’ll ask him to double check
Invidia N1 CatBack
InstaGram: 49RJ
Old 05-07-2018, 08:11 PM   #3281
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
You can tell just from the face of the wheel.
tigermack is offline   Reply With Quote
Old 05-09-2018, 05:37 PM   #3282
tony_r
tony_r's Avatar
Drives: '15 STX
Anyone have the SPC rear lower arms with Delrin inserts? I'm about to throw them in the trash since they make so much noise. Have a way to shut them up?
tony_r is offline   Reply With Quote
Old 05-09-2018, 05:37 PM   #3283
M0nk3y
Throw them in the trash :P
Kyle H. - #89 STX
Old 05-09-2018, 05:44 PM   #3284
tony_r
tony_r's Avatar
Drives: '15 STX
Going to OE at my height would probably net me close to the same amount of camber, so definitely an option. I just don't want to do more work than I have to.
Old 05-09-2018, 07:40 PM   #3285
cjd
cjd's Avatar
Drives: 2017 BRZ
My vote for trash is because I hate aligning with them... Can't help on the noise issue, I have Racer-X and don't know how much they're contributing to road noise vs Raceseng top hats vs subframe/diff inserts. My exhaust is currently rather quiet. Will get louder once I can fix the FP I got so it actually fits...
Old 05-10-2018, 12:06 AM   #3286
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Ask Rich. He has SPC LCAs with Delrin inserts
G_Ride is offline   Reply With Quote
Old 05-10-2018, 12:47 PM   #3287
justint5387
Drives: 4 wheels
We have the SPC arm with the Delrin insert, doesn't make any noise. Did you try to over torque it? I don't think I used a torque wrench.
Did you replace the rear end links?
justint5387 is offline   Reply With Quote
Old 05-10-2018, 01:26 PM   #3288
tony_r
tony_r's Avatar
Drives: '15 STX
Nah torqued it to spec.
I took it all apart last night and figured it out. The right side bushing/insert didn't freely rotate, it was all bound up. Looks like it wasn't concentric when installed into the arm. Did a little machining to them and seems to be working fine now.
Old 05-10-2018, 01:47 PM   #3289
M0nk3y
At least it's not only me who has a noise issue with Raceseng Top Hats, RacerX LCAs
Kyle H. - #89 STX
Old 05-10-2018, 02:15 PM   #3290
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
So, I tried installing my new brake Centric rotors last night and could't get the stock rotors off. After almost 80k miles I guess they've rusted on to the hub. Any advice on how to get them off?
smg1138 is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
