#3277 | |
Drives: Halo 2016 Scion FR-S, 6MT
I wondered that myself. Someone on FB is selling a set of used RPF1s with with those dimensions. I was concerned about the poke myself. He is running on 235/45 which is not wide enough for my needs anyway. I have pics of his setup and they looked decent enough, even with a little stretch. Just wondering if someone had any insight or experience with that offset. Sent from my iPhone using Tapatalk
Enkei TFR (Copper) 17x9+45 | Hankook Ventus V12 Evo2 245/40 | Tein Flex A
OFT Stage 2, E85 | Kraftwerks Skunk2 CAI Open Flash Unequal Length Header Invidia N1 CatBack InstaGram: 49RJ |
#3278 |
Drives: '13 FRS - STX
Probably a typo, iirc the wheel specs are inscribed inside rpf1s including offset, ask for a picture.
Like this: 17x7.5 +48 offset
| The Following User Says Thank You to strat61caster For This Useful Post: | EffaressNOOB (05-05-2018) |
#3279 | |
I asked for tons and actually talked to him on the phone! ![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk
| The Following User Says Thank You to EffaressNOOB For This Useful Post: | strat61caster (05-05-2018) |
#3280 | |
Once they’re off, I’ll ask him to double check Sent from my iPhone using Tapatalk
#3281 |
STX 188
You can tell just from the face of the wheel.
#3282 |
Drives: '15 STX
Anyone have the SPC rear lower arms with Delrin inserts? I'm about to throw them in the trash since they make so much noise. Have a way to shut them up?
#3283 | |
Throw them in the trash :P Sent from my iPhone using Tapatalk
Kyle H. - #89 STX
#3284 |
Drives: '15 STX
#3285 |
Drives: 2017 BRZ
My vote for trash is because I hate aligning with them... Can't help on the noise issue, I have Racer-X and don't know how much they're contributing to road noise vs Raceseng top hats vs subframe/diff inserts. My exhaust is currently rather quiet. Will get louder once I can fix the FP I got so it actually fits...
#3286 |
Drives: Some kind of Subaru
#3287 |
Drives: 4 wheels
We have the SPC arm with the Delrin insert, doesn't make any noise. Did you try to over torque it? I don't think I used a torque wrench.
Did you replace the rear end links? Last edited by justint5387; 05-10-2018 at 12:02 PM. |
#3288 | |
Drives: '15 STX
I took it all apart last night and figured it out. The right side bushing/insert didn't freely rotate, it was all bound up. Looks like it wasn't concentric when installed into the arm. Did a little machining to them and seems to be working fine now. |
#3289 | |
Kyle H. - #89 STX
#3290 |
Drives: 2013 Raven FR-S
So, I tried installing my new brake Centric rotors last night and could't get the stock rotors off. After almost 80k miles I guess they've rusted on to the hub. Any advice on how to get them off?
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
