Old 07-10-2012, 06:17 PM   #1
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
FRS-BRZ Port Fuel Injector (interesting)
Here's a picture of the OEM port injectors on our FRS vs. the blue top feed injectors used in the WRX/STi
They appear to extend way into the intake runner and are very small. I can't say I've seen these used in any other application but if you have let me know on what vehicle.
Too small for our FRS and what we'll be doing so in went some 750cc I'm running a Hydra EMS so no these will not bolt in your stock FRS/BRZ. I had to make some fuel rail spacers to utilize the OEM fuel rails.
Thanks,
Phil Grabow
Element Tuning is offline   Reply With Quote
The Following User Says Thank You to Element Tuning For This Useful Post:
coyote (07-10-2012)
Old 07-10-2012, 06:52 PM   #2
jeebus
so are you disabling the direct injection as well?
jeebus is offline   Reply With Quote
Old 07-10-2012, 06:59 PM   #3
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
they look similar to the injectors used on BMW's and Audi's...
similar Bosch Motorsport injectors looks like this:
Wouldn't be hard to machine those for an 11mm o-ring inlet and Denso seat
JP is offline   Reply With Quote
The Following User Says Thank You to JP For This Useful Post:
Im_SPEED (08-27-2016)
Old 07-10-2012, 07:54 PM   #4
Touge Monster
Touge Monster's Avatar
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
Most of the new toyotas have injectors like that 3URFE injectors look very similar
Touge Monster is offline   Reply With Quote
Old 07-10-2012, 09:07 PM   #5
slow_frs
Drives: turbo scion tc
Thanks,
Phil Grabow
Why ... I'm quite certain that the direct injection will flow enough fuel alone for the power the motor can handle and if you max the duty cycle you can start adding fuel from the port injectors
slow_frs is offline   Reply With Quote
Old 07-10-2012, 11:43 PM   #6
Element Tuning
We are going forced induction and I'm not running gasoline so I'm planning ahead. Justvices not trying to create extra mapping.
We are building a 500 HP Time Attack FRS so much of what we do won't make sense to a casual enthusiest. For most following a similar path changing the port injectors is an easier solution than the direct injectors. At a high enough power level direct injection pressure won't be adequate to deliver enouch fuel on its own.
We don't plan on abandoning the direct injection at all, it's a huge asset to performance and fuel economy.
Old 07-10-2012, 11:51 PM   #7
Illusive
Drives: 2005 Subaru STi
The port injectors are there because without them the intake valves get way too dirty running only direct injection.
Illusive is offline   Reply With Quote
The Following User Says Thank You to Illusive For This Useful Post:
jcw99 (01-21-2017)
Old 07-10-2012, 11:51 PM   #8
arghx7
Drives: car
For boosted applications, spraying E85 with direct injectors has a drastic improvement in charge cooling effect compared to port injectors.
Old 07-11-2012, 12:36 AM   #9
Element Tuning
It has this same effect even with pump fuel. Direct injection is what allows this level of performance with a 12.5:1 running premium fuel which you cannot get with port injection alone.
Old 07-11-2012, 12:40 AM   #10
Dimman
Kuruma Otaku
Dimman's Avatar
@arghx7
Just take some deep breaths, count to 10, and go off to the random pictures thread. Bestwheelbase has some pretty wicked pics posted.
Because titanium.
The Following User Says Thank You to Dimman For This Useful Post:
Hawaiian (07-17-2013)
Old 07-11-2012, 05:11 AM   #11
Allch Chcar
Drives: N/A
It would be nice if there was a set of stock injectors that swapped over. Say in the +50%-100% higher flow range.
So what are you running if not Gasoline?
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 07-11-2012, 05:47 AM   #12
serialk11r
Drives: '06 AM V8V Coupe
I haven't completely thought this through but with E85 especially and boost, wouldn't it be better to spray E85 into the manifold or something rather than the ports, assuming the direct injectors are maxed out? That way it evaporates before it hits the valves, and with boost it will help cool things down too. Reducing available air mass isn't a big deal since the lower temperature and pressure will allow more air to come in anyways.
Old 07-11-2012, 07:06 AM   #13
arghx7
Drives: car
In a situation like this you want to run as much of the total fuel mass through the DI injectors as you can. This has to be within the hardware constraints (injector flow rate, fuel pressure capability) and the calibration constraints (injection timing window). I don't want to sound like an obnoxious name dropper but I went to a long MIT presentation about this a couple months ago at an industry alternative fuels conference.
There is an exponential relationship between the charge cooling effect of PFI and GDI when using ethanol. The MIT Sloan Automotive Lab did a very in-depth engine dyno study on this. They were funded by GM (among others) and used a Pontiac Solstice engine modified with PFI injectors.
the chemical anti-knocking properties of ethanol are still there when you use port injection or your typical alcohol injection type of deal (spraying it into the intake. The charge cooling effect is far weaker, and the effective octane number (in RON) is far less.
The Following User Says Thank You to arghx7 For This Useful Post:
Allch Chcar (07-11-2012)
Old 07-11-2012, 01:10 PM   #14
Element Tuning
I'm currently on E85 but I may also be running some race fuel. Trying to get more power out of this car for Ultimate Track Car Challenge which is next week so I need to move faster than I want.
I'm sure there will be a nice OEM like replacement port injector in the future. For now I'm just sharing what information I've gathered. Port fuel injection runs at 55 psi by the way.
Interesting factoid... Opie BRZ First-Gen (2012+) — General Topics 13 07-04-2012 10:23 AM
Interesting graphics on a 86 ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 05-12-2012 12:16 AM
Interesting news about BBS Esoteric Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 02-17-2012 07:10 PM
Why ft-86 is interesting? NewCarInQ42011 Scion FR-S / Toyota 86 GT86 General Forum 69 11-26-2010 05:05 PM
