Old 07-08-2012, 05:35 PM   #43
Proud of BOXER
Drives: 74 Toyota Celica ST
These should be 8 pot front and 6 pot rear, respectively.
Proud of BOXER is offline   Reply With Quote
Old 07-08-2012, 05:43 PM   #44
TPO
TPO's Avatar
Drives: Scion fr-s,Lexus is250,4-runner
With a pair of 18x8.5 38 offset work meister s1 3pc wheels and the endless front and rear brake setup, you would be the hog with the big nuts
TPO is offline   Reply With Quote
Old 07-08-2012, 06:31 PM   #45
old greg
Rocket Surgeon
Drives: PSM GGA OMG
12 pots or GTFO.
old greg is offline   Reply With Quote
Old 07-09-2012, 01:04 AM   #46
jamal
jamal's Avatar
Drives: Legacy GT
I hope everyone understands that more pistons does not equal better.
Since I already mentioned caliper stiffness here, a 4-pot is pretty much always going to be stiffer than a 6 or more piston caliper.
The main benefit for going to more pistons is to have a longer and larger pad, which might last longer, without uneven wear. Anything more than 6 is pretty silly IMO.
jamal is offline   Reply With Quote
Old 07-09-2012, 01:15 AM   #47
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
until you get into silly aero and alms rubber, you won't need more pad than a 4 pot could handle anyway.
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below.
http://fecompetition.wordpress.com/
https://www.facebook.com/FECompetition
Matt Andrews is offline   Reply With Quote
The Following User Says Thank You to Matt Andrews For This Useful Post:
mines13 (07-11-2012)
Old 07-09-2012, 11:48 AM   #48
Turbowned
Turbowned's Avatar
Exactly. When you're Jackie f***in' Ickx driving this car in spec racing,you can look at brakes like these. Until then, the most I would do is a 4pot front, 2pot rear setup through Wilwood, which would probably cost ~$2500. Otherwise, upgraded pads, rotors, fluid and lines will be more than enough.
The Following 2 Users Say Thank You to Turbowned For This Useful Post:
mines13 (07-11-2012), Slartibartfast (08-18-2012)
Old 07-11-2012, 04:48 AM   #49
yuli8466
Drives: MX5
Originally Posted by Hanakuso View Post
That's almost half the price of an FRS at the current exchange rate..
yes , i think the caliper is good, the price is stupid...
yuli8466 is offline   Reply With Quote
Old 07-11-2012, 12:17 PM   #50
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Something like this, found on the Stillen site makes a lot of sense, I can get a Ferodo DS2500 pad for it too.
STILLEN is proud to announce the release of the AP RACING 4 Piston and 6 Piston Big Brake Kit for the Scion FR-S and Subaru BRZ.
The 4 Pisont front kit under part number AP3120 uses a 330x28mm two piece disc and you have the option of getting either crossed drilled and slotted or just Slotted. You also have 2 color options when it comes to the 4 piston caliper: Red, or Black will look really nice in the wheel well of any BRZ / FR-S.
RED
BLACK
If you’re looking for the next level of braking performance we also offer the AP6100 6 Piston kit.
The AP6100 kit uses the AP RACING 6 piston caliper with larger 355x32mm two piece discs. You also have the option of three different Caliper colors, and two rotor styles.
As you can see, we also offer the Slotted and Drilled, or just Slotted rotor options for the AP 6100 brake kit rotors.
Both of these AP RACING kits bolt up to the factory locations and are designed to work well with the factory ABS systems and brake master cylinder. They also feature dust seals over each caliper piston to ensure reliability and high performance for as long as you own your vehicle.
mines13 is offline   Reply With Quote
Old 07-11-2012, 12:36 PM   #51
Turbowned
Turbowned's Avatar
Mmmm, AP Racing.... wanted these for my MR2 but a front kit was more than twice what a Wilwood kit cost, and I don't need them that badly.
Old 07-17-2012, 11:35 AM   #52
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Why all the hate? Anyone own an Endless setup before? AP? Alcon? If you like something and can afford it, great. While i don't think everyone with an fr-s needs a kit like these, they are useful for a machine that sees frequent track use.
If you don't think the quality is there, or your wallet/wife doesn't allow it, then move on. Endless doesn't care if you like them on the interwebs anyway.
ill86 is offline   Reply With Quote
Old 07-17-2012, 01:41 PM   #53
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
i think 12k for BBK is ridiculous too, but this is endless' full blown racing model, and is priced similar to brembo's GT-R series. the brembo GT-Rs are 8000 just for the front, and another 8000 for the rears. so for 16k, the brembos for all four wheels are 4k more than the endless racing setup.
both brembo and endless have more regular for street use BBKs at more reasonable (but still expensive) prices. these endless racing and brembo GT-R kits are for full blown race cars with ridiculous budgets.
cyde01 is offline   Reply With Quote
The Following User Says Thank You to cyde01 For This Useful Post:
ill86 (07-17-2012)
Old 07-17-2012, 01:54 PM   #54
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Screw endless even their name is ridiculous!! Endless? So its endless braking thats scary lol when will it end!! What a dumb name for a brake manufacturer. Id stick with AP or Stoptech!!
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 07-17-2012, 02:00 PM   #55
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Originally Posted by cyde01 View Post
i think 12k for BBK is ridiculous too, but this is endless' full blown racing model, and is priced similar to brembo's GT-R series. the brembo GT-Rs are 8000 just for the front, and another 8000 for the rears. so for 16k, the brembos for all for wheels are 4k more than the endless racing setup.
Absolutely correct. I was just about to post this.
This is the full blown huge budget motorsport race team kit. You can get a street/HPDE kit for MUCH LESS (although still very pricey)
I almost feel like this and the Brembo race caliper is the same. They look almost identical.
No Limit Motorsport is offline   Reply With Quote
Old 07-17-2012, 02:43 PM   #56
jamal
jamal's Avatar
Drives: Legacy GT
Yeah, but with the whole "limited to 86 sets only" thing it seems to be marketed more toward show cars and jdm fan bois than actual racing.
GRB Brembo caliper on BRZ RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 66 11-15-2016 02:50 PM
Brake caliper paint WRB-DZA-BRZ Cosmetic Modification (Interior/Exterior/Lighting) 45 10-05-2016 01:02 PM
RED G2 BRAKE CALIPER PAINT?? Mo707 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 07-03-2012 01:38 AM
Stock caliper model? skoodge Cosmetic Modification (Interior/Exterior/Lighting) 4 05-31-2012 08:41 PM
The Endless Argument: EFI or CARBURETION Axel Other Vehicles & General Automotive Discussions 2 02-13-2010 08:33 PM
