#3249 |
Drives: 2013 FRS
Since I bought my car which was prepped for stx already with 400/400 springs I've had a strong feeling that the 400/400 was way too stiff. The car feels pretty good but i feel like it should have more grip and more predictability. So I finally swapped in some 275 lb springs on the rear with the intention of lowering the front almost as much and already the improvement is unbelievable. The car is so much more planted, easier to drive, and just grips much better over smooth surfaces or rough. I don't know how the general community came to like the 400/400 setup but I am stunned at the improvement from softening even just the rear springs. Just some food for thought.
#3250 | |
Drives: 2013 Raven FR-S
#3251 |
Suspension Nerd
Drives: 2019 Mazda MX-5
OS Giken / Bridgestone / Lot-USA BRIDE
#3252 |
Drives: '13 FRS - STX
It takes springs, sways, alignment, and a little bit of everything else to balance a car.
You can probably make 400/200 loose as hell with a big rear bar, no toe and whatever gets the front planted. You can definitely make 300/500 push with no rear bar, a bit of toe in and a bigger front bar. If you prioritize certain things in your setup like minimizing toe or keeping soft sways or soft springs you can end up in drastically different places than someone else. 400/400 was available early on with a good double adjustable off the shelf from RCE, most off the shelf 'do it all' kits are around 6k +/- and you have to go hunting for anything different. A worn or improperly adjusted damper can make any spring feel like crap. Probably not the case but worth mentioning. I think I heard a car or two running similar rates to above based on Stranos advice? Makes sense to me if you're prioritizing zero toe and are using a stiffer sway bar than OE and getting the car to match a driving style. I wouldn't judge a setup based on spring choice alone, lots of things can work on this car and I have a feeling it'll be a decade before setups truly converge. BTW OE rear rate for an FRS was 211# I think there's some lowering springs stiffer than 275. It'll be interesting to see some SSC/STX cars on a budget compete over the next few years. Edit: Eibach Pro Kit springs for SSC are 275 rear |
| The Following User Says Thank You to strat61caster For This Useful Post: | smg1138 (05-03-2018) |
#3253 |
Drives: 2017 BRZ
In the rain, lower spring rates definitely seem to help. Saw an SSC car take top PAX in conditions that were barely above freezing, and wet... and the stuff falling from the sky shifted to ice pellets as we were cleaning up. I have no idea what their swaybar setup or alignment was, but of course the sways for SSC can be pretty stiff.
Who would have guessed snowflake class was really about weather conditions though?
| The Following User Says Thank You to cjd For This Useful Post: | Shark_Bait88 (05-03-2018) |
#3254 | |
Drives: 2024 GR86/ 2015 FRS
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts |
| The Following User Says Thank You to Simmons For This Useful Post: | cjd (05-03-2018) |
#3255 |
Drives: '15 STX
SSC is better the worse the surface conditions are. Add grip and it all falls apart. No doubt an STX car would be just as good if not better with some minor changes for conditions. But that's the thing; a lot of people set up their car for optimal conditions, not the worst conditions.
Therein lies one of the issues that stiffly spring cars suffer from. It's sometimes not realistic to swap springs on site. Moreso, with custom valved shocks, you sometimes don't have the desired range to work with a softer or stiffer spring. For something like AX with highly variable surface changes and conditions, it's much easier to tune with bars than springs. There is more than one way to skin a cat, though. |
#3256 |
Looks like it's finally about time to replace my OEM rotors. What do you guys recommend as replacements? Should I get slotted or just stick with blanks? I'm still using the stock calipers with Winmax W3 pads.
#3257 |
Drives: 2017 BRZ
Unlikely to make a difference. Whatever you prefer, but normal cheap blanks are all you need.
| The Following User Says Thank You to cjd For This Useful Post: | smg1138 (05-03-2018) |
#3258 |
#3259 |
Drives: '22 BRZ
Get Centric blanks.
#3260 |
Drives: 2013 FRS
2nd that.Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
| The Following User Says Thank You to bmacfrs For This Useful Post: | smg1138 (05-04-2018) |
#3261 | |
Drives: 2013 FRS
As for comparisons to SSC, seeing how well SSC is doing compared to STX was the final push to convince me to try going softer. There is no reason at all that an STX car shouldn't be significantly faster than an SSC car and the only only aspect of the SSC car that could possibly be anything but a disadvantage compared to an STX car is the softer springs. But yes it certainly depends to an extent on conditions, driving style and preference. I just think it's an interesting topic. The improvement I have experienced has been so drastic with the softer springs that I just think it's worth some discussion. Though, I may be speaking too soon as I haven't actually raced it yet. I may feel a little differently if it starts under-steering badly on course. I'll report back after the 12th. I'm racing with the same crowd again that I last did on the stiffer rear springs so I'll compare my finishes for a rough indicator. |
#3262 |
Drives: 15 BRZ
Anyone ever reach a consensus on if the transition control was legal?
Delta/CENLA Region SCCA - DS
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
