#4145 | |
BoostedBRZ
Drives: Turbo BRZ
Take a look at what I did. http://www.ft86club.com/forums/showp...3&postcount=23 The above doesn't solve your oil sensor port problems. but this should: http://www.ft86club.com/forums/showp...99&postcount=4 do what batstig did in the link above and that will solve your problem.
#4146 |
BoostedBRZ
Drives: Turbo BRZ
no sound change. no re-tune required all it is the width that is changing. How wide the pulley is. the diameter isn't changing. if the diameter changed than that would require a retune.
#4147 | |
Stuck In a Sandbox
Drives: FRS RS1.0
Ah so the TRD plate DOES fit with the kraftwerks kit? thats what i was unaware of lol |
#4148 |
BoostedBRZ
Drives: Turbo BRZ
you're probably gonna have to get a low profile oil cap like the perrin one I have. or take a dremel and shave off the top of the yellow oil cap to make it flat.
#4149 |
Drives: FRS
I picked up one of these thin oil caps. It works, and is about half the cost of the Perrin:
Custom billet aluminum oil filler cap for Scion FRS Subaru BRZ 2013. http://r.ebay.com/odBsKa
2018 Audi RS3 - Iroz
2005 Long Travel Tundra 4x4 2008 Long Travel Tundra 2wd |
#4150 | |
Stuck In a Sandbox
Drives: FRS RS1.0
#4151 |
Drives: FRS
Yes. I have the motul setup. bottom to top: spacer->sensor plate->oil cooler plate
It works. The key is to no leaks is to have good gaskets, and set them up properly. double-ring facing up and the convex side facing down, all gaskets inserted into the bottom side of each plate. Depending on which bolts they come with, you'll need a socket somewhere in the 25-27mm range. I tightened mine down snug, but not too tight. sorry, I'm too lazy to use a torque wrench sometimes.
#4152 |
Drives: Brz
Broke my first belt yesterday. It was a 30mm belt on around 9000 miles. I think it was due to a pulley bearing going bad, it was making some audible noise then a snap. The belt was snaked around the supercharger pulleys so it stopped the charger from spinning, but it took out the rotrex inline filter as it happened.
Gonna rip apart the supercharger bracket and see which pulleys need to be replaced. Douglas @ Kraftwerks was very helpful during this ordeal.
Daily Project: Honda s2000
Track: 707 WHP Turbo Honda Civic EG Old: Kraftwerks Supercharged Subaru Brz |
#4153 | |
BoostedBRZ
Drives: Turbo BRZ
#4154 | |
Drives: Brz
Hopefully they make a auto tensioner revision (highly doubt it). Love the rotrex system
#4155 |
Drives: Asphalt FRS
Has anyone had their system gradually increase in volume? I've noticed in the past few weeks that my Supercharger "whine" has become more of a WHINE. With the hood open it is almost unbearable to be near the car, hurts your ears.
Oil looks fine, no discoloration, so doesn't seem like its a lack of oil circulation or anything. Could it be pulley bearings? Any way to lubricate or replace the bearings used? If they are off the shelf bearings and can be pressed out/in that would be rad.. Any input would be super appreciated! Thanks |
#4156 | |
BoostedBRZ
Drives: Turbo BRZ
#4157 | |
Drives: Asphalt FRS
Been in contact with kraftwerks. Two of my pulleys have a small amount of play/wobble, but spin freely. One has no play, but is a bit tighter and does not spin as freely. Rotrex unit does not have any shaft/impeller play. Still waiting to hear back from kraftwerks about what they suggest for further diagnosing, but they haven't responded in the few days since I sent the video of the pulleys. Other than shaft play, any other diagnostic type things that can be done to determine if the rotrex unit is on its way out? |
#4158 | |
Drives: Brz
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
