| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2017 GT86
Hub Centrics
So i've lost my hub centrics, what size do i need ?
I run xxr's 550 17x8.5 Wheel bore is 73mm if im correct, just need clarification. Thanks.
Instagram - @WessleeSnapz
#2 |
Famous Potatoes
Drives: '15 ultramarine
Do you have a receipt from when you bought them?
#3 |
Drives: Track preped NA FRS
You dont need any.
| The Following 2 Users Say Thank You to Icecreamtruk For This Useful Post: | wparsons (05-02-2018), Yoshoobaroo (05-02-2018) |
#4 | |
Country Boy 4 Life
Hub bore is 56.1 17x8.5 is a rare size.
I LIKE TIRES! |
#6 | |
Flat seat lugs would be an issue, but conical (spherical) or tapered seats are 100% fine.
| The Following 2 Users Say Thank You to wparsons For This Useful Post: | Icecreamtruk (05-02-2018), nico_rsx (05-03-2018) |
#7 | ||
Drives: 2013 WRB BRZ
Yes, a hubcentric ring will help support the wheel on the hub and make sure it is centered better than just the lug nuts. However, will using only the lug nuts to keep the wheel centered work? Yes, and you probably won't have an issue, depending on usage. It's just less robust.
#8 | |
TRACKBREAD
Hub Centrics
I'm not worried about the conical seats. The hole pattern in the hub is not nearly as accurate as the surface of the hub bore, hence why I mentioned bolt circle tolerances. I've used conical lugs without a hubcentric ring and gotten significantly vibrations in the wheel. I'd rather use the hub surface if it was designed for it. |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | Tristor (05-03-2018) |
#9 |
Drives: 2017 Toyota 86, 2000 Mazda Miata
What kind of shitty wheels are you guys using that a spherical lug hole wheel needs to be hubcentric to avoid vibrations?
My stock miata wheels aren't hubcentric and work perfectly. I can't imagine an OEM would use non-hubcentric wheels if it was going to be such shit. |
#10 | |
TRACKBREAD
Hub Centrics
Volk TE37s. Maybe I'm just anal and what is a significant vibration for me isn't for most people. |
#11 |
Drives: 2014 GT86
Sometimes disbalance might come also from other unnoticed reasons. For example if tire on wheel is non remounted/rebalanced for years, some uneven wheel/tire wear/damage or fix/patch w/o rebalance, or if some balancing wheels happened to fall off at some point, if one tightens lug nuts in wrong order not in cross/star fashion. By my experience in most cases even without spigot center rings lugcentric wheels itself always centered right with properly tightened lug nuts on all cars/wheels i had so i'd rather blame other reasons as more possible. Though then again hub rings are cheap, so one's budget won't be broken if one buys them for ease of mounting and some piece of heart/extra ensurance. Just that imho they are not must have/mandatory on lug centric wheels, but cheap nice to have extra.
#12 |
Country Boy 4 Life
I never used hubcentric rings back in he day. Then one car I had needed them, and I had to wait to get them. Now I always get them. They do not cost much, and can save a big headache.
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | Tristor (05-03-2018) |
#13 | |
If you're properly torquing down wheels (wheel in the air, star pattern a bit at a time), the wheel will absolutely center itself. If you set the car down before the lugs are seated properly, then you'll definitely get a wobble. Going into my 6th summer with the car running RPF1's without centering rings, no vibrations ever.
| The Following 3 Users Say Thank You to wparsons For This Useful Post: |
#14 |
Site Moderator
Drives: ichi 86 Project
If you google it, it does answer pretty much all the stuff you're looking for.
This site shows XXR 550 specs. Which show what size centerbore is. Member already answered stock hub bore size in the post. With that info go to Amazon or eBay to search hubcentric ring: "(wheel centerbore)mm to (hub bore)mm". |
| The Following User Says Thank You to ichitaka05 For This Useful Post: | Leonardo (05-03-2018) |
