Old 05-02-2018, 04:20 PM   #1
khcho19
Drives: ford focust ST
17x7.5 vs 18x7.5 wheel
Hi Guys,
I currently have stock wheels which are 17x7.5 48 offset.
Do you think 18x7.5 48 offset will fit without any issue?
Im asking this because I will keep the stock suspension and I will not lower my car.
someone told me that stock suspension can't handle 18x8, so what about 18x7.5?
khcho19 is offline   Reply With Quote
Old 05-02-2018, 04:27 PM   #2
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
If only there were a sticky thread somewhere, perhaps at the top of the wheel and tire section of the forum, which could link to the information you need...that'd be just great. Maybe if it had a catchy name like "Will this fit?", so people would see it easily...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following 2 Users Say Thank You to venturaII For This Useful Post:
churchx (05-02-2018), funwheeldrive (05-02-2018)
Old 05-02-2018, 04:31 PM   #3
hyper4mance
hyper4mance's Avatar
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
Try the calculators below for whatever setup you want to try. Its not just the wheel size, but also tire width and height.
https://www.rimsntires.com/specspro.jsp
https://www.willtheyfit.com/
https://tiresize.com/wheel-offset-calculator/
I didn't plug in your values since you didn't mention what you want for tires, but off the top of my head I don't see why 18x8 wouldn't work.
hyper4mance is offline   Reply With Quote
Old 05-02-2018, 04:34 PM   #4
khcho19
I might use tire that comes with BTZ TS wihich is P215/40R18
Old 05-02-2018, 04:39 PM   #5
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
So plug it into the tools he linked to, start using the information and resources already available to you (like the SEARCH feature and very helpful technical guides located all over this forum), and quit making a bunch of useless/repeat threads.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
Mr.ac (05-02-2018)
Old 05-02-2018, 04:48 PM   #6
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Hi Guys,
Just curious is this a stock 86 wheel in 17x7.5? Is that the TRD wheel?
I thought all stock 86 wheels were 17x7 w 48 offset
DandoX is offline   Reply With Quote
Old 05-02-2018, 04:52 PM   #7
khcho19
It's the one comes with yellow series BRZ
Old 05-02-2018, 04:53 PM   #8
khcho19
For some reason, SEARCH feature is not working for me.
It says there's no result whatever I serach for.
Old 05-02-2018, 05:03 PM   #9
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Start here.
THE WHEEL DIRECTORY
This is a guide with info on what will fit and a compilation of almost all members wheels, specs, and pics.
https://www.ft86club.com/forums/showthread.php?t=7535
I LIKE TIRES!
Shark_Bait88 (05-02-2018)
Old 05-02-2018, 05:12 PM   #10
Shark_Bait88
No idea what you're searching then. I typed "18x7.5 fitment" and got 25 thread results. The 1st and 3rd results both led to the wheel directory, which has plenty of examples of wheels with similar specs that could answer your questions or at least give you an appropriate existing thread in which to ask your question. Sometimes you have to do some digging.
Old 05-02-2018, 05:50 PM   #11
rvoll
Drives: 2018 BRZ Limited, 2017 Sportage
Hi Guys,
1. OEM wheels are 17x7 with a 48 offset (not 7.5)
2. There is no performance reason to go to 18's especially if you are keeping the same offset.
3. If you are keeping the stock suspension, it means you are not racing the car. Therefore, there is no reason to go beyond 215's or 225's for the width of the wheel. Both of these will fit on 7", 7.5", and 8" rims.
4. 17's will give you a slightly better ride and protect the rim more as there is more sidewall. 18's can give slightly better cornering, but the increase is so slight I doubt if you would notice it.
5. If you have that money burning a hole in your pocket, buy better tires. That is the one thing that will make a big difference if you have OEM tires.
I started a whole thread on this topic and have ended up keeping the 17" OEM rims but changing the tires to 225/45/R17 Michelin Pilot Sport 4S -- the same model that is on the tS (except the tS has 18" rims). I really wanted to justify buying new rims, but in the end, it would have been only for looks. If you are just in it for looks, buy what you want and forget that it might negatively impact performance.
rvoll is offline   Reply With Quote
Old 05-02-2018, 06:27 PM   #12
OfficeWorker
Drives: 2018 WRX STI
This may be of interest:
http://www.ft86club.com/forums/showthread.php?t=24102
(Note that the wheels in that thread are insanely light at something like 16 pounds...obviously, most 18-inch wheels will not save weight over an OE 17-inch wheel, and can entail a loss in acceleration and fuel economy, with often limited handling gains in regards to street performance.)
OfficeWorker is offline   Reply With Quote
Old 05-02-2018, 06:43 PM   #13
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
It's all up to offset of the wheel. I've ran 18x8 +35 (225/40 tires) w stock suspension without any rubbing.
As long as you accommodate width of the wheel with offset of the wheel, it won't rub.
Old 05-02-2018, 06:51 PM   #14
khcho19
Thanks for the comment.
For number 1, It is 17x7.5. My car is BRZ performance package.
Yea, I am not racing, and only reason that Im considering 18 wheel is for look, but I am concerning that 18" will make my car look like off-road car, and fuel efficiency bad.
I am considering either 17x7.5 or 18x7.5 (JDM STI wheel) now with 225/45/R17 (or R18) Michelin Pilot Sport 4S -- the same model that is on the tS
Wheel Directory: TRD SF2 18x7.5 +46 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 07-22-2016 08:22 PM
What Wheel is this? 18x7.5 5 Spoke continuecrushing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 06-15-2016 02:44 PM
Wheel Directory: Work Emotion XT7 18x7.5 +48 / 18x7.5 +42 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-26-2013 09:42 PM
Enkei EKM3 17X7.5 or 18X7.5 for a DD FR-S Matt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 02-27-2013 01:36 AM
(SoCal)TE37 17x7.5 OR Tom's TN06 18x7.5 (both bronze & 5x100) bino Wheels and Tires 17 11-13-2012 02:04 PM
