Old 05-02-2018, 09:50 AM   #57
Code Monkey
Drives: Subaru BRZ
On the OEM PP Brembo calipers, I just use my fingers to slowly push the pistons back in, just make sure to remove the cap on the master cylinder. I cannot imagine AP calipers are any different?
Code Monkey is offline   Reply With Quote
Old 05-02-2018, 01:19 PM   #58
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
You can push the AP pistons back in by hand, but I'd recommend wearing leather gloves, they're sharp enough to cut you.
Old 05-02-2018, 01:33 PM   #59
CSG Mike
CSG Mike's Avatar
The OEM PP calipers seal better than the AP CP8350, which is a race caliper.
For any caliper, if you cannot push in the pistons by hand, it *probably* needs a rebuild.
Old 05-02-2018, 01:40 PM   #60
Pat
Pat's Avatar
Drives: 2023 BRZ
The first few times I pushed the pistons back in my CP8350 I could do it by hand. Now I need to use an Irwin clamp to do it. While I understand being able to do it by hand means they are sliding smoothly, I'm hesitant to think they need a rebuild after one year. Mike, do you want to expand on your statement? The pedal still feels good and I'm not getting any noticeable drag.
Old 05-02-2018, 03:34 PM   #61
CSG Mike
CSG Mike's Avatar
Once a year is pretty common. They may not be getting noticeable drag, yet, but given how inexpensive the parts are to rebuild, I'd recommend doing it in your downtime. It should always be smooth.
Finding out the hard way can have more severe consequences, including burning up race pads needlessly, or having brake fade prematurely.
A non-race caliper with an out dust boot/seal will have a longer service life between rebuilds
Old 05-02-2018, 03:38 PM   #62
Pat
Pat's Avatar
Drives: 2023 BRZ
After I posted that I called Essex. They told me there are no significant downsides to my situation other than needing a tool to compress the pistons (a minor inconvenience). Mike, in theory I agree with what you said: "...burning up race pads needlessly, or having brake fade prematurely." However, I think that is an extreme situation and not at all what I am experiencing. Given my minor inconvenience, I'll gladly deal with it instead of shipping them off to be rebuilt annually.
Speaking of which, does anyone have a favorite brake spreader tool for calipers like this? This Lang tool looks appealing. Has anyone ever used it?
Amazon link here
Old 05-02-2018, 03:55 PM   #63
CSG Mike
CSG Mike's Avatar
Amazon link here
I use this spreader
https://www.amazon.com/Lisle-29100-Q...5290701&sr=1-6
Symptoms generally appear suddenly. It's similar to overheating your calipers; generally there's no consequence until one day you have a sudden failure. That's why I run temp strips like this (black = activated):
https://www.instagram.com/p/BOGJxgJjVo5
Per AP Racing (https://www.apracing.com/Info.aspx?I...ProductID=2858)
The brake caliper temperature indicator strip is applied directly to the brake caliper to indicate the maximum temperature the caliper has achieved during use,
It is essential that the caliper temperature is kept well within the working range of the brake fluid to prevent fluid vaporisation which will result in the loss of brake pedal.
Calipers that regularly run at up to 200°C - Re-seal every other event.
Calipers that run intermittenly from 200°C to 220°C - Re-seal as soon as possible.
PM me your address and I'll send you a few strips.
Old 05-02-2018, 08:04 PM   #64
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
The Lang tool doesn’t spread out far enough to compress the pistons on the AP Racing calipers. Might purchase the Leslie tool if it can spread further.
skylinekin is offline   Reply With Quote
Old 05-02-2018, 09:49 PM   #65
juliog
juliog's Avatar
Drives: 86
You can use the Lang tool to compress the pistons if you push against the worn out brake pads inside the caliper.
juliog is offline   Reply With Quote
Old 05-02-2018, 10:41 PM   #66
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
When I used the Lang tool and just grabbed the backing plates. You can also take one pad out and fit it in there.
Old 05-08-2018, 02:30 PM   #67
kch
Senior Misanthrope
kch's Avatar
My AP pistons have always been difficult (but not impossible) to compress by hand, since brand new. Now I just use the Lang tool with worn-out pads.
Old 05-08-2018, 06:21 PM   #68
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
I use one of these with an old backing plate to compress pistons:
Lynxis is offline   Reply With Quote
What does it cost you to race? (Cost of racing) rice_classic Tracking / Autocross / HPDE / Drifting 63 12-27-2013 09:54 AM
Benefit BBQ 11/16 12-3pm for our FOOD DRIVE. VTR Performance Northwest 0 11-13-2013 05:11 PM
Benefit of dark wax? Barbarian Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 07-18-2013 05:31 PM
2014 WRX benefit the 86? SanDiegoFRS Scion FR-S / Toyota 86 GT86 General Forum 22 02-18-2013 09:50 PM
